serge Posted April 20, 2024 Posted April 20, 2024 Hi, I am in the process of replacing the touch lights in my unit (4 out of 5 failled) and I am encountering a problem with the circuit that controls the touch lights, reading lamps, bathroom and closet, they all work but they are extremely dimmed. My unit has the 2 lithionics batteries and the currently show 13.4 V, however when I test the power at the touch light I am only obtaining 11.8 V All the other 12 v system seems to be working just fine, main cabin lights, jacks… Hence any assistance in figuring out this problem would be greatly appreciated. Regards and thank you in advance for your responses. Serge Hull 864
Moderators topgun2 Posted April 20, 2024 Moderators Posted April 20, 2024 (edited) Chances are pretty good that you have a loose ground wire somewhere in your system. I'd start at one end and tighten every ground wire I could find. If that doesn't do it then I'd recheck all connections - also paying particular attention to the negative/ground side of things but, since you are there, you might as well check the positive side at the same time. Good luck! Bill Edited April 21, 2024 by topgun2 spelling 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted April 21, 2024 Posted April 21, 2024 (edited) @serge If the suggestions of @topgun2 don’t seem to correct your issue consider submitting a work ticket to Oliver. They may have additional trouble shooting info to help you isolate the problem. Someone else might chime in that has had a similar experience. You may even want to call Oliver Monday morning. Edited April 21, 2024 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
serge Posted April 21, 2024 Author Posted April 21, 2024 Thanks guys for the responses, I will try to check the ground and get back to you with my findings. Regards, Serge
jd1923 Posted April 21, 2024 Posted April 21, 2024 I understand touch lights were added at some point. Our older hull does not have them and I'm happy for that. Is every light a touch-light? Do you have lighting switch panels to turn on/off Main Lights, Kitchen Lights, Courtesy Lights, etc.? If so, I would remove all the switch lights for standard hardwired lights. Switch lights gives you a point-of-failure at every light location. 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
MAX Burner Posted April 21, 2024 Posted April 21, 2024 10 hours ago, jd1923 said: I would remove all the switch lights for standard hardwired lights. Concur, 100%, John! Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Boudicca908 Posted April 21, 2024 Posted April 21, 2024 In my 2022 there are no light switches. The 'touch lights' are all tap on/off, and the 'reading lights' are turned on/off by pressing into the lens. I'm following this thread because a couple of my touch lights are flickering at this point. 1 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Wandering Sagebrush Posted April 21, 2024 Posted April 21, 2024 10 hours ago, jd1923 said: <snip> Switch lights give you a point-of-failure at every light location. I am old enough to remember strings of Christmas lights that were wired in series, and changing each bulb in an effort to find the one that burned out. 1 1 1 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Moderators topgun2 Posted April 21, 2024 Moderators Posted April 21, 2024 1 hour ago, Boudicca908 said: In my 2022 there are no light switches. The 'touch lights' are all tap on/off, and the 'reading lights' are turned on/off by pressing into the lens. I'm following this thread because a couple of my touch lights are flickering at this point. Ya might as well plan now for the day when you replace those lights with regular "switchable" ones. If you are coming to the Rally, be sure to look up Patriot. He can give you the details on the ...... switch. Bill 1 3 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Boudicca908 Posted April 21, 2024 Posted April 21, 2024 8 minutes ago, topgun2 said: If you are coming to the Rally Sadly, I won't be at the Rally this year. But I'll watch here on the forum for threads to this. Happily, I'm already on the road -- enjoying the glorious wildflowers of Texas! 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
serge Posted April 21, 2024 Author Posted April 21, 2024 Issue resolved, after testing grounds, switches, etc. turn out that the issue was with the fuse… although it was burned the Led indicator beside the fuse was not lighted, the light indicator only turn on if when one of the reading lamp was turned on and the fuse removed. Furthermore there is still some power circulating in the system with the fuse removed. Pretty awkward, but with the fuse replaced all returned to normal and was able to install new lights to replace the original touch light. Thanks again for the guidance and assistance. Safe travel. Serge 1 4
Ronbrink Posted April 22, 2024 Posted April 22, 2024 (edited) 21 hours ago, Boudicca908 said: I'm following this thread because a couple of my touch lights are flickering at this point. I’ve had four touch lights, one of which in center ceiling, that either flickered or would not come on or go off. Upon removing the cover, a simple cleaning of dust within and adjustment of the spring (in center fixture) solved the problem. Also, I find that a ‘gentle touch’ of back of hand rather than a ‘hand bump’ is best for operation. Thinking maybe the ‘bump’ method is causing the spring to move out of optimum position. Edited April 22, 2024 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators topgun2 Posted April 22, 2024 Moderators Posted April 22, 2024 2 hours ago, Ronbrink said: Thinking maybe the ‘bump’ method is causing the spring to move out of optimum position. 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Boudicca908 Posted April 22, 2024 Posted April 22, 2024 2 hours ago, Ronbrink said: a ‘gentle touch’ of back of hand rather than a ‘hand bump’ I use a finger to tap it, but I'll definitely check them for dust and the spring alignment -- thanks!! 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
