Tideline77 started following Full Suspension Replacement - Alcan Spring and Dexter D52 Axles
Haven't done it to our Oliver but we "flipped" the axles on a previous trailer to gain approximately 2" for the same reason. If your Oliver axles sit on top of the springs you can have a spring/suspension shop "flip" them to put the axle tubes underneath the springs. You basically gain the diameter of the axle tubes. (Note that this could slightly affect handling since it raises the trailer's center of gravity, but we didn't notice it on our other trailer.)
Appreciate that tip on the coffee shop ! we are no longer in Leadville, but we did have a great Pizza at “High Mountain Pies” Would recommend that spot for Pizza
I have not read here that anybody has done so to date, but John E Davies who was active years ago wrote some about modifying the Oliver suspension from an Under- to Over-slung suspension. I tow in the NF and BLM of Arizona often, descending steep and deep washes and have so far never scraped the rear. This suspension change would give you a 5+" lift (diameter of axle plus height of leaf springs), and this comes with negatives. Mainly just climbing into the cabin would be a pain, reason why I tow with a 2WD truck, vs. a 4WD truck with a lift! No, I'm done with trucks or trailers where I'd need to climb up like that! 🤣 I'm not seeing a 2" lift option and only 2" may not answer your needs. I've got neighbors with driveways like yours, wow! I'd suggest leave the Oliver alone and fix your driveway. You'd appreciate it when driving your grocery-getter too. Talk to a concrete contractor or build a proper set of ramps specifically for this purpose. Please let us know and post here with pics and comments if you do convert your Oliver to an Over-slung suspension! 😎
Cool @pjt, and thank you for your input as a new Forum member! I hope very soon you get a chance to have an Oliver of your own! This thread was quiet for two days which surprised me. Handy, yeah no problem and I have flare tools from working automotive brake and fuel lines, though I may need a larger flare die. I recently purchased a vacuum pump and gauges and have restored the A/C in two of our trucks. The kit has fittings for R134A, R1234yf, R32 and R454B refrigerants. The Senville 18K and 24K BTU models I've been looking at uses the very efficient R454B which is 70% R32 and 30% R1234yf. Starting to worry about whether I need permits in our city. Hate to get .gov involved, nothing but corrupt bottom-feeders! 🤣 Much of electrical code is BS too, like having a power cutoff box at the unit, as any idiot can merely trip the breaker and I don't want the extra cost and another box mounted to the side of our home. Our city will likely add 100s of dollars in permit costs too. Glad to know that Pioneer is working out for you. We have a member here who installed a Pioneer inverter A/C rooftop on his Oliver. Most of the models are likely very close in features and quality, except for the refrigerant used. Did you sit the compressor/condenser unit on the ground or wall-mount it? In our application, I would like it wall mounted, but wondering if that would cause noise. Cooling bedrooms has different concerns than cooling a garage. Would love one in my garage but I just tough it out July and Aug when we see some real heat. Thank you for the suggestion on installation videos. I'll take a look. I'm going to talk to the heating & cooling company that I've used and trust to get some inputs on how to handle this in our area. More to come... Thanks again, and BTW feel free to ask us any questions if you are interested in purchasing an Oliver, the best little egg camper out there! 😎
Following JD's lead on this: Some thoughts about the 3 way it appears you have done all the common items: Turn the control panel up to setting 5. Park with the curbside door on the north side as much as possible to keep the solar gain off the unit. If not possible, lowering your awning a bit to put the unit into shade. Open the frig door and look in the upper back wall where the aluminum cooling fans are. On the right side of them is a white plastic "clamp" that holds the thermistor for the unit. It will slide up and down on the right most fin. This thermistor controls the cooling system. Moving it up or down will increase/decrease the temp in the box for each of the five settings on the control panel. I don't recall which way you move it go get cooler, but there there is a post on the forum. I'm sure one of the members will remind us on this detail. The Beach Lane Fans seem to be the best fan solution for a warm frig in hot conditions. So regardles of any of the suggestions, if you use a 3 way where it is hot you need the extra cooling needed by the frig. Do plan on doing this if you get yours running. Good posts on the forum on how. So now to get to the gas burner orifice. It is easy to get to and remove. Follow the gas supply valve into the curbside front of the lower access panel. It goes horizontal into a gas control valve. Beyond that valve is an air shield. The outside cover can be bent out to reveal the gas orifice. A small combination wrench is needed to remove it. Done. Hope this helps. GJ
Hull 1703 2026 LEII Has anyone raised their Oliver 2"? I have a steep driveway and the approach angle from the road to the driveway is approximately 12%. To back the Oliver up the driveway I currently have to back up until the trailer is just about to hit and then place boards under the tires until we are started up the driveway and then we are fine. Raising the height by 2" should solve my problem.
