Everything posted by csevel
The shower hose I purchased was a stainless steel hose on Amazon: https://a.co/d/0dgsEMfQ It was very straightforward..open the street side access hatch and a little teflon and you're golden! I have had it on there for five years and it fits just fine and hasn't bound up inside the compartment. Here are a couple shots of the suction mount. It's a ratchet style with two additional suction cups below it for some added strength.
Hi Oliver Family.. It’s been quite a while since I last posted around here, but I just finished a quick little mod for the exterior shower station on the ILOVHER. I do use and absolutely love my wet bath inside the trailer! But before the forum gray-water police sound the sirens: having managed a National Forest campground for five years, I promise I know the rules about gray water and where it belongs. I know there are plenty of places out West that actually permit surface gray-water disposal (and, funny enough, with the wildfire season we're having, the ground could probably use every stray drop). For this upcoming trip, I'll be boondocking in a private field for 12 days, and the owner doesn't mind me showering outside. I'll be using organic, biodegradable shampoo, and with no dump station for miles, keeping gray tank fill to an absolute minimum is the primary mission here. I considered one of the standard pop-up privacy tents, but having used a bicycle tent for camping, I could already envision the poles, stakes, folding/unfolding and general tent wrestling that would be involved. I was looking for something much simpler — something I could put up in a couple of minutes and take down just as quickly. I also wanted to avoid the usual problem of routing the shower hose into a privacy tent. You either have to run the wand through the main zipper opening, which can make the entrance/exit awkward, or start modifying the tent itself. Then I stumbled across these ratchet-style suction arms, and I immediately started thinking, "Oh, I can do something with these!" They reminded me of the SeaSucker-style mounting systems, and the Oliver's smooth, gelcoat fiberglass seemed like the perfect surface for them. I was so excited about the idea that I put the whole thing together and actually showered in my driveway last night just to test it out. 😂 And honestly, I think these are going to work perfectly! The Setup: Ratchet-style suction arms: I found these folding rack arms on Temu. Say what you will about ordering direct from China, but the mechanical ratchet suction on these things locks onto the fiberglass extremely well. They’re designed to hold weight and, so far, they’ve been remarkably solid. DM me if you want the link to the product. Curtains & rings: I used standard shower rings through the cutouts and repurposed heavy shower curtains I already had from a previous project and the bar that goes between the mounts is a simple tomato stake zip-tied tight to the ends. (I may reconfigure that at a later date with tool clips) No modifications to the Oliver: Nothing is drilled, screwed, glued or permanently attached to the trailer. The whole thing takes less than two minutes to set up, packs down flat, provides total privacy (other than wind, LOL) and gives me direct access to the Oliver’s outdoor shower faucets without having to wrestle with a tent or poles. I even have a suction mount for the shower wand. Please note that I have replaced the original ss shower hose with one that is 120" on my ILOVHER. Attached are the suction arms mounted to the Oliver and the full enclosure deployed. I’m pretty pleased with how simple this turned out!
