NO BRAKES ; 2019 Oliver Elite II-Hull #448
CRM replied to BoondockingAirstream's topic in Mechanical & Technical Tips
Without a test lamp, one other thing you can try while connected to the tow vehicle is to run a wire from the frame of the truck to the frame of the trailer and see if you now have brakes. This will tell you if you have a problem in the white ground wire somewhere. Just make sure you get a very good connection on both sides, like under a bolt. -
I will have to find a 12v Test Lamp. But you have offered some good information. Pulling the Break Away Switch... the spinning wheels will stop immediately. Solid and firm. Replug and they spin easily without resistance. Connect to Tow Vehicle... 'Trailer Connected' ... squeeze the manual brake controller in the 2019 F350... and a notice 'Trailer Disconnected'. Works fine on our 2019 27FBQ Airstream. Seems to be in between the 7 Pin Plug and the Axles. I found a Fuse Holder (RED) without a fuse. Below the second seat at the Table. Does someone know its function? Obviously without a fuse, everything inside the Oliver works.
Some feedback on the Houghton air conditioner
TimD replied to Minnesota Oli's topic in Ollie Modifications
Reviving an older thread. Thanks to all who posted! We are preparing to replace the Dometic AC in our 2021 LE2, mostly because it is so crazy loud. At the moment the Houghton unit looks like it is as good or better than anything else out there. Would anyone care to offer an update to their experiences? We live in New England but haven't done much winter camping, mostly en route to/from warmer climes. We're not dissatisfied with the propane furnace, but one less thing to break is always good.. Anyone wish they'd gone with the heat pump and eliminated their furnace? Last, anyone more confident that 9.5K BTU is enough cooling? Thank you!!! Tim -
Do you own a 12v test lamp? If you do, pull the disconnect switch (verify that brakes are working) and then test between the blue and white wires at the trailer connector. If test light lights then both the blue power wire to the brakes and the white wire to ground have connectivity and your problem is on the vehicle side. No light? Then test between blue wire and trailer frame. If it lights then there is an issue on the white wire between the trailer connector and trailer ground. Still no light? Your problem is on the blue wire somewhere between the connector and where it is spliced to the disconnect switch wire. -
Steve Thanks. Now everyone knows. This is information that is often found by those with experience! Learning one 'fuse' at a time. I will plug it back. My Electric Brakes seem to have a Fuse issue or Wire inside the Oliver. Maybe a simple fuse, reset or something that is between the operating brakes and 7 pin plug. Or a wire not making contact in a wire bundle under the table or bed access areas. Wow. Again that was quick.
This fuse is under the street side bed and half way up the right side among other wiring hardware. What does this Fuse Protect? What is it called? I am trying to hunt down an obscure reason why my Trailer Brakes are not recognized, when my 2019 Oliver Elite II to my 2016 F350 Diesel. I plug in and when press the F350 Brakes... disconnected. My 2019 Airstream has no issue with the Brake Controller. So it is the Oliver and some wiring issue? Pull the Trailer Disconnect when spinning wheels on either side... they immediately lock up firmly. Insert the Pin and power is disconnected and free wheeling with no effort. Have a Post on Oliver #448 and trying to find the... obscure... problem, but following wiring using a flashlight is the best I can do at the moment.
