Made in USA leaf springs
Thank You. I have time to decide. Our 2022 LE2 has the 5,200 lb. axle. I can do 4-leaf and add the 5th leaf later, or have the 4-5 leafs in the basement when we decide to sell. -
Steve and Mary replied to Mountainman198's topic in Mechanical & Technical Tips
We recently upgraded to the 5200 lb Dexter axles, purchased thru Alcan, and chose to use the 4 leaf Alcan springs to match the weight of the trailer. We also purchased the Dexter EZ flex and wet bolt kit from etrailer, replicating the stock setup, since we preferred to use step bolts. In addition, we replaced all four shocks with new factory style Monroe shock absorbers. We performed the installation ourselves. Our tire pressures are set at 45:psi which we monitor with our TST tire pressure monitor. We’ve had excellent results, the springs are noticeably firmer, both when towing and when set up for camping. We find that the ride is not unduly harsh and we haven’t had any issue with items coming loose or things falling off. Time will tell if the Monroe shocks will work well long term. We are very happy with the setup and our interactions with Alcan Spring. -
Responding to Wayfinder...wow, I thought I was geeky about solar vs loads... We went down the path of traditional resistance heaters and decided that the furnace was just more efficient at moving the heat around the basement than one single heater...especially 150 watt. Thus at first we added ducts to the street side weaving the ducts toward the shower and forcing air to the bath. This was a great improvement for when we are on propane. But when not, we are trying heat tracing.... The trick is to attach tracing to EVERY water line since tracing is poor at heating the air but great on contact. Tracing was attached with reflective metal tape every 10 inches to assure direct contact. One electrical outlet was added under the dinette seat nearest the bath to power two runs of tracing ; one to the bath and one to the rear. Access under the bath sink was required to wrap tracing around pipes in the bath. I also added insulation on the outer wall being careful not to obstruct the air flow between the hulls. Two other runs were powered from the ac outlet above the bed on the kitchen side by using a white extension cord neatly adhered to the wall to under the bed. Kitchen drawers were removed to access the water lines there. I found that there was an advantage to the four separate runs vs one or two longer runs as it enabled better coverage of the out side shower lines, the water pump area, and the water intake lines. The water tanks are not protected so it could be argued that this might not be fail safe in super cold temps. I have 3 Bluetooth thermometers that continuously record temps in the hull to help monitor. For context, the trailer homes in eastern WA and travels in Feb through Montana or Nevada where we encounter sub freezing temps... Also, a ball valve shut off was placed in the line ( under the sink) to the toilet as we do not use it with our composting toilet.
Great question. Such focus on weight alone makes NO allowance for the quality of the steel nor the quality of the heat tempering.
Confirming Sway Control with HD trucks in 2026
Galway Girl replied to Wayfinder's topic in Towing an Oliver
When we first bought our EII we had a F150 with a hitch rating that required load levelers and sway control for any tongue wt above 500lbs. So we bought the Anderson and used it for 2 years...but then we upgraded trucks. We now have an F350 Diesel 1 Ton Short Bed with a 3" receiver which has a dead weight rating of 2120lbs. We use a B&W Tow N Stow hitch and that's it. We've not had any sway or issues and it's dead simple to adjust if needed and hookup/unhook much easier than using either the Anderson Antisway (with Chains) or the types that have WDH Bars and Sway Bars. We don't need sway control as our truck also has braking sway control built in that states in the user manual that manual sway controls shouldn't be used. CS -
Mike and Carol replied to Wayfinder's topic in Towing an Oliver
We’ve got a 2020 Ram 2500 diesel. Tow on the ball, no sway control. Lots of miles and never an issue. Mike -
The later Will Prowse videos were done with battery intact
Exactly, I stopped reading at “Denis: The videos questioning the positive terminal design in our 100Ah battery are technically invalid, and here's exactly why.”
