  1. Today
  2. Yes Sir, I'm with you on this one! šŸ˜‚ In 2019, I was outfitting a Bigfoot Class-C with solar, inverter (it had none) and new batteries. I looked at Battleborn at the time and it would have been $3,500 for 300 Ah ($11.67/Ah). I went with 3 AGM 105 Ah batteries for $800 ($2.54/Ah, $5/Ah usable). It was a different day. Five years later (2024) I went with 600 Ah Epoch for $1,800 ($3/Ah). This was certainly worth it! Price has gone up some since. Last fall I added another for a total 900 Ah, all tucked into that Oliver battery bay (removed the tray to fit). šŸ˜Ž If you need something more economical, check out the new LiTime 320 for $770 ($2.40/Ah), or get a 2-pack, 640 Ah for $1,494 (2.33/Ah)! Two won't fit in the tray, but 2 Epoch 300s do for quite a bit more $$$. Search for keywords Epoch or Litime to see several owner installations. LiTime batteries have been installed in a few Olivers. These appear to be good batteries at a very good price. https://www.litime.com/products/12v-320ah-mini-bluetooth-lithium-battery?variant=46648243912924
  3. You're cracking me up, Scotty! 🤣 I swear when we had the OEM suspension, every time I stopped for fuel the top of the Oliver would pendulum 1-2 FT left and right, again and again. BTW, our shocks are under-engineered too. I've been looking for a stronger substitute but so far the specs are not lining up. The Bulldogs are likely somewhat better, but not heavier in rebound specs.
  4. Only because of time! The older hulls have more miles, more failed leaf springs. They are the same spring, but on a heavier axle. When I replaced ours last year, the originals were still nicely arced. Steel from China is likely not getting any better.
  5. Past 2030, 2035 at the earliest I’d estimate. And then there’s a long rollout and it’ll be initially expensive. Before that other wet chemistries are coming out, namely LMR (Lithium Magnesium Rich) prismatic batteries. These will be in GM EV trucks in 2027. They offer higher energy density and equal cost to phosphate chemistry. But the kind of batteries we can get for trailers will be wet LIPO for at least a decade. Anyhow, in these sizes (a few kWh) I don’t think there’s any point in waiting, dry chemistries won’t give you any real benefit. I upgraded to the top battery, which might seem odd given the basically unlimited power available in the truck. ā€œPay once cry onceā€, and with electric cooking I think it was still a good choice. And - best part, it’s a more sophisticated battery with built in heating and especially, and on off switch. I don’t think the other options have that? When I had some kerfuffle with my Xantrex the Oliver tech kept telling me to start wrenching on the battery terminals. Took me several tries to get across that there’s a switch on it šŸ˜…
  6. Well I was originally making the point that WD only comes from properly tensioned chains. My question is why do OTT techs install and recommend taut chains. At any rate there are also new options in trucks. My Sierra EV is interesting, despite the very heavy battery giving a total truck weight of 9k (which is a benefit as the truck weighs more than the trailer), but it still has a tongue max of 1k, and a payload capacity of over 1700 lbs. GM requires a WD hitch over 7k lbs and recommends it below that. So technically I don’t need WD, and as the truck has 785 HP and 885 ft-lb of electric torque it has full towing authority. On the leaf springs, we were discussing this on another thread. In my first 4k of towing I didn’t see an ounce of roll bounce, and little porpoising. Perhaps that’ll change as they age, or maybe not, but I’m still curious about these differences.
  7. Yesterday
  8. That's a smart move, John, I'm glad that you're replacing them! I was assured by the Oliver guys at the last rally that I didn't have to worry about my springs, 2023 build with D52 axles, because there were no problems with newer trailers with D52 axles. Well..... I have a broken spring set, passenger rear, with the remaining sets flattening. Needless to say I'm not a 'happy camper' regarding this. I have replacements from Alcan but haven't had time or decent weather to do the repair as yet.
  9. You can follow the 80 PSI MAX spec on the Load Range E LT tire, the 65 PSI rating OTT prints on their DOT label (they used to print 80), or the PSI recommended by the tire manufacturer, based on actual GTW on their load/pressure tables. I/we, most of us, follow the latter. I use any PSI over 45, less than 50, to set them all equal in that range. These numbers allow for 7,800 to 8,360 LBS GTW. On long trips, we carry max 6,600 LBS, so in this range we have spec plus a 20% safety margin. If you run at 65 or 80 PSI, you will cause internal damage to your Oliver. Regardless of brand, LT 225/75R16 tires will all be very close to the numbers you see here. I understand new hulls to have 15" wheels, so get a table for your size. I must have posted this table 6 times now...