We went to the Keg Springs Winery earlier this week. They have quite a few different red and white grape varieties, but specialize in fruit wines. Blackberry, Muscadine, Peach, Cherry, etc. We enjoyed our visit.
Update: Water pump switch has been fixed. I was in Hohenwald for a furnace and water heater issue so I had them troubleshoot and fix as we are still under warranty. The issue ended up being a loose connector on the Seelevel switch. Mike and the Oliver service department were great in addressing all of our issues.
Update: W255H Issue Hull#1703 2026 LEII The furnace and water heater issues have been fixed! Mike at Oliver service was very accommodating and got us back on the road. Turns out the data cable was the issue. While trying to pull a new cable thru, the old cable broke, so I suspect, it got crimped somewhere and worked initially but as we traveled down the road it was compromised. Thanks to everyone here who tried to help me fix it without traveling back to Hohenwald and to Mike and Oliver service department!
Welcome. Looking at the map, I'd suggest the Reno, Las Vegas, Albuquerque, Oklahoma City, Little Rock, Memphis route. Lots to see on that path. Last year we stayed at Maumelle Park outside Little Rock and visited the Little Rock River Market and the nearby riverfront park. We also visited Memphis (not the nicest city) and saw Elvis' mansion and the Bass Pro Pyramid, which is definitely worth a stop (try the restaurant at the top). Some good food and interesting places north of Hohenwald in the Nashville area, too. Have fun planning your trip!
Martin and Linda, welcome! You live in a nice part of Oregon. If you have questions, you’ll find lots of experts that will offer solutions. Mike
Good morning back to you and a big Welcome to the Forum! Amber Falls Winery is not far to the East from Hohenwald, TN (35.57895, -87.36741). This is a pleasant little winery and has a couple of red wines that are worth considering. However, I thought that $50+ for these was a bit high. There is another winery just off the Natchez Trace Parkway - north of Hohenwald called Keg Springs Winery (35.65096, -87.34441) but I've never had the chance to stop in. Good luck! Bill
I'd bet that you are no longer in the Leadville area - but - there is a coffee shop directly across the street from City Hall that has very good pastries and coffee. Plus, they have free WiFi. Bill
Likewise, good to hear from you again Claudia. We've conversed here before and I remember you being quite DIY capable! 😎 Re your statement above, it means two things to me. First, I've always noticed that ours works a little better on LP which is the opposite condition. And that has me thinking about what you wrote, when temps are over 80F. Have you installed a better fan in the exterior vent area? You might think, why would that matter when it cools properly on AC/DC? I'm not certain, but a viable hypothesis may be the fridge on LP creates more heat than when powered by electric. Our fridge used to perform on-and-off and ever since adding the Beech Lane large dual fan it performs excellently under any power source. When we set it on #4 the freezer will approach 0F and the fridge will get down to 32F (Ruuvi temp sensors) and when it does so we switch the cooling level to #3. Chris was a restaurant chef for a few years and she keeps me well nourished! 🤣 That means she keeps a very FULL fridge! We now have an extra fridge in the truck, always with space for grocery shopping. If you reply that you already have a similar fan (not the little OEM fan), then I'm at a loss in what to advise. But if not, do this before you do anything else. My installation is presented at the bottom of page 1 on this post:
