jd1923 Posted January 12, 2024 Posted January 12, 2024 20 hours ago, ScubaRx said: 30 feet of 2awg red + 30 feet of 2AWG black will cost nearly $250. 60 feet of each would be about $470. The wire is not cheap... I'm seeing prices quite a bit less, see my post above for more details. This welding lead is $215 plus tax, 50 FT each black/red. 100 FT should do it. Linked here again: TEMCo INDUSTRIAL WC0181-100' (50' Blk, 50' Red) 2 Gauge AWG Welding Lead & Car Battery Cable Copper Wire Black + RED | Made in USA - Amazon.com Perhaps @ScubaRx was considering a higher quality cable, as the kind @2008RN described above. Love his install, as he "ran the wire in the frame rail." This is the way I would do it, and agreed no shop is going to do that unless you order it on the service ticket. My other comment I made earlier was something like, "at $4000, run as fast as you can!" Some shops quote double when they really could care less if they get this custom one-off job. Given @MAX Burner ran the wires in a half day, let's call it full day. Charging $1000 for labor (plus parts which you should determine and purchase separately), comes to $125/hr! Pay more $$$, then just bend over since they would sure be doing it to you. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
2008RN Posted January 13, 2024 Author Posted January 13, 2024 15 hours ago, MAX Burner said: Concur 100%. That's why we did it ourselves - it took less than a half-day to configure the Tundra with wires, fuse, and Anderson plug/mount from engine compartment to hitch area. Took about the same time (maybe a bit less) for the OTT side of the equation. We used clam hull penetration hardware to introduce the cables into the area below the bathroom sink, underneath and in front of the head, under the forward dinette, to the aft dinette area where we mounted the DC/DC charger. Note: In bulk charge mode this particular charger kicks off some heat. We've been leaving the aft seat hatch off while towing to better circulate air around the cooling fins of the charger. There's a ton of YouTube videos of how some RV fabricators attach cooling fans. As described and photographed earlier, having two of these bad boys in close proximity will create some serious heat and auxiliary fans would definitely be helpful. As of this post, currently boondocking just south of Elephant Butte Lake SP waiting for the temps to rise above freezing before heading off to "The Q" - planning for a mid-afternoon arrival in the Sonoran Desert where its been above freezing temps for a few weeks now. FYI: OATs here last night dropped to 20F. Starting a 10pm last night with 96% SOC, ran the furnace and water heater all night and woke up at 5am to a 78% SOC. Not too bad.... I'm expecting to have 100% SOC by the time we hit Benson, AZ, with the DC/DC charger cranking +/-30A/14.4vDC into the BBs. Cheers! I never thought about mounting at 90 degrees. The was a great idea for mounting the charger using that little space. I also like hearing about the real world experience. I am hoping that my test for an hour in a closed compartment, will be relevant in the real world. If I do have problems with heat, I could try opening the deck plate to see if I could get little air flow in there. Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
MAX Burner Posted January 13, 2024 Posted January 13, 2024 (edited) 8 hours ago, 2008RN said: I never thought about mounting at 90 degrees. The was a great idea for mounting the charger using that little space. I also like hearing about the real world experience. I am hoping that my test for an hour in a closed compartment, will be relevant in the real world. If I do have problems with heat, I could try opening the deck plate to see if I could get little air flow in there. FYI: The Victron instructions for the unit recommend mounting as we did instead of flat - they also recommend at least an inch of clearance behind the cooling fins for obvious reasons. We used aluminum angle for the mount, easy peasy. Did the same for the Cerbo S GX unit which now resides under the forward hatch under the port-side rack. Yesterday from Elephant Butte SP, NM to Lordsburg, NM (about 160 miles) - the charger moved the departure SOC of 76% up to 100%, this was sooner than I had calculated. Heat build-up wasn't an issue as the IR temp gauge measured 105F on the cooling fins at an intermediate stop with engine running in park during bulk charge mode. Cool gear, Victron, IMO. Edited January 13, 2024 by MAX Burner Added data 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Ronbrink Posted January 13, 2024 Posted January 13, 2024 On 1/12/2024 at 8:37 AM, MAX Burner said: Anderson plug/mount from engine compartment to hitch area. Nice install! For general information to those that may not be aware, Anderson has an Environmental Boot that can be used at the bumper mount, as well as the DC-DC cable connect on the OTT; this ensures a waterproof connection when in use, and protection from dirt and moisture when disconnected. 2 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted January 13, 2024 Posted January 13, 2024 Ron: I very much like your setup for managing the two umbilical cables. Would you please share the cut sheet for the product you used to protect the cables? Thanks GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted January 14, 2024 Posted January 14, 2024 13 hours ago, Geronimo John said: Would you please share the cut sheet for the product you used to protect the cables? Spiral wrap hose protector, 3/4” ID for use on dual cable, .67” OD on single cable. Also used remnant sections to wrap propane hoses as routed along and over the frame up to the tank hoses. Unfortunately, the larger size in ‘black’ is currently unavailable on Amazon. I’ve used this type protector for decades on other trailers, as well as boats and Jeeps, and find this particular brand to be high quality and heavy duty. 1 2 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted January 14, 2024 Posted January 14, 2024 On 1/12/2024 at 11:11 PM, 2008RN said: I never thought about mounting at 90 degrees... When mounting flat, call it "floor-mounting" the heat sink is under the electronics of the charger, and since heat rises, a cooling fan would be necessary. When "wall mounting" the heat can escape naturally as heat rises. Given adequate ventilation space above, though hard to find in the Oliver basement, would eliminate the need for a fan. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
