For rallies. I have recently discovered someone trying to maintain at RV LIFE Community / fiberglassrv.com, or simply Google "rvlife rally map" and find the current year's listening. 2027 rallies: https://www.fiberglassrv.com/threads/2027-rally-map.2181770/ Google Maps directly for 2027: https://www.google.com/maps/d/u/0/viewer?mid=1I8mtXQU3Pky2XBNV9VoyNyjY9i-XWPw&ll=42.650591549794484%2C-101.6669803122351&z=4 I've recently attended, or will be attending, these fiberglass rallies: Falling for Fiberglass: https://www.facebook.com/groups/fallingforfiberglass Thanksgiving in the woods: https://www.facebook.com/groups/1249062990470466 Eggs on the Hiawassee: https://www.facebook.com/groups/eggsonthehiawassee/ Spirit of the Suwannee: not sure of site yet. All great rallies. If the weather is cool enough, the boondocking/overflow at Hiawassee is not bad, but again, weather dependent. Some time people double up on sites too if site renters allow it. This end of year is pretty full for me for rallies, but more to come. Next year we're likely leaving Hiawassee a day early to head up to the Maine Oliver mini rally in Boothbay. Richard is the organizer, PM me if you want his contact info.
Note that I've never heard of an Oliver "swaying". However, all of the manufacturers of current 1/2 ton trucks in one way or another "require" a weight distribution hitch. Both legal and warranty issues should be considered before towing an Elite II without a WDH. Bill
To address your question specifically, yes the GMC Sierra 1500 will tow the Oliver trailers quiet nicely. We towed our longest trips in a GMC Yukon Denali, which is a bit heavier than a 1500, but same platform and engines. I had the 6.2 liter gas engine. No problem towing with and without the weight distribution hitch. I towed the trailer home from Nevada without the w.d.h. on it and had no wobble or sway. I wouldn't tow it with anything less than a 1500. It was too heavy for a Tacoma that I had briefly. I've also tried a Cadi EV and that towed nicely and a Sierra HD. The HD was obviously the best. My next trip we're taking a Hummer EV, so we'll see how the range does on that EV.
Update! Aaron Wolters from Oliver has kindly provided me with a list of registered Rally attendees for this year's rally. If you are attending the Rally and would like a copy, PM (private message) me with your email address and I will try to get this list to you via email. In addition, I will (hopefully) get the list to a printer and will have copies available at the Rally either at my site (B-03) and/or at registration. Bill p.s. note - there are currently 235 registered attendees.
We have done the list the last three years. After talking to Scott Oliver and Matt last year, they were going to try to include that information with the welcome package. So no, I am not collecting details this year. Due to a scheduling conflict with a building project here at home, we have canceled our reservations. FYI Rally attendees: After seeing the above posts I did a little bit of poking around in order to see IF this list was actually being produced for this year's Owners Rally. Well, given that I would guess that Scott Oliver delegated this job of producing an attendee list with campsite numbers to Matt Duncan, and that Matt Duncan no longer works at Oliver, the communication chain had a good likelihood of being broken. Hopefully I will be able to obtain the information we need with enough time to get copies and have them available at the Rally. However, if there is someone that you really want to meet up with, it might be advisable to contact them ahead of time to find out exactly where they will be at the Rally. In this vein - I will be in site B-03 from late Tuesday afternoon through Sunday night (October 21 through October 25). Bill
About two weeks ago my wife reported to me that her cloths dryer was not working. After a quick inspection I called an appliance repairman who explained that there was a short in the heating elements and/or an internal relay - neither of these parts were available for a repair. So, off to Lowe's we went and spent $2,000 on a new washer and dryer (had to get the pair due to them being "stacked" in the laundry room. A few days later once again my wife got my attention by saying that once again the "new" dryer was doing the very same thing that the old "broken" dryer did! This time I suspected that the circuit breaker was faulty, so, I removed the cover panel from our sub-panel "A" and inspected the breaker and wiring closely. Yep - one of the wires entering the circuit breaker for the dryer was loose. Odd that none of the other wires were loose and that the loose wire showed virtually no signs of heat. But, a five minute "fix" was all it took to solve the problem. However, obviously, it was too late to get the old dryer back let alone the $2,000. What are the odds that your battery cable was loose? What are the odds that a single wire into a breaker was loose? At least yours didn't cost you $2,000.😵💫 Bill
- Last week
I'd guess that one reason to use single valves rather than 3-way valves, is for ease of configuration. I ran into this when I replaced my single valves with 3-way electric valves, they have to be oriented correctly to get the correct flow paths and that meant there was piping loop-arounds to reach the correct ports. If looking at the flow paths for L-port or T-port 3-way valves, they will not work in @topgun2 drawing without a different pipe configuration... and then the simplicity is lost! Single valves are easier to configure in that tight space without loop-arounds, and they are easier to show in valve line-up sketches.