You're welcome, Robert. That's great that you are in Colorado! You should definitely visit Alcan like I did on our trip, purchase parts at a minimum, get the Alcan Leaf Springs and get their U-bolts also to mount the springs. Your Oliver is a 2022, mine a 2016 needed everything. I'm assuming you have the HD EZ Flex kit installed from new. For example, if you have towed 50K miles in 4 years, your EZ Flex equalizers are likely shot. There is a section in my post about the equalizers. They wear cock-eyed inherent to their design. If your mileage in 4 years is much lower say 20K miles, they may be OK to be reused. Shocks don't matter much. If you had Alcan work the spring install, you could ask them to test the shocks. If bad they could replace them if available, or just reinstall them as-is and you could DIY new shocks at anytime, a simple task. Many on this forum and elsewhere are adamant about the wet-bolts installed in a certain 3 or 9 o'clock position. I'm not sure that matters, I worry less about some things. Since the Alcan wet-bolts were not splined, I just mounted ours in random positions. When I grease, I usually get one Zerk per side that will not take grease (yes wheels and load OFF). I just loosen that bolt, give it a 1/4 turn, apply grease and retorque. To date, only one Oliver owner had issue with the Alcan shackles, where they got buggered with use. The same owner went with an extremely light torque setting, hence the damage. No other complaints from what, 200 Oliver owners with Alcan Springs! If you believe in the 3-9 positioning get a HD splined set instead. I also thought afterwards, I could have bought the full HD EZ Flex set saving money. If needed when there, purchasing Alcan wet-bolts would be fine. One thing I can tell you is they will reuse everything good and are not the kind of outfit to upsell their customers. Another thing I would have done differently? If Alcan had in stock the axles I needed, in hindsight, I would have had them do the whole job when I was there. They charged others a very reasonable $600 for labor, and got the job done in a half day. I enjoy DIY on my vehicles, always pay for parts only, dislike paying for contract labor! But to install axles and springs was a long hard job for one old guy at home (my son helped when asked), pacing myself I spent a few days! They certainly would have fit me in vs. allowing me to drive off that day! They measured our Oliver and spent so much time with me. Our Oliver is one of the few with the 50" axles, while Alcan had a whole pallet of 50.50" axles for their Oliver customers. My axles had to be custom ordered, so having them do the work while we were in CO was not in the cards. You have a lot to consider. I suggest you keep the installation option open. Call them and talk to Lew or Tim. Let us know how it turns out for you!
Good morning to all. This is Martin and Linda from S Oregon. We live near Jacksonville and the Applegate valley. Wonderful wineries and cider makers in the valley. We just picked up our 2019 E2 and are searching for places to go as we head to Tennessee next summer. New to this site also so hopefully this post works. Enjoy
Cottonwood Lake USFS campground on Cottonwood Pass, near Buena Vista, Co 3.5 miles of miserable washboard dirt road , nice campground, no water available as the well has been broken over 5 years with no plan to repair 🤔 campground is all FCFS and fills up Friday mornings too much dust with folks driving 25 mph in a 5 mph campground One pic in Leadville, Co
Ty J started following Geronimo John
Made in USA leaf springs
Tideline77 replied to Mountainman198's topic in Mechanical & Technical Tips
Thank you for this detailed information we are roaming around Colorado and I was thinking about contacting Alcan to check on appointment availability for the upgrade. Maybe we will just pick up the springs and haul them home to complete the job after we gather all the other parts , shocks, EZ Flex, Shackle U Bolts and wet bolts Thanks a million -
We probably have the same Dometic unit though I have never checked its model # but my hull is #70 so not too far apart. No issues on mine so far. Given your description I would be inclined to think you might have to take the unit out of the Oliver to work on. You are already much further down the pike of knowledge on this thing than me. Best of luck with the repairs and working through this. Rob
Just installed a 24k BTU Pioneer mini split in my garage. Takes some time and effort, but it's doable if you're handy. I don't have experience with a dual head unit. You will need some specialty tools: Cut, debur, and flare copper tubing (get the Yellow Jacket eccentric) Vacuum pump Micron gauge (recommended) Lineset bender kit (BendAid) Specialty torque wrench (or crows foot) for flare nuts Measure everything multiple times before making any critical cuts or holes. The included cardboard template for mounting the inside unit was wrong, but luckily I caught the error. It works exceptionally well and is very quiet, both inside and outside. Benjamin Sahlstrom has some excellent installation videos: https://www.youtube.com/@BenjaminSahlstrom/videos
