I M in KS Posted August 7 Share Posted August 7 On 2 recent trips, I have filled the fresh tank from city water, probably 3 or 4 times. The monitor only reads 19 and then jumps to 38 & never goes higher. I fill it till over flowing, an it has been filled on relatively level ground or tongue down. I really don't recall if it worked well or differently before paying attention these times. Any idea what could be the cause? Link to comment Share on other sites More sharing options...
Gliddenwoods Posted August 7 Share Posted August 7 I have given up. The monitors never give accurate data and I have accepted that as fact. 4 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs. Link to comment Share on other sites More sharing options...
jd1923 Posted August 7 Share Posted August 7 59 minutes ago, Gliddenwoods said: I have given up. The monitors never give accurate data and I have accepted that as fact. Agree 100%. These external sensors are some better than in other RVs. We just know how many days the gray and black will last and have extra fresh tank in the TV. We don’t use the readout. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
Rivernerd Posted August 8 Share Posted August 8 20 hours ago, I M in KS said: Any idea what could be the cause? Bad sensors. Like those who posted above, we have learned that our fresh, gray and black tank sensors are terribly inaccurate. Our fresh tank sensor, for example, reads 68% when the tank is overflowing (and therefore clearly full) with the trailer level. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package Link to comment Share on other sites More sharing options...
MAX Burner Posted August 13 Share Posted August 13 On 8/8/2024 at 10:03 AM, Rivernerd said: Our fresh tank sensor, for example, reads 68% when the tank is overflowing (and therefore clearly full) with the trailer level. Same here - our fresh tank sensor never reads >94%... We use the readouts as just a "ballpark" sense of the condition of each of the 3 tanks - for that, they're fine for us. Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
John Dorrer Posted August 13 Share Posted August 13 Our fresh tank maxes out at 88%. I always overflow the tank and still 88%. Gray tank monitor was replaced under warranty. I just add 12% when looking at the fresh tank monitor. 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli - Link to comment Share on other sites More sharing options...
I M in KS Posted August 28 Author Share Posted August 28 Thanks for the responses. If this is how the good/expensive ones perform, I can't imagine how bad the poor/cheap ones work. I'll consider reaching out to SeaLevel. Link to comment Share on other sites More sharing options...
FloraFauna Posted August 29 Share Posted August 29 On 8/7/2024 at 4:05 PM, Gliddenwoods said: I have given up. The monitors never give accurate data and I have accepted that as fact. Me too. I try to keep rough track of consumption. All of our fresh water goes into the grey tank but the two indicators (fresh and grey) never add up. I was thinking of trying to correct it before my trailer goes out of warranty but decided it's really not worth it. 1 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4 Link to comment Share on other sites More sharing options...
Geronimo John Posted August 31 Share Posted August 31 On 8/13/2024 at 2:30 AM, John Dorrer said: Our fresh tank maxes out at 88%. I always overflow the tank and still 88%. I had a similar problem. Then I re-leveled the Ollie very carefully and the tank numbers made a little bit more sense. It was amazing that just a few degrees of incline can make on the math. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trany, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
John Dorrer Posted August 31 Share Posted August 31 7 hours ago, Geronimo John said: I had a similar problem. Then I re-leveled the Ollie very carefully and the tank numbers made a little bit more sense. It was amazing that just a few degrees of incline can make on the math. GJ I'm going to play with that when I bring the trailer home and fill it. 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli - Link to comment Share on other sites More sharing options...