2026 YM Oliver awning style windows and other changes
Steph and Dud B replied to Patriot's topic in Ollie Modifications
I would prefer an induction stovetop with the lithium power packages... -
jd1923 replied to Patriot's topic in Ollie Modifications
It looks like an Oliver to me! Not much different. Is that wallpaper on the bath/closet door wall? -
Steve Morris replied to Patriot's topic in Ollie Modifications
In a different view, the flexible reading lights are different, with the switch on the base. -
Patriot replied to Patriot's topic in Ollie Modifications
Haha! Wishful thinking. đ typo corrected! -
rich.dev replied to Patriot's topic in Ollie Modifications
Really, a dry bath? -
For those members who donât do FB, here is recent pic of a few 26 YM interior updates from the Oliver FB page. I am seeing the fiber-granite sinks, a vent over the closet door where the pervious speaker use to be mounted. A new Bluetooth speaker, induction cook top, a texture wet bath wall, under cabinet switch lights, a new bath door, and the white belly band. đșđž -
Haloview MC7108 Rear View Camera Install
Boilermaker Chemist replied to Boilermaker Chemist's topic in Ollie Modifications
@Steve Morris sorry to hear about your issues. Knock on wood I haven't had any issues to date. On my Winnie Minnie I purchased the external antenna and attached it on top of the air conditioner shroud. You might try that. But mine works fine on the Ollie without it. -
Steve Morris replied to Boilermaker Chemist's topic in Ollie Modifications
Thanks Mike! After seeing your setup at Lake Guntersville, I ordered and installed the same unit, although I used the adaptor kit you had recommended and simply tucked the wires away under the camera. Unfortunately, my experience was not as good as yours. I had frequent loss of signal, and terrible signal delay. To the point that a car would sometimes be beside me before it showed up as behind me on the display. But this only happened at highway speeds. It worked great when stationary or backing into a campsite. I thought it might be engine interference, so I put the truck in low gear at low speeds to get the RPMs up, but it still worked great then, too. Haloview Customer Service was useless in resolvingtheproblem. Looking at reviews online, this is a common complaint. So I'm now back to the original Furrion camera. It's not great, but it at least works for me. If anyone wants a Haloview MC7108 for a truck camper or backup camera for a car that didn't come with one, I'll sell you mine for $100 plus shipping. Cost new in June was $200. -
Haloview BT7 Touch Rear Camera installation on 2022 LEII
Boilermaker Chemist replied to dhaig's topic in Ollie Modifications
@Steve Morris, sorry to hear about your issues. Knock on wood I haven't had any issues to date and just posted my install to this forum. On my Winnie Minnie I purchased the external antenna and attached it on top of the air conditioner shroud. You might try that. But mine works fine on the Ollie without it. -
At this point... I have run out of WIRES to investigate. Common Sense tells me this could be the Rosetta Stone. If not, a truly Dead End... no Fairy to help after this. (Got a second opinion with Wife, upside down, and noticed that it is attached to a long metal boxy 'container'. Even with the Black and Blue wires... Our combined detective work: Level Meter for one of the tanks: 'GREY' water tank. Even with the wire colors... I am back where I started. )
Million Dollar Highway in a half ton truck with LE2?
Jps190 replied to routlaw's topic in Towing an Oliver
We were in Ouray last fall and were heading to Great sand dunes after that so we had the same decision to make. We had driven down to Silverton without the trailer and that was exciting enough. Woke up the day of departure and it was raining so 550 was a no go for us. Headed north back up through Montrose then 50 towards Gunnison. If there is even the slightest chance of rain I would avoid it. -