Wayfinder replied to Wayfinder's topic in Towing an Oliver
Thanks JD. Yeah, upon retirement from my current PITA job, I'm likely going to RV Tech school in January. That's the goal anyways. I talked to my advisor yesterday to get more info. She was very helpful from the NRVTA. I'll be trying for my VA benefits until then. My generation didn't just get benefits upon leaving the service, as it is happening right now, with the current generation (disgusting to me). The VA might pay for the entire school plus tools, if I'm broke enough. Saving well over $25K. If not, I'm going anyways. Anyways, I need way more payload. -
Mostly softball questions, boilerplate answers delivered by an experienced politician! Installation torque! 🤣 How about all those lose bolts interior to the casing?
jd1923 replied to Wayfinder's topic in Towing an Oliver
If you're buying a late model 2500 or 3500 truck, likely no need for the Andersen WDH. The Owner's Manual for our older Dodge 2500 states to use a WDH when tongue weight is > 500 LBS or trailer is > 5000 LBS. We certainly needed the Andersen when towing the Oliver with the OEM suspension. Without it the Oliver would porpoise up and down on a rolling highway, not comfortable. Once we upgraded to D52 axles and Alcan springs, we do not use the WDH, since the Oliver is now carrying its own weight. 😎 See what towing specs are and buy the right truck since you have this opportunity. In the year or so we had to use the Andersen, I likely cursed 100 4-letter words. What a pain! Thankfully, never again. -
As I will need to upgrade my truck soon to a 3/4 or 1-ton, to carry more parts & tools, I was confirming that most folks do not use any sway controller these days with the Elite II, when not using the Andersen WDH. I went through some old 2016 & 2019 threads, and that was the gist I got out of them. Thanks,
We went 5-leaf since Alcan designed it this way specifically for the Oliver. They installed a few 4-leaf springs only due to Oliver owner requests. I would guess over 95% of us have installed the standard 5-leaf system. I've had to go over a lot of speed bumps lately. My truck suspension, being so tight, bangs hard over speed bumps, but the Oliver suspension glides over them so nicely! Looking through the sideview mirror, you can see each tire articulate up and down without affecting the other axle, while the hull does not budge an inch! I should buy Alcan leaf springs for the rear of our tow vehicle! 😎 We always tow with a dog bowl half full of water. The water stays put, and never had a drawer open. We did have items jostled in the Attic and hanging clothes fall in the closet once in the first few miles. Once I worked the first required torquing of wet and U-bolts, we never had another issue.
I subscribed to Mike Sokol's report/newsletter after you mentioned him. Looking forward to seeing Mike's results after his experiments with a BB battery.
@Jls Your question got me thinking. I do that once a month. 😉 How do you place your heat trace within the hull? I might like your idea over mine, but it was fun to research and geek out about. My idea was, at first - WARNING: Lots of bla bla from AI research 😞 I might consider using 12v Ceramic heater(s)? While in my driveway in GA on the coldest of days, I use two of those silver-looking clamp-on utility lamps with 60 watt bulbs in them. On lamp next to the water pump under bunk, and one under dinette facing the front of the camper, or towards the black tank area of bathroom. I've not yet had any issues in the camper. I might consider, and would be geeky-fun to try, using a Kat's Heaters Ceramic Interior Heater with Fan - 300 Watt - 12V, Part Number: KH37500 from eTrailer.com, or something similar. These have a 150w and 300w settings. I asked my uncle AI (Claude) for output estimates since I have four fairly new Lifetime 6v AGMs in my old trailer, 220 AH usable. How long would one of those heaters last on both a sunny day and with no sun. I have 380 watts of solar. Down below, I also asked: Compared to a 60watt incandescent bulb plugged into AC, what kind of heat might that put out? Answer: A 60W incandescent bulb is, in a very real sense, mostly a heat generator that also produces light — about 95% of its energy becomes heat, only ~5% becomes visible light. BLUF: The Takeaway The 150W heater puts out about 2.5× more heat than a 60W bulb The 300W heater puts out about 5× more heat than a 60W bulb A 60W bulb is roughly equivalent to a very modest hand warmer in terms of room heating ability This are some non-verified results: 4 × 220Ah 6V Lifeline AGMs Config: 2S/2P → 12V, 440Ah total 50% SOC = 220Ah usable 60W Incandescent Bulb as a Heater Effective heat output: ~57W of actual heat BTU/hr: ~195 BTU/hr The glass surface can reach 200–260°C (roughly 400–500°F) — hot enough to burn skin on contact The air warming effect in a room is modest, but in a small enclosed space (like a chicken coop or a