  1. Today
  2. Dean this is very helpful. unfortunately i left my volt meter that i normally carry in the trailer at home but i will try to manually raise the hitch jack with the hand crank tool and then go into town and buy a cheap voltmeter at an auto shop so I can check the batteries. i have lithium ion batteries. and then check voltages from there. i will check the manual and look for wiring diagram. maybe someone at this camp ground has a voltmeter.
  3. Wow, I’m really sorry this happened. I’ve heard of similar issues with other trailer brands when there’s little or no effective overflow outlet. That’s why most trailers are filled using a flex‑hose insert—to let air escape properly. With the direct connection on our trailers, it’s difficult to manually fill at the inlet and allow that air to escape. In your case, it sounds like the overflow tube may have been restricted, or the incoming water volume and pressure simply exceeded what the overflow tube could handle. Thanks for sharing this experience. And again, I’m sorry you had to deal with it.
  4. Electric RV jacks almost always have a manual method for raising and lowering them in the event of dead batteries. The connection point is located on top of the jack, and the trailer includes a tool designed specifically to operate it.
  5. I should have started by asking whether you have voltage at the batteries, and then whether you have voltage at the input side of the 60‑amp breaker. A voltmeter will help immensely. It could even be something simple—like lithium batteries that were accidentally switched off. On my trailer, a 4‑gauge cable runs directly from the batteries to the 60‑amp breaker, and that circuit is independent of the heavier‑gauge cable feeding the inverter. I can double‑check in the morning, but I’m fairly sure the wire going to the converter is connected before the 60‑amp breaker, which would mean the breaker isn’t the issue. I hope this doesn’t add to the confusion. Dean
  6. Dean, jacks do not work. i cannot get the trailer of the truck hitch. i did flip this 60V and it did not fix the problem. i wonder if i can over ride it or maybe it needs to be replaced. i am wondering if I can manually lower the hitch jack so I can at least unhook the trailer from the truck.
  7. Imelda, The 60‑amp circuit breaker under the street‑side bunk also supplies power to the jacks in my trailer. Do your jacks work? If they do, then move on to the converter—located under the dinette in my unit—and check the fuses there. If the jacks don’t work, the breaker is most likely the issue. Dean
  8. I hope this issue has not previously been addressed on the forum. I could not find anything on this topic with a search. So, here goes. I have always assumed that the fresh water tank in our 2022 Elite II could be filled until water flows out of the overflow tube underneath the fridge, regardless of the fresh water sensor reading. This approach is recommended on p. 61 of our 2022 Oliver Owners Manual: "fill until water starts to run from the freshwater overflow..." I have regularly done just that with no issues--until a few days ago. When filling the fresh water tank, the aisle floor bulged upward, the entire trailer shifted to the curb side binding the door, and then, with a loud CRACK, the backsplash on the sink side of the galley countertop separated by about 1/2" from the fiber granite countertop, because the corner of the countertop near the sink was sloping toward the curbside! After we recovered from the shock, my wife and I immediately ran fresh water (via the pump) into the gray water tank through the galley sink until the trailer shifted back into equilibrium. Fortunately, this enabled the aisle floor to level out again, the door to unbind, and the countertop to slowly rise up again to meet the backsplash, so the two once again line up. When we get home, I plan to re-caulk the joints that separated, and carefully inspect for any additional damage. So far, all appears to be "back to normal" while we continue our extended trip. Lesson learned: despite what is recommended in your Owners Manual, monitor the fresh water tank level when filling, and once the sensor reads close to 100%, SHUT OFF THE WATER! DON'T WAIT FOR WATER TO FLOW FROM THE OVERFLOW TUBE!
