Portable solar panel with legacy elite 2 platinum package
Dean and Mary replied to Brian H.'s topic in General Discussion
Thanks, Galway Girl, for the link to your solar panel kit and all the details. I found it very informative. Unfortunately, the cable is currently unavailable. -
Tom and Doreen replied to Brian H.'s topic in General Discussion
Yes, the cover has worked out very well. One of the nicest features is that there is a zipped door panel that allows access to the trailer when the cover is on which works great when checking on or working on the trailer during the winter. -
Mike and Carol replied to Lamar's topic in Mechanical & Technical Tips
The propane cook top has been very reliable and works well for us. -
DanielBoondock replied to Brian H.'s topic in General Discussion
Looks like you also got a branded cover add-on too. That’s nice, I need to get a cover -
It’s just a normal roller shade, nothing unique to Oliver, so doing a general web search on roller shades might help. Mine are working fine but I think (remembering to when I’ve used them before) if it’s kinda stuck just pull down to the bottom of the window to reset the mechanism. Regarding “the others retract to at least 3/4 of the way up” - I think you mean they leave 1/4 hanging when fully retracted? That’s not right, all of mine only leave an inch or two of the shade hanging. Anyhow so far been trouble free for me. The design has been around forever, seems like an early 20th century invention, anyhow should be easy to work with. No, interesting it has an even longer history
Thanks for all the replies. Sorry I haven’t updated sooner. We have been boondocking for several days. I have been in communication with support at Oliver. At first they didn’t understand why it wasn’t working. As they investigated they reported that it appears that the stovetop does pull 1800 w and overloads the 2000 w inverter. The only other major draw is the refrigerator. Even when I turn that off, the stovetop does not come on. I stopped at a Bass Pro the first day to pick up a small 2 burner propane stove so we could at least have coffee in the morning. Not what I was planning when camping. If I had known I would have asked for the propane stove instead of the induction stove. We have the Platinum pkg and I did ask sales at the dealer if people liked the induction stove and if I could use it boondocking. Answer was that it works. I noticed that the induction cooktop comes standard on the Legacy 2026. This isn’t working for us as designed. I have asked for this to be resolved…proper inverter set up or a propane stove retro fit. If you do much camping at Harvest Hosts, BLM, National Forrest, National Parks, etc. w/o hookups, it is a problem unless you run a generator. When we return from our travels we will see where Oliver lands on this. They are considering possible “upgrades” to our camper. I wouldn't see a resolution as upgrades, but will find out. When hooked up to shore power, the cooktop works great. But so far for us, most of our trip, was making coffee or cooking outside on a portable propane stove. -
https://res.cloudinary.com/lci-cloudinary/image/upload/v1734451736/Design Team/Sell Sheets/Lippert_-_Sell_Sheet_-_3000_Series_Windows_OEM_-_2023002334-WEB.pdf https://corporate.lippert.com/products/rv/windows For all the people interested in these other windows, link above. Not easy to fine.
Getting back to this: Looking at the Lippert.com website, I do not see awning-style windows, just the 8800 series sliding windows. Are we sure the manufacturer is Lippert? Are they OEM only? Tim
Thank you Galway Girl for input from your actual experience! Very helpful!
I had this happen and found that one of the spade connections at the pump had come loose. I crimped the spade connection for a tighter fit, reinstalled, all good. A few others have experienced this, as well; simple fix!
