MikeKaren Posted May 2, 2024 Posted May 2, 2024 2023 LE2 #1309. Our High Pointe microwave/convection oven has apparently failed. It will only run for 2-3 minutes before shutting off. I think we have isolated it to the actual oven because I ran an extension cord from our garage directly to the plug for the oven and it didn't change anything. These ovens only have a one-year warranty so we are going to have to replace it. My questions are: has anyone used a different brand and had a good experience? How difficult is it to change out? Any suggestion on where to get one? I've searched online and the High Pointe is not very widely available. Rec Pro seems to be the more popular choice. thanks in advance. Mike Gutting 2 Mike & Karen - Marietta GA 2023 LE 2 - Hull 1309 - 2022 Toyota Tundra
Moderators topgun2 Posted May 2, 2024 Moderators Posted May 2, 2024 Mike - If you are at all "handy" you might try seeing if you can repair that thing yourself. I've repaired a couple of ours and the parts are fairly cheap and available for most microwaves. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John Dorrer Posted May 2, 2024 Posted May 2, 2024 (edited) 7 hours ago, MikeKaren said: 2023 LE2 #1309. Our High Pointe microwave/convection oven has apparently failed. It will only run for 2-3 minutes before shutting off. I think we have isolated it to the actual oven because I ran an extension cord from our garage directly to the plug for the oven and it didn't change anything. These ovens only have a one-year warranty so we are going to have to replace it. My questions are: has anyone used a different brand and had a good experience? How difficult is it to change out? Any suggestion on where to get one? I've searched online and the High Pointe is not very widely available. Rec Pro seems to be the more popular choice. thanks in advance. Mike Gutting Just out of warranty? That is a bummer? Edited May 2, 2024 by John Dorrer 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
QuestionMark Posted May 3, 2024 Posted May 3, 2024 (edited) Check out this old post here on the forum (Toshiba EM925A5A-BS): Edited May 3, 2024 by QuestionMark Added model number 2020 F250 Lariat Supercrew 6.7 Diesel 4x4 2020 Oliver Legacy Elite I * Hull #664 (April 2, 2022 Incident) 2017 Oliver Legacy Elite II * Hull #293 (Purchased Used April 16, 2022) YouTube @OliverTravels293 Located SE Texas Region
MikeKaren Posted May 3, 2024 Author Posted May 3, 2024 2 hours ago, John Dorrer said: Just out of warranty? That is a bummer? Yes, it is. It seems like the components should have more than a one-year warranty. Mike & Karen - Marietta GA 2023 LE 2 - Hull 1309 - 2022 Toyota Tundra
MikeKaren Posted May 3, 2024 Author Posted May 3, 2024 47 minutes ago, QuestionMark said: Check out this old post here on the forum (Toshiba EM925A5A-BS): Thanks very much. This will be helpful when I attempt it. I really appreciate it. Mike 1 Mike & Karen - Marietta GA 2023 LE 2 - Hull 1309 - 2022 Toyota Tundra
dewdev Posted May 15, 2024 Posted May 15, 2024 @MikeKaren FYI Our home GE microwave-convention oven stopped working after using the convention oven portion a number of times. The unit was repaired by a appliance repair person who told us to only use microwave portion as the unit is not well designed for the heat of the convention oven. We have a stove with a convection oven and use that as the heat does not bother it. 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Wandering Sagebrush Posted May 15, 2024 Posted May 15, 2024 On 5/2/2024 at 8:51 AM, MikeKaren said: 2023 LE2 #1309. Our High Pointe microwave/convection oven has apparently failed. It will only run for 2-3 minutes before shutting off. I think we have isolated it to the actual oven because I ran an extension cord from our garage directly to the plug for the oven and it didn't change anything. These ovens only have a one-year warranty so we are going to have to replace it. My questions are: has anyone used a different brand and had a good experience? How difficult is it to change out? Any suggestion on where to get one? I've searched online and the High Pointe is not very widely available. Rec Pro seems to be the more popular choice. thanks in advance. Mike Gutting Mike, our Oliver came with a microwave delete, the first RV we’ve owned that didn’t have one. We don’t miss it. The increased storage is much appreciated. 2 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Wandering Sagebrush Posted May 15, 2024 Posted May 15, 2024 (edited) 1 hour ago, Wandering Sagebrush said: Mike, our Oliver came with a microwave delete, the first RV we’ve owned that didn’t have one. We don’t miss it. The increased storage is much appreciated. Okay, one exception to the missing part… Having burned the daylights out of it, I was reminded of my total fail with Jiffy Pop. I do miss being able to toss a bag of Orville Redenbacher into the microwave and have unburned popcorn. However, I did learn the secret to Jiffy Pop is to hold the pan about 2” above the flame. Edited May 15, 2024 by Wandering Sagebrush 1 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Jim and Frances Posted June 14, 2024 Posted June 14, 2024 Just as an aside, when using the "convection" oven feature, there is a chance that the oven will "go dark" after the cooking cycle. By going dark, I mean the panel is bank and the interior bulb is not on when the door is opened. This is the overheat thermistor triggering (ours goes off now at after about 30 minutes @ 350F). We open the door, let it cool down (and heat up the cabin 😞). It cools down and resets. I have searched for a schematic for this oven but so far can't find one online. Maybe there is one inside the oven? As @topgun2 mentioned above, this particular problem should be an easy fix but not sure that is what is causing your problem. 1 SE Texas | 2021 Elite II Twin Bed # 927 "Lucy" | 2019 F250 FX4 6.7
MAX Burner Posted June 26, 2024 Posted June 26, 2024 On 5/15/2024 at 7:32 AM, Wandering Sagebrush said: I do miss being able to toss a bag of Orville Redenbacher into the microwave and have unburned popcorn. OK, so we're popcorn folks - not quite junkies, but close. The collapsible Pampered Chef microwave popcorn bowl does a great job "not burning" Orville's corn - slam a few dollops of Kerry Gold salted Irish butter into its integrated dispenser on top - and poof! A couple minutes later - heaven on earth! Yum 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Moderators topgun2 Posted June 26, 2024 Moderators Posted June 26, 2024 57 minutes ago, MAX Burner said: OK, so we're popcorn folks - not quite junkies, but close. Me toooooooooo! 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
