I am looking for a round rocker switch, SPDT, weatherproof, threaded mount, not lighted, blade terminals. I am not finding anything like this using my usual search methods. I have removed the shelf from the bathroom vanity and have installed a marine hatch in its place. I now must relocate the pump switch. The factory used what I think is a DPDT panel mount switch and held it in place with a wad of caulk. I want to mount the switch more securely. Switch as mounted in the shower shelf Switch removed from shower shelf Where I want to place a new switch Wiring schematic showing switch I want to replace Thanks for your help Bill
This is one of the major reasons I had my Ollie done by the CGI guys. Certainly I didn't want my Ollie screwed up by someone that really didn't know what they were doing. There are a few shops doing this kind of work in and around the Asheville, NC area, but, very few of them had ANY EXPERIENCE with fiberglass. And, reviews were generally mixed. After seeing how hard CGI guys work, seeing the results of their work and then getting to meet them at one of the Oliver Owner's Rallies, I was sold. There have been a few posts here on the Forum by members that have used other outfits and they have noted satisfactions with the results at prices that are competitive or even lower than CGI. Unfortunately, I do not recall any of those posts being for ceramic coating shops anywhere near Maine. Good luck! Bill
When I first starded to look for the missing knockout the first thing my wife said was I need a borescope camera. So in my thinking thats a green light to make the purchase. I'm sure they make one with a magnet tip just incase I do find it, LOL
"The price for a horoscope varies from around $30 to hundreds of dollars. " Darn Spell-changer's... š¤£
I got one for my phone three years ago, and find it really useful! Trying to run wires through a wall chase at home, but getting blocked? You can easily see what's in the way. Can't see the model number on the back of the stacked washer/dryer? Easy peasy! One nice feature on the one I have is that it does not plug into the phone. Instead it has its own transmitter that sends via Bluetooth to the phone. That makes it easier to manipulate the camera without the screen moving all over the place. Plus, when I bought it my phone used a lightning plug, and the current uses a USB-C plug. With the bluetooth version, it still works fine. There are also models with attached screens, but I've never used one of those. Here's mine, but it is discontinued: https://a.co/d/00RnxN3L
After reading @aaronorange recent post about their missing furnace knockout, I was thinking that they would have benefited from a borescope to look for it. My daughter gave me one for Christmas last year and itās been way more useful that I would have ever believed. I use it all the time, especially in the Oliver. Iāve found wire routing paths, looked in concealed spaces, found dropped screws. I even found a lost factory screw that was grinding away under the sewer pipe. The price for a horoscope varies from around $30 to hundreds of dollars. Vevor company has models for around $65 that are ideal. Itās one of those tools you donāt know you need until you have it. Cheers! Geoff
Yes, Then you truly have a missing "knockout" as Craig astutely noticed, and again as he recommended you should let OTT service know by opening a ticket, and reporting such. Be sure to add your OTT model year to your salutation as that helps all responding better understand what the issue may be. B~Out
[Disclaimer I have no association with, or financial involvement with Garmin] Just now, Garmin "Cyclops update for North America software update" available, not sure if new, or the update was not downloaded and applied earlier. The Garmin RV890, If you use this to plan trips, be aware that it is a āReal-Timeā device. By that I mean if you are actively planning a trip during the winter (Nov-Feb, Mar) months, to and through Alaska, the NWT, Northern Quebec, Labrador, or other places where the roads are not passable during the winter months, the RV890 will not allow you to route through these areas during those winter months but may re-route you many ,000 or mi/km via another route. At least has been my experience. As you get closer to your departure date and the routes you want to take are no longer impassable due to snow, the RV890 may (if you choose shortest distance option) allow you to route the trip the way you want to go. i.e., If planning a trip from FL to AK, and you plan on leaving in May, you may not have passable roads in parts of AK until late May, so you may have to wait until closer to AK to get the RV890 to take the route you want. I believe this was done to prevent RV890 users from being routed through unsafe routes, or worse. I do not know if these āGarminā updates which come from time to time would update āseasonalā route openings/closings. My guess is if a route is blocked by a major land/mud slide and it is obvious it is not going to be passable for some time, then that information would āhopefullyā be on a Garmin update. I do know when we were travelling to Tumbler Ridge, BC in ā23 or ā24 while it was in the early stages of a BAD FIRE, the only thing suggesting ānot passableā were the Mounties actively closing roads behind us as we made it to the town, then exiting out our āpre-plannedā route away from the active fire. By the time we were back to an area where we could check our RV890 for routing, the route in had not changed. B~Out
Thanks to all that read and replied! Never found the missing knockout. Searched under the floor with my phone camera and inside the heat chamber. I went ahead and covered it with sheet metal and furnace metal tape, and all is back to normal. As stated earlier, all other ductwork is attached. To answer SNY SD UP, yes, I did modify the ducting to get better flow into the bathroom back a couple of years ago. Our ductwork is similar to yours, featuring one rear flex duct that turns 180° to head towards the front of the trailer, and another facing the front of the trailer. When you say galley side knockout, are you referring to the side facing forward to the galley/kitchen or to the center aisle, as in our case, having twin beds? Our missing knockout faces the center aisel. The photo was taken through the removable acsess port under curbside bed, Thanks again!