closet), people have actually used bulbs as supplemental heat 150W Heater Heat output: ~512 BTU/hr Air temperature near the outlet: roughly 50–65°C (120–150°F) Practical use: Takes the chill off a very small enclosed space — great for a car cabin, a small tent, or under a desk. It won't meaningfully heat a room. Space it can handle: ~15–25 sq ft (roughly the interior of a car) 300W Heater Heat output: ~1,024 BTU/hr Air temperature near the outlet: roughly 60–80°C (140–175°F) Practical use: Can comfortably warm a car interior or a small enclosed cabin/van space. Still not enough for a full room. Space it can handle: ~25–50 sq ft Important Notes 12V power source matters: A 300W heater draws 25 amps at 12V — this is a heavy load. Make sure your battery, wiring, and fuse can handle it. Insulation is everything: In a well-insulated camper, a 300W heater can get quite cozy. In a poorly insulated space, even 300W will struggle. These heaters are best thought of as comfort heaters, not primary heating solutions for large spaces. Current Draw Heater Watts Amps @ 12V 150W 150W 12.5A 300W 300W 25A Runtime to 50% SOC Heater Usable Ah Draw Raw Math Real-World Est. 150W 200Ah 12.5A ~16 hrs ~13–14 hrs 300W 200Ah 25A ~8 hrs ~6.5–7 hrs The real-world figure is lower due to: Peukert effect — AGMs lose some effective capacity under sustained load Inverter/wiring losses if applicable (~5–10%) Cold temps — AGM capacity drops in cold weather, which is exactly when you need heat most 🙃 Solar Reality on a Cold Sunny Day 380W rated panels in cold, clear conditions: roughly 75–85% output = ~285–320W realistic Flat roof-mounted panels on a highway aren't perfectly angled to the sun, but clear sky and cool temps largely compensate Call it a conservative ~285W average while moving Net Power Balance with Solar Heater Solar In Heater Draw Other Loads (~20W) Net 150W ~285W 150W 20W +115W (charging!) 300W ~285W 300W 20W ~-35W (tiny draw) What using Solar Means Practically 150W heater — you're essentially running it completely free, and still slowly charging your bank while driving. Nearly a wash even on a cloudier day. 300W heater — virtually break-even. A slight net drain, but so small it's almost negligible. On a really bright stretch you'll be net positive, on a shadier stretch slightly negative. For Protecting Water Lines Specifically This is a low-load task — you don't need to heat the whole camper, just keep the hull above freezing. A 150W heater on low (if it has settings) or even a small 40–60W pipe heating cable would do the job, meaning your solar would be comfortably net positive all day. Bottom Line With 380W of solar on a cold sunny travel day, a 150W heater is essentially free to run and your batteries will likely end the drive in better shape than they started. The 300W is break-even. This is exactly the use case solar excels at — offsetting a modest continuous load during daylight hours.
🤣 Love it, quite resourceful! If I had the luxury of ordering a 2027 Oliver, I would order it without awnings on either side! 😎 It would be aerodynamic, a thing of beauty. If our entry-side awning was to fail, I would remove it and do MORE fiberglass repair. I would also NOT order any rooftop antennas, cameras, or other accessories like Zamp ports where OTT would drill into the fiberglass (see pic, not pretty installations). I would also delete most interior screens, like the tank level screen that is rarely accurate. We stopped looking at ours years ago. You'll soon know how many days the fresh tank will last and the waste tanks will fill. The link below is something you should consider, and if yours would be a Girard awning, I would search this forum for keyword Girard, as I have read many posts about Girard awnings closing in the lightest of winds, switch and battery failures or opening on their own! @Chrisharon it's very smart thinking a year ahead on your order, and my apologies for providing much more than you asked. Yes IMO, an awning-less Oliver would truly be a thing of beauty! 😎
We have the 3.5K axels I put the 5 leaf springs on the Oli. I have almost 11K miles on them. The first couple of days (750 miles) seemed a little rougher then they mellowed out. I do go on gravel, and some of the 2 lane roads in the nation are as bad or worst than gravel roads. I just got done doing a lub on the wet bolts and checking everything out. All seems fine. The Oli weighs about 6500 pounds when loaded. I haven't notice any problems in the interior, it was worse with the original springs. The trailer stays pretty mellow with movements of an inch or two after uneven pavement. Where it used to bob and weave like a drunken sailor before making it harder to control. After the leafs no control issues. I think you would be fine either way.
I would rather have a great product with no warranty than a fair product with a great warranty. The time and PITA factor in obtaining warranty work/recompense is ..., well, a PITA.