No worries! It gives us something to do! That is a Wago connector to splice two wires together. It has little levers on it so that you can pull the wires out. Other connectors might look similar, but without the lever, and the wires won't come out! Glad you found it! Happy camping!
All I had to see was a truck hauling a U-Haul trailer down the road with sparks flying from the driver side tire that had blown out. He was going down the road passing people having no idea he was tireless with rim grinding on the road. He kept going for miles down the road before we finally saw him pulled over. Convinced me to always have TPMS.
All i found the problem. a loose battery connection. i feel like an idiotic not checking it first. sorry i wasted a lot of your time. i am good to go now.
Yes, at some point OTT replaced two (2) brass two-way valves with four (4) basic open/shut valves. Both configurations achieve the same end result of three (3) plumbing configurations, 1) Normal Camping, 2) Sanitation/Winterization or 3) Boondocking positions. Maybe the change was due to the higher cost of lead-free brass or the 1/4" flow restriction in the OEM brass valves (see pic). I replaced ours with 2-way motorized ball valves with 12mm ID. I've never seen inside the basement of an LEI, but both models have similar kitchen sinks, wet baths, outdoor showers, 3 water inlets, etc. Of course things are more cramped and some things are mounted in different locations.
Bob R joined the community
Well, looking at the diagram posted by Topgun2, I am unsure what to say! Looks to be 4 valves on the newer models! I have no idea how they configure. Glad to only have two! Mine are three way valves by the way, and they have been simple and effective. Curious to hear how AKPilot's hull is configured as its 3 hulls newer than Topgun's. Maybe the E1's are plumbed a little differently because of space constraints....
i think i checked all the fuses on the 12V line and they appear good but there is this connector on both the positive and negative wires coming from the batteries to the fuses and i wonder if they are open circuit. I have never seen this type of component before. is it a connector or fuse or what but it goes to the fuses where i cannot get any voltage reading of any kind even though the fuses test good what is this type of connector for?
Yeah, I missed that too. Dave has the older EI along with a couple of others who frequent our Forum. Oh, and there are no plumbing schematics older than 2019 as far as I know. Maybe @DavePhelps could review the 2019 diagram and comment re older EI differences. The plumbing should be similar. EI and EII have 3 water inlets with similar (same) valving configurations. They likely install water line restrictors on both models. I forgot to mention, there's no restrictor on the boondocking line since the Oliver water pump supplies the suction there's no need.
Used Oliver advertisements Return to the Oliver Forum
jd1923 replied to dewdev's topic in General Discussion
Turns out these parts as pictured will be at The Rally next week 4-Sale. A good traveling spare set would include a left and right hand set to cover a full axle rebuild. Anybody who can change a trailer tire can mount this hardware on roadside if necessary (think Alaska trip). The hubs come off with a small circlip and one large nut. The brake backing plates connect with 5 nuts on the axle studs (you can see 4 of 5 nuts in the picture). These parts are listed on eTrailer to see their retail value. These are brand new parts to be sold at a very good cash price. Please PM me if interested. You could pick up the parts pictured at the Rally and I would ship a like set for the other side to you free shipping. -
My apologies! I simply neglected to notice that what you were requesting was information on the Elite I NOT the ELITE II as I posted above. Bill
Welcome @AKPilot and congratulations! Btw, there are quite a few of us who feel OTT built a darn good Oliver back in the day! I've been restoring our for 3 years and finally all the major stuff is done! 😎 I would start with Dave's suggestion, meaning first be certain your valves are set correctly. There is another reason the boondocking port may work and the others do not. If you look closely at the OTT plumbing diagram at the City and Fresh Water inlets it shows backflow prevention aka check-valves on both lines. What the schematic does not show is that OTT also installed water flow restrictors next in line (see pic, rear wall of basement, Hull #113). This statement had me thinking. Perhaps hard water left in the plumbing over a long period of time would evaporate leaving heavy calcium deposits in these waterline devices. I say heavy because there is a bit of water upstream. Our check-valves always leak a little when unpressurized. With ample water uphill and basically an opening downstream, more and more evaporation over time could lead to calcium buildup that would eventually close the openings. This may well be your use case. I've had it on my long list to REMOVE these restrictors. A true pressure regulator on the fill hose is superior to an inline restrictor, since limiting pressure vs. restricting GPM flow rate are not the same (the former is good, the latter no so). I believe removing them is best. At the same time, the check-valves could be cleaned with CLR but most owners when getting in there have replaced them. They're a relatively inexpensive part and yours are likely to crusty to clean anyway. Hope this helps! Please post your maintenance, repairs and modifications here as you work through them and of course ask questions for anything you need!