One of the first things that I did after I bought my Winnie Minnie back in 2020 was to install a rear view camera. After doing some research, I chose the Haloview MC7108 Wireless RV Camera with 7'' Monitor. I was not disappointed. It had excellent resolution and the image on the screen had brilliant color. Fast forward a few years and I bought the Oliver. Although nearly everything about the Oliver was an upgrade, IMHO the Furrion rear view camera was certainly not. First, the image on the tiny 4â monitor was so small that I could hardly make out any detail. Even worse, the image brightness was so poor, if I had my sunglasses on I couldnât see anything but a blank screen (yes, I tried adjusting the brightness and contrast). So I finally scrapped the infuriating Furrion and replaced it with another Haloview MC7108. I am very happy with the replacement. Below are the details of my installation. In making modifications to the Oliver, my number one rule is to try to avoid drilling any additional holes in the fiberglass. With that in mind, I also purchased the Yinettech Camera Bracket Adapter Kit for Furrion. The steel adapter plate is made to screw onto the Furrion âshark finâ. The kit also included a Pig Tail Plug Adapter since the plug on the Furrion camera is not the same type as the one on the Haloview. It turns out that the Haloview camera is much heavier than the Furrion. So I was concerned that the plastic âshark finâ might not hold up over time, especially considering my lengthy travels and the state of some of our roads. Also, the Haloview camera comes with a rather long cable which wonât fit inside the âshark finâ. Rather than take a chance on using the âshark finâ, cut the cable and make new connections, I chose to mount the camera on top of a Carlon PVC Type 2FSE electrical box. This provided plenty of room for the long Haloview cable and the Yinettech plug adapter. So the wiring was essentially just plug and play. When I removed the âshark finâ gasket from the Ollie I noticed that the area underneath it had been filled with caulk and this was raised above the fiberglass. I decided not to disturb the caulk around the opening for the cable since it was in good condition. Instead, I cut an opening into the bottom of the PVC box to accommodate the raised area and thereby allow the box to sit flat on the fiberglass. I cut off the mounting feet on the box and using the Furrion gasket as a template, drilled holes to match the existing ones in the fiberglass. Since the PVC box was grey, I sanded down the exterior, wiped it down with acetone and then applied several coats of Krylon Fusion All-In-One Gloss White spray paint and primer. This paint is formulated to bond well to plastics like PVC. A weatherproof cover plate was treated similarly and painted. Coincidentally, the rubber gasket that comes with the camera also fits nicely inside the conduit opening. Adding a PVC conduit adapter holds the gasket firmly in place. In order to keep water out, I overlapped butyl tape all around the bottom edges of the PVC box, covering the screw holes. I then secured the box to the fiberglass using the original screws that were used with the âshark finâ. Next, I used Geocel ProFlex RV white sealant around the exterior edges of the box, the top cover plate and the bracket supporting the camera. Screw heads on the cover plate were sealed with the GeoCel and screw heads on the camera bracket were sealed with black Dicor. Finally, I used two cable ties to form a drip loop on the cable to keep water out and used a gasket cutter to cut a hole in a rubber stopper to make an additional seal for the cable. The Haloview kit comes with two nice options for mounting the monitor on the dash. One is a U-shaped bracket that can be secured to the dash with screws. I chose the other which is the center mount bracket. It is simply attached to the dash with 3M tape but is very secure. I am extremely happy with the addition of my new rear view camera system. I think the resolution and color of the Haloview system are exceptional. There are also a lot of extra features on the Haloview system that you will not find on the Furrion.
Using the color illustration of the Legacy Elite II Trailer Harness Electrical... the only item up for discussion seems to be the 'Ground Bar'. Is that the bar under the seat with a dozen or so wires? None are labeled. Lots of Yellow Wires. Is this the source for the Brake Grounding attachment? The Brakes have Power when the Break Away Switch is engaged. They lock up immediately. We spin each side and those passed the Rewire... just finished. Someone may have some advice. The connections all seem tight and secure. It there another location once the power leaves the Ground Bar to Brakes? 13 Yellow wires & 4 White wires... from a quick glance. All screws have a wire. One has no screw, but looks threaded on the Right Side of the bar. There are 3 bundles? with the plastic around the wire(s) on the Right side. I did not look if they had one or more wires... any suggestions? The wiring diagram is missing all of this.