- 7 replies
- 12
Hi Oliver Fam, I'm hoping to hear from owners who have actually serviced the Dometic RM2454 burner system in an older Oliver installation. I haven't been on the forum for a while, but I own Hull #184 (2017 Legacy Elite II). I also had the same RM2454 three-way refrigerator in my Casita for about 10 years before moving to the Oliver, so I'm fairly familiar with the unit. Recently, I've noticed the refrigerator is not cooling as well on propane as it does on electric, especially when ambient temperatures are over 80°F. The flame appears normal, steady, and blue with no orange/yellow. The fridge was in normal use at the time—not empty, but not heavily packed or overfilled. I've already worked through the usual troubleshooting steps, including adjusting the thermistor position, running the auxiliary cooling fan, and reviewing common recommendations from both this forum and elsewhere online. At this point, I'm trying to determine whether the issue is related to a dirty or partially restricted burner orifice, a partially obstructed burner, propane pressure, or something else in the LP system. I've attempted to access the burner compartment, but even getting to the baffle screw was more difficult than expected due to the tight working space and awkward access. Looking at the burner/orifice area and chimney, it doesn't appear to be a straightforward space to work in with wrenches. Most of the access is on the right side, and as a right-handed person with some limitation in my left hand, it feels like a very constrained area to safely get proper tool control. For those who have actually worked on this specific installation: Were you able to clean or remove the orifice for cleaning in alcohol? Have you checked propane regulator pressure as part of diagnosing this issue? What tools or approach worked best in this tight access area? Was it realistically doable, or did it turn into a refrigerator removal job? Any lessons learned or "wish I knew this first" tips? I'm not currently looking to replace the refrigerator. I also carry a separate 12-volt auxiliary fridge, so I have some flexibility. I'm mainly trying to understand whether this is a reasonable maintenance task or one that effectively requires pulling the unit. I have cleaned a gas jet before (a few times) on my Casita as part of maintenance. Those who know me from the forum know I tend to be a very hands-on owner and do most of my own maintenance work when possible. I have the interest, but sometimes not the tools or mentorship to pull it off. Appreciate any firsthand experience. Claudia Hull #184
' ILOVHER ' ~ 🙂
Progressive Dynamics Converter/Charger needs home
csevel replied to DavePhelps's topic in General Discussion
Dave, What is your asking price for the charger? I bought one off of Ebay from Canada that included the 'Li' switch for lithium.. however, I'm disappointed because after install, I still have a high pitch sound coming from it when under load from lights, etc. I'm not sure if it was a defective part but I'm not going to go through the hassle of return. -
The tank was full when I noticed the leak so, no. I'm going to try John's suggestion today!
The drip did not significantly increase when the pump was activated. The DH looked while I ran the pump. If I have to replace the backflow/check valve...what size is it? There are soo many to choose from on Amazon!
The leak is visible from the outside only and the hose is NOT connected. I'm not trying to fill or anything actually..the tank was full. I just noticed it dripping when I was walking around the trailer.
Over the last week or so, I've noticed a drip from the fresh water inlet. It drips about every two seconds. I tightened the fitting with a 1/2" Allen key but it did NOT solve it. I don't exactly know where to look next!? Any tips, links and/or advice appreciated! Here are some shots of my pump set-up and the basement (what I think are the hot and cold check valves)...
Posted - then sat with it and figured out my problem..YAAAAY! - MODERATORS you can remove if need be 🙂
Way ahead of ya.. done and done like
I want to remove the roof-top omni antenna as I simply do not watch television while camping (or even at home, lol) I removed the television as one of my first mods on the ILOVHER and now I'd like to remove the antenna; it's just personal preference. It's a bug collector and it spins and rocks uncomfortably up there and snags on the cover. In addition, someday I'd like more room for solar panels. We download and play movies in inclement weather on our tablets and listen to music on a BOSE blue tooth speaker so FM channels aren't necessary either. I realize I may want to keep the antenna and/or wiring if I ever sell, but I'd still like to remove it, save it and cap it off. Does anyone have any suggestions or tips to remove it and/or what I could possibly use to seal the holes and/or cap it off? Thanks in advance, Claudia
Too late, but that's a helpful tip. The product (which I have seen many iterations of on Anazon) was also of a cheap rubber/plastic material. The color was off too and I simply knew in my gut I was making a mistake installing it. At least it came off easy and I can start fresh! Seriously hoping the Trim-Loc is better overall.
I managed to easily rip the gutters off before trash day in 50 degree weather. They came off without hardly pulling and very little tape to scrape off. I hope the Trim-Loc will be a better product.
I think the EZE RV Rain Gutters is the product that was used originally on my Oliver by the previous owner. The least expensive I could find was $145 for 50 feet. I ordered 25' of the Trim-Loc from Amazon for $65; hopefully it will be the same quality
Since this is not my first, second OR third try... I'll be really good at it so line up ten or so Ollies and I'll simply do them all!! LOL
Thank You! I plan on using about 31 feet or so because I want to bring the ends down alongside the windows like John E. Davies so two rolls for me!
I'm aware of the posts and did in fact do my install on a hot day with tape. It sat for three days in warm weather... My Casita had drip rail as well so it's not my first attempt...Just wanted to help new owners be aware of the bad product.
