CRM
CRM last won the day on October 19 2025
CRM had the most liked content!
2 Followers
    Tampa
    45
    2010
2,854 profile views
CRM's Achievements
Mentor
Mentor (12/14)
  • Posting Machine Rare
1.3k
  1. 55k in 2016 is around 76-77k in today's dollars. Though as you say- there more standard options these days.
  2. I see Steve was able to fit three 300ah batteries into his tray. Didn't you have to remove yours to make them fit? Different size trays, or did battery dimensions change?
  3. This one off Amazon should work fine and you shouldn't have to do any rewiring. Waterproof Reverse Polarity Switch
  4. I'm looking at these Vatrer batteries now myself. Can't beat that price for 900ah for what seems to be a decent quality brand.
  5. Haven't bought anything yet, just still in the beginning of the planning stage. And that King antenna was removed within days of buying #45... Ended up bringing it to @mossemiwho also lives here in Tampa. Have to get my son off to college and complete the move to our new place in Floral City Fl, but once that's done, upgrades will be priority #1!
  6. Nice, though I'll probably stick with the 3k model for size and weight. I know it's not too much, but I don't think I'll ever need that much power in my rig. BTW, it won't be long now before I'll be adding solar and lithium- so be ready to get your brain picked! 😂
  7. Actually, according to Morton's testing, the Turbro is a fair amount more efficient than the Chill Cube in BTU's per watts... though I have no doubt that the Chill Cube is quieter and has better temperature control. I still wouldn't recommend the Turbro to anyone not willing to modify it as much as I did mine, though. One I would take a close look at is the new Furrion low profile with heat pump unit that *looks* to be the same outside unit as the Turbro but also *looks* to have fixed most if not all the issues I have with the Turbo, especially the ability to have a wired external thermostat. Going to try and check one of these out in the wild to see how they perform. I have a brother looking to upgrade his Dometic and might give him my Turbro if it works as advertised.
  8. I'm so sorry, that was not my intention! I just didn't want to see you treating them as non-maintenance sealed bearing hubs if they were in fact standard bearings.
  9. My wife would have made me stop for a pic for sure!
  10. Glad you got out! Situations like this is why having four wheel drive is at the top of my list for a TV. Won't go without a front hitch either.
  11. Good to know... Thanks. Thought they put that on the label from a prior discussion about the Nev-R-Lube axles.
  12. Are those axles Nev-R-Lube? I thought the Nev-R-Adjust label was only on the standard bearing axles.
  13. A short clip that some may find useful. It shows just how easily an inverter A/C unit ramps up and how it allows a much smaller generator to run it safely as compared to a standard compressor A/C unit. While this was on a Greenland Turbro, the numbers and ramp up profile should be very similar with any of the current units on the market. This test was using a Honda EU2200I generator and the readout is in volt-amps and not watts. VA actually topped out at 970VA but the video stopped right before the peak. After running 15 min power draw leveled out around 600VA and then down to 400VA after an hour or so. Should be able to get 6+ hours runtime on the .95 gallon tank if the A/C runs continuously. Not my plan to ever have to use the generator to power the Ollie, I just wanted to know how it would perform in an emergency situation where we're left without power for several days. Something everyone here in Florida thinks about during hurricane season! Video Project 8 (1).mp4
  14. Looks like they modified a Turbro unit like I have and fixed most or maybe even all the features I don't like about it.
  15. Before the shutdown Oliver was planning something similar with the "Sport" package. Check out the price for the "Appliance Package" add on... 😲