Galway Girl replied to Mountainman198's topic in Mechanical & Technical Tips
We have 3.5K Axles and used 4 leaf Alcan, had them do the install, they gave me the 5th leaf to carry with me if we wanted to install it later. After 5k miles with 4 leaves we're just fine. That said if you have the 5K axles on your trailer, then most folks use the 5 leaf version to match the axle rating. -
I wish he was testing several off the shelf batteries and not just the one provided by Battleborn themselves. There are also more issues in question than just the terminal overheating problem and I hope he addresses each one of those too.
Here is the Mike Sokol Battleborn interview with Battleborn. I can't figure out how to make this viewable to everyone. For Facebook members, you can open the post before this one. Mike Sokol interviews Denis Phares from Battle Born Batteries on lithium battery terminal overheating! “I reached out to Dragonfly Energy (Maker of Battle Born Batteries) a few months ago after a number of my readers at RVelectricity.SubStack.com asked me to investigate if there was a design flaw with Battle Born Batteries that could cause them to overheat in their RVs. After a few in-depth conversations with Dragonfly Energy’s Founder and CEO, Dr. Denis Phares, I asked for a written interview. Following are my unedited questions and Battle Born’s answers.” - Mike Sokol Mike Sokol: Exactly who is Dragonfly Energy and when did they start building Battle Born batteries? Denis Phares: Dragonfly Energy is a U.S.-based energy storage technology company headquartered in Reno, Nevada. We design and manufacture lithium iron phosphate battery systems for applications including RV, marine, off-grid, and commercial use. Battle Born Batteries is our flagship brand, focused on deep-cycle lithium batteries and complete power systems for real-world applications. We brought our first deep-cycle LiFePO4 battery products to market in 2014. Mike: How long has this core battery architecture been in use, and what does its track record look like across real-world deployments? Denis: The core battery architecture for the 100Ah models was developed and validated between 2014 and 2017, with the product first reaching market in 2016. Since then, it’s been deployed at large scale across RV, marine, off-grid systems and in commercial applications. That long-term field use, combined with consistently low warranty rates, gives us a clear, data- backed understanding of how the design performs across a wide range of real-world conditions, environments, and installation types. At this point, the performance isn’t theoretical, it’s based on years of observed behavior in the field. The design has also been repeatedly validated through third-party certification testing. This includes achieving the ETL mark by Intertek, where the batteries were tested to UL 2054 standards, among others. The most stringent electrical test requires the battery to survive a short circuit where the primary protection mechanism is faulted. In our case, this amounted to completely bypassing the Battery Management System (BMS). Our 12V 100Ah (BB10012) model in particular is among the most extensively tested and certified deep-cycle LiFePO4 batteries in its class. Taken together, that combination of certification testing and long-term field data provides a consistent and well- understood picture of how the products perform. They perform safely and as designed. Mike: How many Battle Born batteries with this design architecture are currently in the field? Denis: Based on our sales information, there are over 400,000 Battle Born Batteries in the field today across a wide range of models and applications. A significant portion of that installed base is our 12V 100Ah batteries, which are the most widely deployed configuration. That scale spans everything from RV and marine systems to full-time off-grid and commercial use. Mike: Since there’s approximately 400,000 Battle Born batteries in use, have there been any large design changes based on user feedback or returns? Denis: There have been no fundamental changes to the core battery architecture. That consistency is intentional. The design was validated through extensive internal testing and third-party certification, and the long-term field data has remained consistent with those results. Maintaining these certifications requires that any component changes be relisted and revalidated through third-party testing, ensuring continued compliance with the same safety standards. Mike: At a high level, what layers of protection are built into Battle Born lithium batteries, and how do they work together to assure maximum safety? Denis: Battle Born Batteries are designed with multiple layers of protection that work together as a system. At the chemistry level, we use lithium iron phosphate (LiFePO4), which is inherently more stable and resistant to thermal runaway than other lithium chemistries. At the electrical level, the battery management system actively protects against overcharge, over-discharge, overcurrent, short circuit, and temperature extremes. At the mechanical level, the batteries use a flame-retardant enclosure and cylindrical cells, a format known for mechanical durability, efficient heat dissipation, and integrated pressure relief features, along with physical spacing that enables passive thermal management. Each of these layers is independently effective, and together they provide a system designed to prevent conditions from escalating. Mike: Why does that internal fail-safe system exist in your batteries in the first place? Denis: The internal fail-safe exists because of how these batteries are evaluated and used in real-world RV OEM applications. To be used in RV OEM installations, batteries must meet safety expectations aligned with RVIA standards, which rely on certifications like UL 2054. That standard includes the single-fault short-circuit test, where the battery is subjected to a