The On Board Jacks are for those who walk inside the Oliver when parked, and are sensitive to the movement once parked and inside. NOT FOR SUPPORTING WEIGHT OF THE OLVIER. We have never used them. We are not... a Prince and Princess. Myself, an OLD guy, with attitude,... and lots of previous experience doing dumb stuff when a teenager.. This is an Oliver Elite II with four wheels. The Oliver with one axle WOULD BE A DIFFERENT and you would be 100% correct. Just not this time. JACK POINT decal behind back axle tires. Lifts one or both wheels off the Earth. The hydraulic Jack was used to get the tire lifted, remove the lug nuts and remove the wheel and tire for easier access, and secure this point. Nice hydraulic jack, as well. Use it on the Airstream, as well, and... survived. I do not eat Twinkie's, either as they have too much sugar. There is a STICKER that says to USE THIS LOCATION TO LIFT THE TIRE OFF THE GROUND. There were Three Wheels still attached and a hydraulic jack with lumber stabilizing it all. When having to remove a flat tire, the same process would be used. The Hydraulic Jack makes it simple and stable. Would do the same with the F350 tires... No magic here to be confused with this. Recall I use to do OSHA inspections. Unless I have become senile... I should not be allowed to drive. The Front Axle Tires were still mounted onto the Axle. And chocked.... both sides. No need to remove them. The major wire issue all come together on the REAR Axle and through the center of the axle. ********** Added: Mike at Oliver Inc. agreed with my Wife with my process. The Neanderthal is correct and a Human Bean is Wrong. Added: I would appreciate HELP in finding the Ground or wire location from the 7 pin plug creating this short to the brakes. Most likely wires attached to the street side of the Oliver. This may have been a Factory Issue and not something that wore out or broke from use. This may have existed on DAY ONE... and I am Old and inherited this situation. Trust me. My Wife would 'kick my winky' IF I was doing something really Dumb. She is a Human Bean. I learn by making mistakes... but not stupid ones. đ (I EDIT AFTER I GET THE IDEA DOWN ON THE SCREEN. I THINK FASTER THAN I CAN TYPE... SYNDROME.)
Geronimo John started following NO BRAKES ; 2019 Oliver Elite II-Hull #448
JD thanks for the generous offer. We Boondock every Spring for years in the Reserve, New Mexico Area, hunting Agates. Driven through Prescott a few times... a Boom Town with a Forest. No Tech. Watch the numerous videos on the Internet. Great source of getting an.... education. Many Good, some Not. Prescott is in a wonderful location, as the Main Street is like entering a mountain town in Colorado or Wyoming. Everyone lives in the surrounding forests with some having that south view of unlimited views. We actually considered looking for a home there, but Boulder City is in an area much like Prescott, with major cities on the west side of the mountains from us. Good pullout once south of town and down the mountain grade. Remembered that... I rechecked the Extension Cord wire and it is more in the 16 gauge wire once stripped. No tech around here. I resort to 'do it yourself' if nothing else is available. Local service had three months booked. Yikes... lots of Travel Trailer problems for those owners. This should not happen to anyone with an Oliver. Rather blemishes my attitude that something that should be permanent from the Factory... should not have a problem. You pay up front for. the quality and Brake Wiring is the... issue? I had a multimeter years ago. Can describe the carton... looked for it... and not to be found. It would have been 40 years old. Great for Jukebox wiring from the 24 button select simple models looking for wire issues. We may be the only Oliver in Nevada. Nothing to compare with. Hundreds of Airstreams. We stopped at 2019 Models of Airstream and Oliver Elite II as the Propane, Solar, Electricity power options are excellent. The Truma hot water tank was junk and unrepairable, after purchasing the Oliver. Too many wires and coils. I like simple systems. Our Airstream's Dometic six gallon hot water was operating on the Airstream Dealer's Lot... and has not been used after the 2019 checking everything out before purchase. Trusted the seller... my mistake. For anyone buying used... DO NOT PURCHASE USED, UNLESS YOU TEST OUT EVERYTHING. Trusting the Seller may not be the best way to go. Beautiful trailer and I will have this all worked out. Will eventually sell, with the Truma not installed, as I removed the trashed by some service business. I had the Recall Notice, but I did not... qualify, as I pulled it apart and it was NOT REPAIRABLE. Had the uncrimped burner issue. I was not even offered the 'improved burner' as I tried to repair it,.. myself. I wander. Love the Oliver Elite II and our 27 foot Airstream, both are perfect 2019's for Boondocking. Both have a purpose for Boondocking locations. Narrow and clearance is excellent on Olivers. Advice at a RV Service is.... ZERO. No Oliver around Nevada to compare... with. Geologists... experience risks whenever out in the... bush. But the trailer should not be the... problem. Sorry for the diatribe... Ahhhh.