And when at a location that i can get a good iNet connection, i will check to see if any updates. I want to make sure that the "navigator" has most recent updates...
Hi Folks - we're hull #1673, 2026 LEII; we live in Maine. I'm reaching out to CGI to try to arrange ceramic coating while they are here; their large number of Olivers coated seems a great recommendation. Also wondering if anyone has any experience / insight on ceramic coating companies in Maine... any thoughts appreciated. Thanks!
Congratulations! Weāve got three left, MN, WI and MI. Not sure when weāll be able to travel north but will probably hit all three on the same trip. Mike
Good idea - I do the same. I know that one of the "system" updates is for the Andriod part of the internal workings of the 890 (and 1090) - so, it must be fairly important. Bill
thank you Bill, I always check for updates before doing anything new on the RV890. One of the Checklist items before we leave is to check for updates. B~Out,
Have you done any mods to the duct work based upon "Snackchasers" post, if so i would look for a disconnect of ductwork from that port. Your Oliver is #1238 what year s/b on your signature? it would be interesting to see if the factory has changed the heater duct runs based upon Snackchasers changes... it appears as though Oliver has changed the open heater ports, so this one appears to be facing the galley, as you can see it from the galley access port. Back in 2020 (our model year) there was one open towards the rear, which must do a 180 to head towards the front of the trailer and one facing the front of the trailer. Our galley-side port still has its knock-out port intact. For me it was like a "Fun House" optical illusion for a minute until realized what i was seeing based upon my 2020 experience.... B~Out
Congrats! Alaska next.....
Congratulations -- that is exciting! Are you heading to Alaska next?
This must mean your ducting is detached from the furnace somewhere, or you have a large hole in the ducting. It's a pain when traveling, but you'll need to get under the curbside bed again to fully diagnose and correct. Most of these furnaces have forced air coming out fore and aft of the furnace. Check there first and then follow the ducting forward. If you can't see it quickly, run the furnace while you have the basement open and you should feel a lot of hot air blowing somewhere! We'll be thinking of you, as you head north and it gets hotter and hotter in Arizona. Have a great trip! š
routlaw, thanks for checking with us šWe did look under the bed thatās how we found the opening and the rest of the duct looks secure. Iāll let everyone know what I find once we get parked for the night.
How long did this milestone take you to achieve? Any idea of the total miles? Congrats! Bill
Thanks, thatās what I was thinking but didnāt see the knockout in plane site. Iām going to take a mirror to see if it slid under the floor. š We are slowly making our way to Alaska from Arizona. Currently in Idaho and we are definitely using the heater. š„¶āļø.
Difficult to tell from the existing picture but it's also possible the duct work has dropped out of the knockout panel. If you haven't already I would move your bed aside, open the hatch from above to make sure the duct has not vibrated loose and onto the floor.
Jd, my Oliver came with Furrion fs65w speakers. They have white grills and at $20 each on Amazon they are a bargain. You might spend as much just changing the grills. I actually looked into replacing the Furrion speakers with Polk Audio DB652 to improve the sound. They have a broader frequency range and the sensitivity is improved from Furrionās 86dB to 92dB. However, they have black grills, would need a 5.5ā to 6ā adapter, and they are about $50 each. The return didnāt justify the cost. I took another route and painstakingly measured the Furrionās speakers Fs (free-air resonance frequency) to determine if a 3-D printed sealed enclosure or baffling would improve their sound. This involved injecting a range of frequencies through the stereo, then measuring the voltage at the speaker terminals through a 10 ohm resistor. The highest voltage was at 188 Hz, which is the point where the speaker resonates most freely. This indicated that the speaker suspension was on the stiff side and improvement was unlikely After all that, just the new IVR stereo was enough improvement that I completely forgot about replacing the speakers. Cheers! Geoff -
The 48th state was Rhode Island. We completed the last fifteen (15) states over the past 12 Months. Newport, RI was a fun town to complete the job.
