Jim and Frances
Jim and Frances last won the day on March 19
Jim and Frances had the most liked content!
2 Followers
    927
3,995 profile views
Jim and Frances's Achievements
Community Regular
Community Regular (8/14)
319
  1. I have heard of no Oliver / Garret awnings unfurling. My friends were in an Escape (Canadian) trailer. I don't recall the brand of awning but they were electric. I decided to do this after I noticed our curb-side awning was a slight bit ajar while on the road. It was not fully embedded in the housing after some high winds while camping. After I adjusted the motor, all was fixed. Yes, I should have done a more careful walk-around prior to leaving after the high winds. I also adjusted the wind/motion sensor to be more sensitive. Was not trying to suggest any problems with our Garret awnings. Just one less thing for me to worry about - hence my "suspenders and a belt" comment. Or, one is none and two is one. 😀
  2. Having seen and talked with owners (non-Oliver) that have experienced awning unfurlings at 60MPH, I added some inexpensive safety straps to our awnings. (As Justin Wilson use to say, "I wear a belt with my suspenders 'cuz I'm a safety engineer"). The actual straps work great. The buckles will start to rust after a year or so but are inexpensive to replace. UV will also likely reduce the strength of the straps so it's on our recurring maintenance replacement list. The "lock out" indicators help me from opening the awning with the strap on, which assuredly I would do! Parts used listed below. Straps from Amazon Red Velcro for "Lock Out" indicators Small Circular White Velcro Dots w/ Adhesive
  3. Congratulations!! I am sure you and your wife will have years of fun and excitement with your Ollie. The folks on this forum will bend over backwards to help - I know this first hand!! What's that old saying...the only stupid question is the one unasked 😀
  4. Someone has had the same idea....I would not use either LOL (First from Etrailer.com, second from Home Depot).
  5. Be sure to check the internal wiring of the external Zamp connector - ours was 12 AWG. Per wire calculators even with short lengths, you may have some issues at the amp loads you are estimating.
  6. We've been using the Zero-G hoses for several years now. No issues to date. They are approved for drinking water and store easily. Also, since I am lazy and have a bad back, we use the stainless quick connect fittings on the trailer and all our hoses. Fast and easy! (The more expensive stainless fittings are much better than the brass ones - which tend to leak a bit.) Hope this helps!
  7. Saw this nice LE11 yesterday by the Buc-ees in Madisonville, TX. Howdy ya'll!
  8. @burntcookie As previously stated, the level of knowledge, help and support on this forum is outstanding. Lots of experience that is readily shared. We've made several mods on ours and help has always been there. I can't say enough good things about this group - a huge advantage of owning an Oliver that is not really marketed enough! (No, I am not getting paid for this announcement 😄)
  9. No prob....I've got the B5, it's the B4 I for which I am hunting.
  10. @jd1923 I've attached copies of the electrical pages for the 2021 LE2 from the Oliver manual...is this what you needed? Thanks again for your and @Snackchaser's help! I will do some more searching! Electrical Pages from OTT-2021-Owners-Manual-compressed.pdf
  11. Can anyone tell me where is breaker "B4"? This is on a 2021 LE II. Also, not sure what the "charge line" means. Is this the 12V charge line coming in from the tow vehicle? Thanks for your help!
  12. A fan??? So wrong!!! I kinda enjoy having sweat dripping whilst trying to apply ceramic coating - NOT. 😉
  13. I was in the process of replacing brakes and hubs last week and one of the brake plate nuts was loose enough to turn by hand. I had not checked these torque marks in over 3K miles. I don't think this one loose nut had any thread locker applied. All the others did. My bad and lesson learned. As for brake magnets, it appears one of our self-adjusters was not adjusting very well, resulting in excessive wear of the magnet. Noticing uneven magnet wear when removing hub for other maintenance is a good sign your "self-adjusters" are not adjusting evenly. As compared to other magnets. I am a slow learner....but am still learning! 😀
      • 4
      • Like
      • Thanks
      • Love
  14. @Ronbrink Oh what I would do for some of that shade! 🫠
  15. Is yours part of the recall? If yes, could your burner element have shifted? Just throwing it out there as an idea. Mine is part of the recall and I await replacement burner element and worry about it in the meantime 😮 - hence my first thought.