There must be a direct positive (+) battery connection to the Optifuse. Geoff ask you to retest, but when you're certain there is no power on the battery side of the breaker (or both sides) then the +battery cable feeding the Optifuse is either 1) disconnected, 2) switched OFF or 3) has an added inline fuse that is blown. You must have an open circuit for there ot be no power on "either side of the optifuse." OTT in their OEM build did NOT add a switch or redundant inline fuse in this circuit. The Optifuse is the breaker that protects your batteries from shorts in ALL DC lighting and appliances (all DC loads). If you have anything but a solid stretch of 6 or 4 AWG between the Optifuse and your batteries it must be an aftermarket installation, perhaps something was added during April 2025 when you had LiTime batteries installed. Your solution is simple. Just follow the battery cable from the Optifuse to the batteries. Given your Optifuse is under the streetside bed, the cable will run a whole 5 ft total, first under the pantry area, then up through a drilled hole/grommet into the battery bay, then connected to a positive battery terminal. Your "Tech" could have added a +bus somewhere interior, if so test for +13V there. But if the retest shows +13V on the battery side, but NOT on the load side of the Optifuse, then replace the Optifuse with a 60A ANL Fuse. There are no other possible causes for the full loss of DC power in the Oliver. You either have an open circuit in the battery cable or a bad Optifuse breaker.
My Legacy 1 is close in age to yours, 2015 hull 107. I'm wondering if your water valves are configured correctly. Mine has only 2 valves. At some point Oliver went to three. If you have the two valve system, the "handles" on both should be oriented front to back of trailer. This would be the general use setup, which would include using the water pump while boondocking, or city water hookup. If you turn both valves 90 degrees (side to side of trailer), then the siphon inlet at the rear curbside will be engaged. You would then siphon water from an external canister or whatever and fill your fresh water tank. Turn the valves back when ready to use the system. That's how it works for me anyway. Dave
I'm a little confused because you've said there is no power on either side of the optifuse, but you've also said that it tests good? Also, you mention a 2000 watt inverter, where you talked about a converter before. These are different things and wired differently. BTW, a 2000 watt inverter should have another ~200 amp breaker or fuse between the inverter and battery. That's not the problem, but you should be aware of it. Mine is mounted on the vertical wall above the inverter. At any rate, the battery and/or the inverter both feed the 12 volt panel (and jacks) via the 60 amp optifuse breaker. Re-check it for 12v from each terminal to ground. There are grounds all over the place in that area, the jack post, trailer frame, or the inverter chassis will work. If there is voltage on the line side, but no voltage on the load side, then you have a bad breaker. These breakers are readily available, and the failure rate is pretty low for the millions of them out there.
carpenter replied to dewdev's topic in General Discussion
I am just up the road in cheyenne and would also be willing to come down and purchase the front tray if you are interested. Going full time in my 22 is going to be an adventure and I think storing the generator and gas can outside my truck topper would be ideal. -
i got back home fine and with a voltmeter i did some more checking and there is 13V coming out of the batteries, I checked but there’s no 12 V on either size side of the optifuse. The fuse is good as i checked with ohmmeter. There is a one amp in line fuse I also checked it’s good also. the 2000 inverter is turning on fine and turning on the microwave and all the stuff that runs off the AC so it’s puzzling why there is no 12V DC power in the trailer. there has to be a bad fuse or switch somewhere. I am going to try to reach out to OTT but it usually takes them a while to get back to me. any other ideas? could a fuse be blown in the inverter.
Thank you very much Bill. much appreciated
Below is a diagram for a 2017 Elite II which is the same as my 2016 hull #116. Bill p.s. included are a couple of others that you might need at some point.