direct short with no electronic protection active and must not produce fire. This testing is repeated across multiple units to ensure consistent results. The battery architecture was designed with that requirement in mind. In addition to the battery management system, the design includes a passive, built-in fail-safe within the positive terminal inside the battery pack. Under normal operation, it conducts power with very low resistance. Under sustained fault conditions, it transitions to a high-resistance state and stops current flow. In practical terms, this creates a defined point where current can be interrupted if conditions become unsafe. That behavior has been validated through both certification testing and long-term field data, where the outcome is consistent: the battery stops delivering power rather than allowing the condition to escalate. Mike: When people notice heat at or near the battery terminals, what’s usually going on electrically—and how is that different from an internal failure in a battery causing the problem itself? Denis: In high-current DC systems like RV and off-grid applications, heat at or near battery terminals is almost always related to resistance in the external electrical system, not an internal battery issue. Common causes include loose connections, improper torque, undersized wiring, or resistance elsewhere in the system such as bus bars, disconnects, or inverter connections. When current flows through a high-resistance point, it generates heat. Heat can also travel along conductors, so it may appear to originate at the battery even when the source is elsewhere in the system. The battery is designed to operate normally under proper installation conditions. If a sustained fault develops, such as prolonged heat at a connection point, the internal fail-safe at the positive terminal responds by increasing resistance and interrupting current. So, in most cases, what people are seeing is not originating within the battery itself, but the battery responding to conditions elsewhere in the system in a controlled way, as designed. Mike: There’s been a number of YouTube videos showing overheating of Battle Born batteries. Is that a normal occurrence with an intact battery, or has disassembling the battery for demonstration videos actually created the overheating condition? Denis: The videos questioning the positive terminal design in our 100Ah battery are technically invalid, and here's exactly why. The positive terminal in a Battle Born 100Ah battery is a sealed, structurally constrained assembly. The brass terminal is epoxy-bonded to the lid, which holds the internal components under fixed compression. That's not incidental to the design, it's central to it. Under a sustained thermal fault condition, the polymer layer softens, reducing contact pressure at the metal interfaces. As that pressure collapses, current concentrates at microscopic contact points, causing rapid localized heating. This accelerates the formation of an insulating aluminum oxide layer, which quickly drives the terminal into a high-resistance state and stops current flow. The battery shuts down. No fire, no escalation. When you remove the lid to film what's happening, you've eliminated the structural constraint the mechanism depends on. The terminal is now free to move. Cable torque drives continuous motion between the contacts, which keeps exposing fresh metal surface at the contacts, preventing the protective oxide from ever completing. The result is sustained arcing that looks alarming on video, but is entirely a product of the disassembly, not how the intact battery behaves. In other words, opening the battery to observe the safety mechanism creates a measurement artifact. An intact battery in the same fault condition shuts down effectively. The data, science, and more than a decade of field use consistently support that. Mike: How many battery terminal overheating complaints have you had at your help desk, and what percentage of your help desk calls are from terminal overheating? Denis: Relying on data from 100Ah batteries evaluated through our warranty process since early 2022, approximately 0.2% of units across the installed base have exhibited elevated resistance at the positive terminal. These cases do not appear to be the result of an internal battery failure. Based on our examination of the returned batteries, they are overwhelmingly associated with external factors such as improper installation, poor connections, or system conditions that create resistance and heat at the connection point. Importantly, these events have not resulted in any outcomes that would indicate a battery safety issue and are typically resolved through straightforward troubleshooting or warranty support. We have also closely monitored support activity following the recent videos. While they prompted increased customer inquiries and inspections, we did not observe any increase in or change in type of warranty claims. Terminal-related inquiries represent a small portion of overall support volume. The majority of help desk interactions are related to system setup, charging, or integration, not battery safety concerns. Mike: Have you separated out any battery terminal overheating failures into DIY and Dealer installations? If so, what are the numbers and percentages? Denis: We do not categorize every case with a formal DIY versus dealer label, but we do analyze warranty data across OEM and non-OEM installations, and the pattern is consistent. In OEM installations, where torque specifications and conductor sizing are standardized, cutoff events are extremely rare. The cases we do observe are overwhelmingly concentrated in non-OEM installations, where factors such as connection quality, loose terminations, undersized cables, or improper torque can introduce resistance at the terminal interface. This is not a generalization about DIY installations. Many are done very well. The consistent observation