  10. Unaware of any issues on the 5200 lb. Axels since Oliver switched to the 5200 lb. axels. After 5 years we are replacing shocks and having Alcan 4-leaf springs installed. The place that services our suspension said they noticed a slight flattening of the springs. The Alcans just arrived.
  11. Usually the 1/2 Ton Trucks are limited by the 'dead weight" or weight carrying capability. The receiver unit on the truck you have should have a sticker like this one (from a 2018 F150) either on the actual receiver hitch or on the door frame. Notice that on this unit the max Tongue weight capacity is 500LB. (Weight carrying the case where you don't have a WDH and is essentially the dead weight from the trailer tongue down on the ball.) An Elite II tongue wt when loaded is easily above this 500lbs, and requires a weight distribution hitch to be safe and legal. In this F150 case, once a weight distribution hitch is applied, the F150 can then handle up to 1220 Lbs of direct tongue weight. The towing guides for most vehicles state the method for determining how much adjustment is needed from the WDH. Most have you: 1) Measure the unloaded truck's front wheel well height through the center of the front wheel. 2) Measure the wheel well height after loading the unit and attaching the trailer. In most cases the amount of weight distribution needed is set to bring the front end back down by at least 1/2 of the total difference in those two measured heights. Example: Unloaded measures 37" Loaded measures 41" (4' total rise). Apply enough WDH force to lower that front measurement by least 2" ....or 39" when loaded. Each manufacturers towing guide states specifics by vehicle make and model. CS
  12. Yes it’s D52 rated at 3500 Agree with the idea of a better constructed spring since the Dexters can fail, just wondering about changing the stiffness. A suspension is a frequency damper, shocks for lowband (to sub hertz) and springs plus ez flex puck maybe midband and higher. Pushing stiffness (higher weight rating) would increase the low cut off frequency, thus losing damping Again this isn’t my field but I think this is what we have. The other factor is tire pressure, seems like people here tend to ride low for a less bump. Indeed here, that lowers the cutoff frequency. I prefer running at spec for efficiency and I have a hard time ignoring ratings. Possibly people having more issues are running softer pressures? Just a thought
  13. Yes.... Given a 3/4 ton truck ditch the Anderson. Have to mention for folks using a 1/2 ton that you need to read your manual very carefully. Most half tons will require a WDH if the trailer weight is over 5k lbs. Hopefully no one finds themselves on the wrong end of a lawyer trying to take their house, but if you do... you'll be glad you had the WDH installed. Quack Quack! Oh no.. wait... I got the Alcan springs. Scotty
  14. I get that, but the axels should be 5,200 on all Oliver's starting in 2022. Maybe I misread what he said. He said he has D35 axels, when it should be D52, rated at 3,500.
  15. When 2x 1750 leaf springs are installed on D52 axles, the assembly is rated at 3500 LBS.
  16. The axel weight doesn't seem right. In 2022 Oliver switched to the D52 (5,200 lb), rated at 3,500 lbs due to the 4-leaf spring. Why would Oliver switch back to 3,500 lbs? I'm not sure you are providing the correct information. The older trailers were 3,500 lbs. and these trailers are experiencing the spring breaking. 5,200 axels have been installed since 2022.
  17. Your experiences may be different after more miles on your new hull. Ours waddled greatly and porpoised when not using the Andersen WDH. Awesome towing with the 5-leaf Alcans! šŸ˜Ž Same leaf springs, given the D35 rating. Many Dexter 1750 LB leaf springs have failed with time. Keep an eye on the arc of your main leaf springs! When one starts to flatten, replace them.
  18. I have a new 2026 with the D35 3ā€ axels, EZ everything and the 072-042 1750 springs. Considering whether going for a heavier spring makes sense now for these reasons. In 4k of towing so far I sensed no issues, no roll at all, no porpoising except on bad roads where you can’t avoid it, and a smooth tow. I previously had researched Bigfoots quite a bit before settling on Oliver. Over there an owner was looking to upgrade to a heavier suspension but was advised against it by the Bigfoot company owner (forget his name now). Reason being ā€œthat axel would beat the hell out of the trailerā€. This makes sense and jives with the experience above. A higher rating will necessarily be a stiffer suspension. This will have a comparable narrow band frequency response to vibrations, relative to a less stiff system I play as an engineer by day and while the natural tendency is to over engineer, when it comes to mechanical design that’s often not a good idea, but I’m not an expert in suspensions. Anyhow I’m wondering whether the stiffer springs are a good idea here. Older Oliver’s it might be good, but not so sure now.
