mjrendon
Everything posted by mjrendon
posting from an IMAC - no issues
You might also want to make sure you have a socket that covers your tow vehicle.
Blue Sky IPN-ProRemote Setup Values (T-105)
mjrendon replied to topgun2's topic in Mechanical & Technical Tips
Please check this thread to see if it is what you are looking for. -
This will cover most Mine are 19mm.
Upgrade to lithium batteries blows circuit boards....?
mjrendon replied to John E Davies's topic in Ollie Modifications
You are correct. My 2017 Oliver owners manual shows furnace fan and ignitor at 4-8 amps. -
@John E Davies posted this link in another thread - 10.3 amps for the furnace fan -
This is great information. I had Oliver check this inlet port in October and they mentioned tightening with a hex wrench then. They checked it and said there was no problem. After returning to Austin I still had the same issues as before. Ordered a wrench and found that the hex nut was tightened properly.
I picked up the trailer last night and tested the inlet with two washers and it did work without the normal coaxing that I had done previously. I also placed the bucket of water on the bumper to improve flow. I have ordered new screen washers to replace the original ones.
The winterize inlet on my Oliver Elite II trailer requires me to apply pressure in just the right spot/angle to get it to start pulling water or antifreeze into the water supply lines. Sometimes it seems as though it is never going to start pulling. Any tips on how to get this inlet to work more consistently? I am typically using a short white hose with standard threads attached to the inlet and then dropping that into water or antifreeze.
This is a timely topic and tip for me as I am headed to Big Bend SP on Thursday through Monday. On Sunday and Monday the temperatures are going to be too cold to use the Oliver's water system (or for mountain biking) as they are expected to drop to 12F and stay below freezing for over 24 hours. The trip back from Terlingua to Austin will be chilly one too.
My RV insurance provider (GEICO) does not offer roadside for RVs but does offer roadside for tow vehicles. I signed up for coach-net roadside but have not needed to use it yet. Price was $179/yr for a long list of benefits. Coach-net was rated high on several RV youtube channels.
We have reached another milestone!
mjrendon replied to SeaDawg's topic in How to Join and Use Oliver Travel Trailer Forums
Oliver makes great products and obviously values supporting a healthy community where owners and interested parties can ask and answer questions, share ideas and otherwise communicate. A big thank you and high marks to the administrators and moderators for keeping the forum on a positive path. Both of these roles can be difficult and often times thankless, but in my opinion are being done consistently well here.- 11 replies
- 11
Richard, Check this thread for the information you requested. Mike
Overland, Could you describe the failure symptoms, if any? If the BMS was working correctly, a failure would result in the two of the four batteries going offline, leaving you with functional system but with 50% lower capacity. Even if three of your four Battleborns had failed in this manner, you would still have a functioning system. DId Battleborn provide you with any insight into the failure mechanism yet? Thanks, Mike
Is there an enforceable household rule that goes with your timer or is it just for your own amusement?
Topper vs. Soft Tonneau Cover Vs. Hard sectional Cover
mjrendon replied to SNY SD UP's topic in Towing an Oliver
I also have a folding cover on my Tundra and very interested a bike rack like FrankC has. It has been great to hide/lock things in the truck while traveling. FrankC, Thank you for posting these pictures of your bike rack. Would you PM me the parts list? -
Wow! AMAZING craftsmanship! I had some initial concerns over the potential for terminal stresses but less so after noticing how the batteries are butted together, which should provide for significant stability that would be difficult to achieve using four of their standard batteries. I am very interested in, if and how you are going to strap the four batteries together.
Note that the threaded side of the u-bolt is on the keyed side of the housing, otherwise the u-bolt will slip out.
Why do RV appliance suppliers build systems that can not tolerate voltages greater than 13.6V? Options other than installing a regulator on the fans might include placing a diode (or two) in series with the fans. Most diodes have a forward drop of ~0.7V per diode. This would be much less expensive and likely more reliable than the regulators. However the voltage drop from the diode(s) would also occur when the battery was in a low state. -
I know the alternator output was mentioned before. The fan may not be running when the alternator is active. Oliver systems with solar likely see these voltages daily for extended periods. ZAMP charge controller Absorption charging voltages at 25℃ from manual --LTO type battery 14.0 +/-0.2 VDC - -Gel type battery 14.1 +/-0.2 VDC --LiFePO4 battery 14.4 +/-0.2 VDC --AGM type battery (default setting) 14.4 +/-0.2 VDC --WET type battery 14.7 +/-0.2 VDC -
Do you carry a spare or would you bypass in event of a failure? Mike -
I swapped out the original fridge board with a Dinosaur, but that was for a Dometic board failure unrelated to higher Li charging voltages (was using 4xAGMs then). I am happy with the Dinosaur board's performance so far (1+ year) with Li (Battleborn) since October. I would imagine that the solar charger outputs are over 14.2v at times as well??? -
Very nice! I like that the ground is switched.