Unfortunately, the Trim-Lok Brand in white seems to be sold out on many sites. May have to go direct. I Agree.. Taking it off twice should be fun times 😞 I actually think it prevents having to re-caulk the top of the windows. Claudia
Just a heads up, I recently had to replace the window rain gutter trim around my windows because the original trim was never brought down far enough along the edge of the window and they were starting to peel and come off exposing the 3M tape and simply not doing the job intended and leaving longer black streaks than I like. DO NOT PURCHASE THIS PRODUCT FOR YOUR OLIVER: https://www.amazon.com/dp/B0D98165TN?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 It's horrible. It was purely my decision to go ahead with the install even though the color was a bit off and not nearly the quality of the original gutter. The tape is crap and even though I installed on an 85 degree day and let it sit for days, the rounded corners lifted on the first rain and it looks awful. Again, I knew that there was a chance that I'd have to peel it all off and start over..but I took the gamble. Just know, it's an inferior product. The lower price point should have tipped me off... I'm hoping this product is superior at more than twice the price: https://recpro.com/rv-rain-gutter-trim-with-adhesive-backing/?srsltid=AfmBOopQirOHpRVjMz9qYBNAXXOuiSK1bDn8mqsrwrVR8CRQd1liPtrE Let me know if you have had better luck with RecPro. My research suggests the original product was made by Essential Products called EZE RV Windshield Gutter, but I can't find it anywhere. Live and Learn, Sigh, Claudia
Is this the gray tank vent in the bathroom vanity?
csevel replied to Steve Morris's topic in General Discussion
I spent some time under the sink trying to locate any loose fittings and found nothing. I did find out that the black tank from under the dinette seat was a contiguous open area (which I simply did not know) so any smell I had under the dinette was in the sink area too except not as pronounced. I decided to just leave well enough alone and spray OdorBan everywhere as per Ronbrinks suggestion in my original post, including the valves. I put some https://bit.ly/3BLgPdG in there and haven't had smell since. Not sure if warm weather will reactivate it next year but I'm really glad I opened the area up! I may want to change out my faucet someday, check p-traps etc.. and it was pretty simple to do. Thank you for the gasket material you gave me at the rally, however, I didn't end up using it as I thought it might be too hard to place around the perimeter of the cubby. I used this instead: https://bit.ly/3A0quwj It's channel shaped and easy to route. Everything went well. I used the original screws and snap caps even though I had bigger ideas in the beginning. For the number of times I'll actually go in there, it wasn't necessary to use plus nuts and get all crazy. So far no leaks and it looks stock. Good Luck Steve! Let me know if you find anything more. Regards, Claudia -
Beech lane levelers for for Legacy Elite II
csevel replied to a topic in Mechanical & Technical Tips
I have the Rapid Jack and a regular Andersen leveler. I purchased an extra chock directly from Andersen. I tend to find the best campsites that are always unlevel! -
I have been using this hose with a quick connect fitting and I love it. https://www.amazon.com/gp/product/B0894GMDWP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Time to review your insurance! RIP hull 686.
csevel replied to BlueHighways's topic in General Discussion
So sorry for your loss but how exciting to order a new Oliver! I went through a whole process with National General Insurance for Agreed Value and it took forever. I hope in the event of a loss of our ILOVHER that the insurance will be there. Good to note all of your documentation was helpful. -
Just to follow up on this post... I finally scraped away the caulking from the towel bar in front of the bath vanity to investigate whether I had a detached vent pipe. It wasn't nearly as much a chore as I anticipated...took all of 15 minutes! To my dismay there isn't any loose pipes or fittings. There is a faint black tank smell in that area but I was unaware that the space around the black tank is contiguous with the space under the dinette seat...so any smell I have there would also be inside the vanity. I'm still perplexed as to why there is a smell at all but I'm assuming my sniffer is just overly sensitive. I'm happy that I tackled this as I'm going to use a gasket around the towel bar (thanks Steve Morris) to prevent water intrusion and keep it accessible for the future in case I purchase a new faucet. I'm just going to use the original screws and snap caps to secure it down since I don't anticipate going in there very often.