Hi Oliver Fam, I'm hoping to hear from owners who have actually serviced the Dometic RM2454 burner system in an older Oliver installation. I haven't been on the forum for a while, but I own Hull #184 (2017 Legacy Elite II). I also had the same RM2454 three-way refrigerator in my Casita for about 10 years before moving to the Oliver, so I'm fairly familiar with the unit. Recently, I've noticed the refrigerator is not cooling as well on propane as it does on electric, especially when ambient temperatures are over 80°F. The flame appears normal, steady, and blue with no orange/yellow. The fridge was in normal use at the time—not empty, but not heavily packed or overfilled. I've already worked through the usual troubleshooting steps, including adjusting the thermistor position, running the auxiliary cooling fan, and reviewing common recommendations from both this forum and elsewhere online. At this point, I'm trying to determine whether the issue is related to a dirty or partially restricted burner orifice, a partially obstructed burner, propane pressure, or something else in the LP system. I've attempted to access the burner compartment, but even getting to the baffle screw was more difficult than expected due to the tight working space and awkward access. Looking at the burner/orifice area and chimney, it doesn't appear to be a straightforward space to work in with wrenches. Most of the access is on the right side, and as a right-handed person with some limitation in my left hand, it feels like a very constrained area to safely get proper tool control. For those who have actually worked on this specific installation: Were you able to clean or remove the orifice for cleaning in alcohol? Have you checked propane regulator pressure as part of diagnosing this issue? What tools or approach worked best in this tight access area? Was it realistically doable, or did it turn into a refrigerator removal job? Any lessons learned or "wish I knew this first" tips? I'm not currently looking to replace the refrigerator. I also carry a separate 12-volt auxiliary fridge, so I have some flexibility. I'm mainly trying to understand whether this is a reasonable maintenance task or one that effectively requires pulling the unit. I have cleaned a gas jet before (a few times) on my Casita as part of maintenance. Those who know me from the forum know I tend to be a very hands-on owner and do most of my own maintenance work when possible. I have the interest, but sometimes not the tools or mentorship to pull it off. Appreciate any firsthand experience. Claudia Hull #184
Main battery switching, a different approach
Thanks, and it has worked great for 2 years now. Along with 35-gal fresh water in the TV we use it every few days. No-way could we do that lifting our heavy custom mattress! This and moving all the electrical under the rear dinette seat has saved a lot of frustration. Perhaps OTT could add these ideas to their 2027 models! 😎 - Last week
DanielBoondock replied to Lamar's topic in Mechanical & Technical Tips
If you like that you gotta try regenerative braking at 0.5 trailer gain! I’ll pull 130 kW silently on the regen and bring you to a full stop, it’s nuts. I have to lower the regen to the moderate level as the high level is too much. Big batter == more regen capability basically. Anyhow yeah the first gen trucks like Lightning, CT and Rivian aren’t for towing, but these second gen Sierra + Silverado are pretty hard to beat as a camping companion. Power is the one thing I don’t worry about boondocking. I’ve talked about it before but I haven’t mapped a trip yet that doesn’t have charging close enough for these trucks. The only vampire I notice is the WIFI (TP-Link travel router), slowly but surely it’ll eat at the battery and heat up the attic, even on Eco. Not a problem with all these kWh really but its’ annoying, I turn it off at night. I wifi hotspot mooching and tether my unlimited plan phone for the family otherwise.