  9. Picked up our Apex two weeks ago and have been in it every night - so far, so good. We planned to spend 3 weeks straight to learn and work out any bugs (very minimal issues so far) Pros - A dream to tow & bike mount has been solid/Eco flow display easier to learn that anticipated/battery re-charge amazingly fast/Houghton AC quiet and have ran all appliances (simultaneously) and some “faux” boondocking on the 48 volt DC system w/ no issues. It has been wonderful to arrive at the campsite with 98% battery every time. Overall love the attention to detail and quality of the design. Dinette cushions (backs) could be improved and wished they would have included the solar suitcase connection. Cons: Black/Gray tank indicators don't really warn you of a full tank, but the toilet gurgling and the shower backing up are sure indicators 🙂 I haven’t attempted filling the fresh water tank yet (to be honest I am intimidated by the multiple valves under the bed - wish they were labeled but thankful for the poster size diagrams on the compartment cover. Our background: Previous tent camper, then a Casita circa 2000s, and Airstream owner. So far impressed with the Oliver overall operation (Airstream could learn from Hohenwald orientation and pick up) and while tempted by the new Casita double axle trailer (significant price difference) the Apex is a well designed trailer and we have no regrets.
      • 1
      • Like
  10. i did find the fuse but unless the fuse is bad i flip it on and off but didnt seem to solve the DC power problem i. the trailer. i don’t have a meter to test the fuse.
  11. ii am at a camp site. tomorrow i will look for this.
  12. i am at a camp site. tomorrow i will look for this.
  13. My 2021 model has a 12V 60A circuit breaker under the street side bunk.
  14. the ac power is good microwave is working and ac outlets but no lights and refrigerator and ac not coming on
  15. oliver 2 year 2020
  16. Yesterday
  17. Which year and model of Oliver are you asking about? Mossey
  18. ac shore power turns on microwave and turns on outlet but not lights. i know there fuse blown somewhere but where?
  19. Todd B - If you are still in the Teton area be sure to look up "Elk Ranch" road. It is located north of your campground, is on your right as you travel north and is easy to get into and out of even when towing your Ollie. Great views of the Tetons are available here without dealing with 5,000 of your closest friends. Also, Dornann's is a good place for a decent pizza - located just north of the airport. Safe travels! Bill
  20. Dean & Mary - Re Rallies: In a recent conversation with Aaron Wolters at Oliver he told me that he is working on and is interested in "regional rallies". If you would be interested in helping organize such a rally in your area, I'd suggest that you get in touch with Aaron. There are and have been a number of these regional rallies - the New England area, the Texas rally and the Florida rally all come to mind. Therefore, any organizer would not have to re-invent the wheel to get it done. Bill
  21. Wrapping up a week in Grand Tetons. Gros Venture is the campground and the fall colors, even though we were a little late, delivered! Also, thought I would post some solar number as some of these days it was really pulling in some good numbers hitting almost 350w out of a 400w panels one day. Another 6 days discounted, running invert most the day with Starlink and laptop and even some small microwave use. Batteries are sitting at 70% still.
  22. I just upgraded from a 2" Bulldog hitch to a 2‑5/16" hitch. Thanks, Patriot, for the information and the link to the Collar Trailer Hitch Lock for Bulldog‑style Couplers. I just placed my order, and it will definitely help with security while towing, since the wire that holds the collar offers virtually no real protection. I’ll be using a Proven lock on that collar so it matches all my other Proven lock keys.
  23. When we are driving it just sits on the dash. When at camp we just put it wherever we can get a decent sky view. Plugs into our Elite on the outside and with the long power cord it’s easy to work with. It’s a great thing to have for so many reasons
  24. We live in the mountains about an hour from Denver off Highway 285. We hope to attend a big rally someday if one is held close to Colorado, and a smaller regional rally would definitely interest us as well. Thanks for checking out our signature line about the equipment upgrade. I’m still working on it and hope to have everything wrapped up soon. Once it’s finished, I’ll put together a full write‑up and share the process. And yes—I agree that an Oliver‑offered Victron upgrade would definitely appeal to buyers. Dean
  25. Welcome to the Oliver family! Nice looking trailer - enjoy!! Mike
  26. That Power Foam Turtle Wax bug remover gets high ratings. Once you get your ceramic coating done you will find that the bugs are a bunch easier to remove. CGI (that Patriot mentions above) has a product that will also aid in bug removal while enhancing and adding to the life of your coating - I believe that "Ceramic Shield" is the name. Bill
