Steph and Dud B Posted May 5, 2024 Posted May 5, 2024 Well, Eggcelsior has failed us again. This time it's the furnace. I have airflow, can smell gas, and hear the ignitor ticking, but no ignition. I would clean and gap the ignitor electrode but I can't find it. Anyone know how to access it? It's 46 degrees outside. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
rideandfly Posted May 5, 2024 Posted May 5, 2024 (edited) Here's John Davie's thread about how to service a Suburban furnace: Edited May 5, 2024 by rideandfly 2 2015 LE2 #75 / 2024 F-150/5.0L
rideandfly Posted May 5, 2024 Posted May 5, 2024 (edited) Here's a parts breakdown link for Dometic/Atwood furnaces: https://pantherrvproducts.com/dometic-afsd20-atwood-rv-propane-heater-furnace-18k-parts-breakdown/ Edited May 5, 2024 by rideandfly 2 2015 LE2 #75 / 2024 F-150/5.0L
rideandfly Posted May 5, 2024 Posted May 5, 2024 (edited) Here's a YouTube video about cleaning a Dometic/Atwood sail switch: Edited May 5, 2024 by rideandfly 1 1 2015 LE2 #75 / 2024 F-150/5.0L
MAX Burner Posted May 5, 2024 Posted May 5, 2024 @Steph and Dud B - This might be a long-shot but it worked for us a while back, actually D's idea not mine. But configure your compressor head with a long outlet tube and hit the area of the ignitor, gas valve, and sail switch with compressed air (the general area that you can access from this section of the heater). Not super high, maybe 20-25psi. For us, it blew away any small debris/dust from the ignitor and it was able to light the burner. Good luck! 1 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted May 5, 2024 Posted May 5, 2024 OK, I'm confused. Is it a Dometic or an Atwood? From the Panther sites, it appears that the Dometics are not the Atwoods. Please clear my foggy mind or some strong coffee! Which model does our our OE2's have GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted May 5, 2024 Posted May 5, 2024 9 minutes ago, Geronimo John said: OK, I'm confused. Is it a Dometic or an Atwood? Doesn’t Dometic just rebrand many of their products? Could it be sold by Dometic, manufactured by Atwood? April 2018 OTT Service replaced our Suburban furnace with an “Atwood Furnace with outside door.” Reason, “Customer states furnace fan rattles intermittently, Customer requests to remove Suburban and install the Atwood 20K furnace.” 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted May 5, 2024 Posted May 5, 2024 My 2018 Owner's manual shows I have this one. But the below does not seem to match the above. So since I am wanting to purchase a thermocouple for MY unit, which parts list would I use from the above? Sure wish I could just walk out to my imaginary Texas Man Cave and look myself..... GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Steph and Dud B Posted May 5, 2024 Author Posted May 5, 2024 Update: it's an Atwood and this YouTube video seems to have done the trick: It was in John E Davies' thread, so many thanks to @rideandfly! Following the video, I knelt in the cold rain and removed the burner assembly. I found that the igniter electrode was arcing to the burner tube instead of the negative rod, so I bent the negative rod closer until I got a big arc there and reassembled. The furnace fired right up this time, but wouldn't keep running, as if there was a problem with the thermocouple, too. Defeated, wet, and tired I gave up and we retreated to a hotel for the night. After checking in to the hotel we returned to Eggcelsior to get clothes, toiletries, etc. for the night and, just for the heck of it, I turned the furnace on again. The sucker lit up and stayed lit! Maybe something got wet during disassembly in the rain? Maybe there was a lot of air in the gas line? Don't know. By this point, not wanting another middle of the night surprise, we decided to just go to the very nice hotel and let the trailer sit there alone and think about the way it was behaving. If it's still warm when we return in the morning I'll call it fixed. (Incidentally, if you've never been to Jim Thorpe, PA, it's worth a trip. I'll post something in our blog later.) 2 5 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
rideandfly Posted May 5, 2024 Posted May 5, 2024 5 hours ago, Geronimo John said: OK, I'm confused. Is it a Dometic or an Atwood? From the Panther sites, it appears that the Dometics are not the Atwoods. Please clear my foggy mind or some strong coffee! Which model does our our OE2's have GJ John, Starting 2017 Atwood is sold under the Dometic brand. https://www.dometic.com/en-us/outdoor/lp/rebranded-atwood Bill 2 1 2015 LE2 #75 / 2024 F-150/5.0L
jd1923 Posted May 6, 2024 Posted May 6, 2024 Love the hotel when necessary! We are on a 2 1/2 week trip mainly in SW Utah. After a week or so, used my travel points for an overnight at the Marriott, dinner out included. So, so glad to hear you are good again.@Steph and Dud B you’re the one! What you accomplished is that of a HVAC professional. 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted May 6, 2024 Posted May 6, 2024 20 hours ago, Steph and Dud B said: By this point, not wanting another middle of the night surprise, we decided to just go to the very nice hotel and let the trailer sit there alone and think about the way it was behaving. If it's still warm when we return in the morning I'll call it fixed. Single point of failure means you have no options. I like having options. Such is especially important for running our Refrigerator and Furnace is important. For the Refer, our OEM was gas, 12V, and 120V. For replacements I'll not go with the gas (High risk of fire) and get one that can run on either 12V or 120V. Add to that a good quality "5-Day" ice chest. For Heat: I suggest getting a quiet heat pump when you replace your Hammer Mill OEM one. Next a 120V 1500 watt electric resistance heater. IF you are doing a lot of cold weather camping to also get one of the safer propane fired portable heaters and a couple of small disposable propane gas cylinders like these as well. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted May 7, 2024 Posted May 7, 2024 18 hours ago, Geronimo John said: IF you are doing a lot of cold weather camping to also get one of the safer propane fired portable heaters and a couple of small disposable propane gas cylinders like these as well. Good plan, however some precautions: Be sure to properly ventilate by cracking some windows; many question the safety of propane heaters like the Mr. Heater variety, but just heed the warning(s) when used indoors. Also, based on my experience there will be an increase in humidity and condensation in the cabin, a byproduct of hydrocarbon combustion. I have seen condensation run down the interior wall and wet the bedcovers and dinette cushions, especially during a night of use. This can be somewhat mitigated with more ventilation than thought needed. 4 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator.