is that installation quality and system conditions are the primary drivers of these events, rather than an issue within the battery itself. Mike: From an installation perspective, how important are best wiring practices, proper torque of terminations, and correct conductor size compared to internal construction the battery itself? Denis: They are critical. In high-current DC systems, connection quality, proper torque, and correct conductor sizing are just as important as the battery itself. Even a small amount of resistance at a connection point can generate significant heat under load. If connections are loose, undersized, or improperly installed, heat will develop regardless of the battery being used. Mike: Do you train your dealers on best practices for Battle Born battery installations? Denis: Yes. Education has been a core part of our approach from early on, and we provide ongoing training and support to dealers and installers on best practices for system design and battery installation, including wiring, connection methods, and overall system integration. This includes technical documentation, direct support from our U.S.-based team, and formal training programs, including RVTIA Level certification courses. The goal is to provide the support to help ensure installations are done correctly and consistently. Mike: How does Battle Born’s Nevada-based technical support team handle questions about battery design and safety, especially when the issue may involve the broader electrical system? Denis: Our Nevada-based technical support team takes a system-level approach. When customers reach out with questions, we don’t just look at the battery in isolation. We work through the full electrical system, including wiring, connections, charging sources, and loads, to identify where issues may be coming from. That often means helping customers troubleshoot installation-related factors such as connection quality, conductor sizing, or integration with other components in the system. The goal is to provide clear, practical guidance to help ensure the entire system is operating safely and as intended. Mike: How does Battle Born’s technical support team adapt as new questions or concerns trend within the RV and off-grid community over time? Denis: Our technical support team has been doing this for a long time, and they’re not just repeating information. They’re actively problem-solving. We’ve been supporting lithium battery systems in these applications for over a decade, so the team has extensive experience working through a wide range of system behaviors, including more complex or less common configurations. As new questions or trends emerge, the team works directly with customers to identify root causes and practical solutions. Mike: For customers worried about internal battery issues, what can they realistically observe, and what should prompt them to reach out for Battle Born support instead of guessing or watching a YouTube video? Denis: In most cases, customers are not going to observe an internal battery issue directly. What they’re seeing are system-level symptoms. Things like heat at a connection point, intermittent performance, or unexpected behavior are typically related to the broader electrical system, not the battery itself, and are not unique to any one brand but common considerations in any battery-based system. If anything seems abnormal or persistent, such as excessive heat or loss of performance, the best next step is to reach out to our technical support team rather than trying to diagnose it based on assumptions or online videos. Mike: If a customer notices overheating at battery terminals or wiring, intermittent performance such as loss of capacity, or anything that doesn’t seem right in their electrical system, what’s the safest next step and who should they contact?” Denis: If something doesn’t seem right, the safest first step is to stop using the system and disconnect power if it can be done safely. From there, they should contact our technical support team so we can help diagnose the issue and guide next steps. END Mike Sokol from RVelectricity.com and the NoShockZone is an independent electrical safety instructor and consultant working out of his FunkWorks Lab in Funkstown, Maryland where he tests a variety of electrical products and systems for the RV industry. As many of you know, Mike’s been producing electrical safety and use articles for RV consumers and technicians over the last 16 years. Sokol_Bb_Interview_Substack.pdf
https://www.facebook.com/share/p/1ABG97SjiK/https://www.facebook.com/share/p/1ABG97SjiK/
I have ordered Alcan Springs and will need to decide whether to install as 5-leaf or 4-leaf. I have a truck service place that will do the work. Their recommendation is to install 4-leaf based on trailer weight. Without going through the entire thread, are there any owners that went Alcan 4-leaf? We don't plan on driving rough gravel roads. That got done pre-Oliver. -
taylor.coyote started following 2nd Awning?
We purchased a used trailer in 2019 that has two awnings. We spend a lot of time in the remote high deserts boon-docking in the western states. Over the last six years we have yet to use the awning on the back side of the trailer. The good news: we have been able to use the second awning for spare parts on a couple of occations to keep our front awning operational. Based on our experience, we would not recommend investing in a secound awning.
We love our second awning and use it all the time when camping in Connecticut. We do a lot of dry camping at the beach, where there's plenty of sun for our solar. I often park the trailer oriented north/south and we put one awning out in the morning, then the other out in the afternoon when the sun crosses over the trailer. Gives us shade to sit in all day and keeps the trailer cooler inside. If you plan dry camping frequently in sunny, open spaces, even up north, it might be worth it for you.