Got this working yesterday, using the screws supplied with the light on top and hardware I had in the shop to attach the bottoms. It looked hodgepodge today. I really should fab a proper bracket, but for now I just wanted to fix its appearance. Went to the local HW store and got four short 4mm countersink screws and two Nylok nuts and washers. I had to countersink the brackets further to get the screws flush. The assembly is much better, but now that the light is taller, I noticed two things. The base bracket looks cheap now that you can fully see it. And the height is right at the belly line where the hulls meet, so visually it's not good. It looked better shorter, but now the light is where you need it. If I was to do this again, first I would use the great idea @Steph and Dud B made above; to grab power and use the light switch on the jack. Second I would fab a proper bracket a bit shorter than this one and push it forward a couple inches to get the required angle. Then it's not up against the hull belly line and will look better. It's too late for me re the first idea, but I'll do the latter when I source the right stainless steel stock. Looks like one of those Star Wars robots! It's all the light we'll need to hitch-up and load or unload the truck in the dark when necessary. We now have proper exterior lighting on all four sides! 😎 -
Thanks so much @Galway Girl. I appreciate the information. I have already submitted tickets and called Oliver. I will be on the phone with Truma first thing Monday morning. Bob
As an aside...while Truma is very clear that they only want their technicians doing any updates or changes...I believe Oliver did a bunch of installation of new burner units . Be sure to turn in a "ticket" to both Oliver and Truma. See my PM for some more suggestions. CS
Please read my detailed report that I sent in on this topic attached....I've had truma's replace 3 times. First potential cause - Truma didn't properly tighten the brass fittings internally that feed the burner assembly. Second potential cause - Truma didn't crimp the burner tube assembly correctly, and with travel they rattle out (the burner tubes are like in a bar-b-q and can fall off which causes raw gas to be injected into the burner area for explosive ignition instead of gentle start.) This blog post has 3 goals and was SENT to NHTSA for evidence of why Truma needs to do something to fix their defective mfg process. 1) List symptoms we experienced with our Truma and use photos to illustrate the 3 firebox events. 2) Describe 2 different Truma reported manufacturing defects and show photos illustrating those issues. 3) Describe the in field solutions for each of the 2 manufacturing issues. 4) Show a pictures of the current Truma Burner Unit with all Manufacturing updates in place. The attached PDF is in full detail with picture of what is likely the issue or issues causing explosive ignition. Truma Issues.pdf Hope that helps...remember...you need to report this to both Oliver and Truma in order to get any warranty coverage. Craig Short
rideandfly replied to Snackchaser's topic in Ollie Modifications
@Snackchaser and @jd1923 Appreciate your constructive advice. Looking forward to wiring & testing the unit Monday! 😎 -
Our old Furrion jumbo heads sure are ugly! Your new iRV62 looks sooooo much better, even with the large faceplate which has a clean look! Excellent work cutting out the plastic sheet plus the aluminum sheet for added strength. The wiring should be the easy part. You're 90% there! 😎
I appreciate that. I have opened a ticket and sent a copy of the video to Mike Sharpe. I checked and there are a couple of Truma authorized service centers near where we are (Buffalo/Rochester area). Thanks for weighing in on a Saturday night. Bob
I’m sorry that this is happening and during a weekend to boot. Open a service ticket and see if you can send that video. In any event you’ll have to find an authorized Truma service facility to replace your unit. Maybe get the unit replaced now and take a chance on getting reimbursed after the repair?
Oliver has told me repeatedly that my water heater was not part of the recall. I have had numerous issues but this one is the most serious.
Looks like the burner has fallen apart. I thought that was an ongoing recall for this unfortunately all to common issue. I believe Truma says in this case not to use the water heater. Hopefully someone who has a Truma and has gone through the recall process can help.
IMG_3472.mov Almost hate to post this video, but I am in week 1 of a 4 week loop and just encountered a major issue with the truma. The video speaks for itself. Any thoughts?
During troubleshooting I did raise the nose. I probably exacerbated the problem! Best, Mark
Yes👍
@rideandfly Nice work! That's some clever engineering! -
It you look in the closet, there is a horizontal section of vent pipe about three feet long. If the trailer was parked with the nose up, that section of horizontal pipe would fill with water if the vent cap was off, or water was sprayed up under the cap. That's the only reasonable scenario that would cause blockage of the vent and result in slow drainage. Seems like dropping the nose back down would drain that standing water better than going on the roof with a vacuum. 😁 Us retired folks got to be carful on ladders! Cheers! Geoff