  19. Reading more carefully, ā€œexcept perhaps the Pacific coast.ā€ We won’t even cross that state line in what used to be such a beautiful state. AZ is full of EVs and there’s enough ex-Californian issues here in politics, traffic on our roads… If I still had a commute, I’d buy a Tesla S (sorry, last time I purchased a GM product was so long, long ago)! And there’s no such thing as FREE! I prefer to use the term included. Shipping is included in the asking price and a charge station at work is a benefit included in your employment. Your company pays utilities. You can argue the life of systems. BTW, at 180K our Cummins is just broke-in full efficiency! I believe @Rivernerd in his $50K quote! If that investment was to save $200/mo, if that, it would take a 21 year payback period. We’ll keep paying our electric monthly. If we were a young couple, growing up with the technology of the day, there would be other considerations. Heck, $50K is a good cash price for a used Oliver! šŸ˜Ž
  20. I think I will still wait until the solid state Lithium systems become commonly available. Those look seriously capable.
  21. Sorry those are tired old myths. You know ICE engines lose efficiency as they age? Everything loses efficiency, including us meat engines šŸ˜…The source of the myth comes from the old Leaf batteries. They just air cooled those things. So you'd drive on the freeway (heat the battery), stop for a charge (no airflow), and fast charge (heat the battery). It hammered them, and they aged very quickly. All modern EV's have HVAC water cooled systems that carefully manage the temps, and the batteries last forever. So much in fact they have second lives, when people are done with their cars in ten years they repurpose the batteries for grid use. Same thing with solar panels. Also these generally don't use LiFePO4 chemistries, they're several generations beyond now and have greater durability and resilience. Point being, yes they do lose some performance but so the heck what? Look if a 10% or even 20% performance loss is a problem, well better batteries/trucks/panels are now available. And for panels, the cost is almost all in the labor - sound familiar? That was the lions share of the bill, maybe you've seen this if you ever worked with an electrician. If I ever wanted to replace my panels it would be a simple rooftop swap and wouldn't cost much. And that all obscures the fact that even if I decided to replace these panels after 20 years of free power generation, well I still got X years of printing money.
  22. Sorry not sure what you're saying, out West the charging is an issue? I live in California, it's the EV capital of the US and the highest density of charging. The one and only exception is Hwy 1 North of SF, but as my truck loves the windy coastal 'highway' and range isn't an issue. There's plenty of Level 1 charging but no DC until you get to the bigger towns up north. Yes it does actually. I did a full accounting including the time value of money, of course the upfront costs and other factors, it paid for itself very quickly. It's due to a couple of factors, one is electricity cost is ruinously expensive in California like everything else. Two is the generous NEM1 policy which lets me use the grid as a battery. True up is once a year where I pay something around zero, or get a small check in return. Three is peak shaving, where they really get you is between 4PM-9PM (the 'duck curve'), so I had my grid designed to take advantage of that time, and we 'power down'. So I earn at peak rates, and use at off peak rates - make sense? Finally you have to look at the bigger picture. We each have an energy budget, NG, electricity and transportation. ICE drivers are forced to have those three buckets, but I have one bucket. I converted my house to electric (e.g. induction cooktop). So now with one energy bucket that I can be an energy provider for, the economics seriously changes. How much do you pay for gas on a yearly basis? For me that's bundled in to that single bucket. Further with free charging, that also feeds into my energy bucket. I'm fortunate to have a DC fast charger at work for free. So I pull in some 160 kWh about on a bi-weekly basis. Since this is fungible, meaning free charging is the same as generating it via solar, that drives the cost down. And free charging is everywhere, half the time we charged at campgrounds, or public service charging elsewhere (e.g. rest stops). Technical discussion but no, absolutely I can show you the data that indeed my system is paid off.
  23. A little confusing but they have two numbers for the 22oz spray versus gallon. Here's the current products and numbers They had these for sale at the factory service as mentioned, Here's a factory tour where he talks about Durawax (time stamped) Was at the trailer yesterday and checked the instructions on the Fast Clean and Shine (921/923). This is meant to clean a previously treated surface without removing the treatment. So I think the idea is to wax it, then clean up using this so as to not remove the wax base layer. That's an interesting idea, combine the wax plus the cleaner. There's a bunch of products that take this kind of approach of a simple one step clean & wax. I like futzing so I think I'll do a wax, then use the FC for cleaning thereafter. Being interior it shouldn't need much reapplication of the wax.