Steph and Dud B Posted May 7, 2024 Author Posted May 7, 2024 I do wish the A/C had a heat strip or heat pump as a backup but it wouldn't have mattered on this trip because we were dry camping. We do have a Mr. Buddy propane heater but didn't pack it because there was really only one cold day in the forecast and we've never had a furnace failure in 25 years RVing. What were the odds, right? 1 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Geronimo John Posted May 7, 2024 Posted May 7, 2024 6 hours ago, Steph and Dud B said: What were the odds, right? I have lots of experience where my travel companion, Mr. Murphy, often trumps a pair of Odds. 🙂 GJ 2 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted May 7, 2024 Posted May 7, 2024 46 minutes ago, Geronimo John said: I have lots of experience where my travel companion, Mr. Murphy, often trumps a pair of Odds. 🙂 GJ I believe strongly in the iconic phrase from the song Beautiful Boy by John Lennon: "Life is what happens to you while you're busy making other plans." There is NOT enough room to have backups for everything! I prefer to pack light and take our chances. Our backup heater is an extra blanket! I'll just bet, that with all the frustration day of, that @Steph and Dud B have a life memory they will cherish, or at least remember. You have to make the best of things and live life as it comes, no regrets. I tend to remember the good stuff. 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steph and Dud B Posted May 8, 2024 Author Posted May 8, 2024 3 hours ago, jd1923 said: I'll just bet, that with all the frustration day of, that @Steph and Dud B have a life memory they will cherish This is true. The hotel turned out to be a gem and we had a wonderful afternoon and evening in town. 2 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
jd1923 Posted May 8, 2024 Posted May 8, 2024 Beautiful boy by John Lennon (Lyrics) (youtube.com) Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted May 8, 2024 Posted May 8, 2024 (edited) On 5/7/2024 at 12:41 PM, jd1923 said: There is NOT enough room to have backups for everything! I prefer to pack light and take our chances. I agree in principal recognize your TAKE OUR CHANCES perspective. Packing light and as a result often rolling the dice works well for a lot of RV owners. Others pack heavy and could never go where you and I like to go. Then there are others of us that are actually somewhere in the middle. It is all good. It is also good that our "spares/emergency/DIY gear) is different. No point in running across a situation and having the exact same gear. Better for our response if our Kits are different. MORE OPTIONS. I would wager that we both, and many others, carry gear that gives us more options so that we don't have to roll the dice very often. Also that neither of us go overboard on the weight or space side. GJ UPDATE: Talked to knowledgable OTT techs and pulling the FWT is a PITA. Not something they or I would recommend for any mod. So I did suggest that they increase the plug prone tank drain to 3/4" or 1" to facilitate tank flushing. Edited May 9, 2024 by Geronimo John 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
MAX Burner Posted May 10, 2024 Posted May 10, 2024 On 5/8/2024 at 1:10 PM, Geronimo John said: UPDATE: Talked to knowledgable OTT techs and pulling the FWT is a PITA. Not something they or I would recommend for any mod. So I did suggest that they increase the plug prone tank drain to 3/4" or 1" to facilitate tank flushing. Dusten mentioned that he'd removed several FWTs and it usually required a forklift to pull it out after the bumper assembly is removed - that operation.... is way outside of my wheelhouse! A 1" or greater (if possible) drain tube would be a great mod - gets more plastic shavings and debris from the tank when performing the annual flushing. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
jd1923 Posted May 10, 2024 Posted May 10, 2024 A 1" line with connectors becomes 3/4" ID, a great improvement at 2x the current OEM drain. OTT uses 1/2" PEX with 90 connectors that have 3/8" ID. See my picture of the motorized valve installed on the drain. Yes, the 90 fitting is 3/8" ID and if any of you still have the old brass switch valves (for boondocking / winterization modes) they are 1/4 ID. Motorized valves I used in all 3 locations have 12mm ID, one mm short of 1/2" ID. It drains a little faster and the boondocking fill is now twice as fast. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
