Experience the latest innovation in travel trailers with Oliver’s 2022 model. Each year, we strive to enhance our trailers to meet your unique requirements, and this year is no exception. Our dedicated team invests countless hours in meticulous research to provide you with the finest options to elevate your travel experience. We leave every detail behind when catering to our valued customers. Discover the top-rated features handpicked by our team, designed to exceed your expectations.
1. Stainless Steel Convection Microwave
With the RV Stainless Steel Convection Microwave, you can bake brown or crisp foods using the convection function or the combination of convection and microwave oven. In addition, this RV Stainless Steel Convection Microwave has cooking power and additional heat settings that allow you to cook just about any food you want.
2. Memory Foam Mattress
Need an even better night’s sleep while you’re on the road? This comfortable latex foam mattress will be a replacement cushion for any of your needs. In addition, the pin core foam allows superior breathability. Talalay latex foam is a rubber-based product derived from the Hevea Brasiliensis tree. Unlike plastic-based bedding materials such as memory foam, Talalay Latex foam is biodegradable, uniquely healthy, naturally hypoallergenic, antimicrobial, and dust mite resistant, making this latex foam bedding the logical choice for allergy sufferers.
3. Front & Rear Propane Quick Connects
To enjoy your outdoor experiences, consider adding front and rear trailer connections for grills, torches, and propane campfires.
4. 4G Cell Phone Booster
The vehicle cell phone booster extends the cellular signal range to ensure you get better voice and data with fewer dropped calls, improved voice quality, and faster uploads and downloads. This booster is compatible with all US and Canadian wireless networks, such as Verizon, AT&T, Sprint, T-Mobile, US Cellular, Straight Talk, and more.
5. Nature’s Head Composting Toilet
This toilet replaces the standard Dometic toilet. It is self-contained and urine-diverting, and its waterless operation allows for ease of use for many applications. The Nature’s Head is lightweight, odorless, and compact, making it a perfect fit for your Ollie. In addition, the toilet, with its stainless-steel hardware, robust construction, and user-friendliness, has been designed to withstand the harshest conditions.
6. Solar Panels
– Four (4) 6V AGM Deep Cycle Batteries
– 2000 Watt Xantrex Freedom XC Inverter
(Legacy Elite II Option)
The minimal electrical draw of our LED lighting and other technologies will allow you to use your Ollie off-grid without needing a generator. Efficiency is dependent on sun exposure.