  24. @Boudicca908 921 is 22 oz bottle, 923 is 1 gallon jug https://www.duragloss.com/wp-content/uploads/2021/07/921-DURAGLOSS-FAST-CLEAN-SHINE.pdf 951 is 22 ounce bottle, 952 is 1 gallon jug https://www.duragloss.com/wp-content/uploads/2021/07/951-DURAGLOSS-AQUAWAX-SPRAY-WAX.pdf
  25. Custom Automatic Leveling for the Oliver's Barker Jacks Part 3: I skipped over a lot of detail to keep this project interesting, and it’s probably still too much information. But some might be interested to hear about some of the background work that was involved. After the test board phase was complete, and everything was working well on the bench, the system was installed in the trailer for real-life testing. This was an anxious time because it had only been tested with simulated current, and I had no idea how it would react under real current conditions. Things went south immediately! I started testing with rear jacks because they were easier to wire and much more complex than the tongue jack. I didn’t want to run the tongue jack wires if the whole project could end up in the trash bin! I came up with a test procedure to verify each function in different scenarios of operation, and that required manual jack operation. That’s when the problems started! I was blowing the 30 amp jack fuses and couldn’t figure out why. I first focused on the H-bridge relay wiring as the problem. Then I suspected that the ESP-32 or driver outputs were miss-wired during transition from the test board. They had been soldered together one wire at a time under magnification, and back tracing the bundled wires was a nightmare. I couldn’t find the problem and came close to scrapping the whole project. I was so confident in the design, and overly focused on wiring, that I completely overlooked the obvious. There was a major flaw in the way the auto-leveling system was isolated from the manual jack switches. I had used a high-amperage relay that closed to a common ground only when the H-bridge relays triggered, which broke the short circuit path when the manual switches were used. However, I hadn't considered that the pole-reversing function of the switches created a different ground path through the hot side of the leveling system. The solution required major re-work, replacing the single ground isolation relay with six 30/40 amp relays that isolate the manual switches from both the ground and hot side. Although there were two spare Darlington driver channels capable of handling two relays each, there weren't enough channels for six new relays and a second driver was added. The system now runs 12 relays from 9 driver channels — six H-bridge relays and six isolation relays, two per jack. All the components were installed in a 12ā€ project box that was limited in size by the 3-D printer capacity. So the relays were stacked 2 high on a stepped base to save space, and a elevated terminal block helped with wire congestion. I was able to mount the current sensors directly on the PCB with the ESP-32 and other modules. It’s tight, but nicely compact too! The switches for the leveling system are mounted on a 3-D printed control panel inside the outside storage garage. The panel includes flush to the surface push-buttons to safeguard against accidental activation, one for ā€œAuto Levelingā€ and the other for ā€œRetraction.ā€ There is a master On/Off switch, status LED, and a Piezo Electric buzzer for the status tones. The entire panel is also recessed to protect it from cargo. The system can be shut down with the On/Off switch, or by re-pressing either momentary switch. The systems parasite draw is near zero when on, but it’s normally off when not in use. The existing freshwater control system was incorporated into the lower part of the control panel due to space constraints. It has a 4-way water pump switch for the outdoor shower, with indicator LED. There is also a 4-position, 6-contact, rotary switch that controls motorized valves for the four freshwater configurations; Normal, Freshwater Tank Drain, Boondocking, and Winterizing. The LED indicators show configurations other than normal. A printed weather proof hood was used for wire penetration into the tongue jack head, and a terminal board was used to splice into the rear jack wiring. This was a useful addition for quick disconnecting and troubleshooting. Those were the only modifications made to the trailer, other than enlargement of the existing switch panel cutout on the garage wall. All the custom components used in this project were designed with a free on-line CAD program called TinkerCad. Some items were 3-D printed from PLA filament, a plant based plastic. Other pieces were printed from ABS plastic for better durability, or TPU — a rubbery filament. Automotive Deutsch style plug-in connectors were used to connect the switch panel and control box, and they allowed me to connect a remote switch box that was used to operate the system from inside the trailer during testing. There is also a panel mount USB cable port for a laptop connection to view the serial monitor or update the software. The system needs a one time calibration that is done with the trailer perfectly level. Both momentary switches are held for 5 seconds until the Status LED quickly flashes three times and the audible calibration tone indicates satisfactory level. The software determines the pitch and roll off-sets from absolute level, and sets them as the new target level +/- 0.2 degrees pitch and 0.3 degrees roll. This equates to about 1/4 to 1/2 inch tolerance. The end result works great! There will probably be more software fine tuning in actual camping conditions, but it will be easier to do that in the future. I’m just finishing up a Bluetooth App for the automatic leveling controls, and it will include setting adjustments for tolerance, ground contact pressure, clutch runout, leveling step durations, and more! If you made it this far, I hope you enjoyed the project! Cheers! Geoff
  26. Sweet! I see a new mattress in "theOrca's" future.
