Wow I did take picture of Serial and specs. Looking through my pics. R32 Softstart was recommended by Tosot supportPXL_20250209_201150403.thumb.jpg.fefcb1c69f5f48ee5bf8ec0373236cef.jpg
2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout.
300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt  Nova Kool refrigerator. Tosot A/C.  Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
Here’s an interesting fact: In further researching the origin of the Atmos 4.4, I learned that Dreiha also offers 2.5 and 3.5 models, 7.5K and 11K, respectively. However, these units are primarily manufactured for European markets and are 220-240v with R410A refrigerant, but still have the same ‘SANZ’ connections as the Atmos 4.4; German designed and foreign made at one of the aforementioned SANZ Clima facilities. I’m even more convinced there is no China connection with these Dreiha products!
On 3/29/2025 at 10:48 PM, Ty J said:
Tosot A/C installed
Ty J:  Is this a drain tube?  If so it would be simple to penetrate the hull on both sides and pipe them down via the existing Dometic drain tube.
On 3/31/2025 at 6:24 PM, Ty J said:
Wow I did take picture of Serial and specs. Looking through my pics. R32 Softstart was recommended by Tosot support.
Thank you and please verify. When I zoom in on the label, it gets too blurry to see. Does the label state: "Refrigerant R32?"
Thats my Cell phone booster. I can try to penetrate the gasket if I can find some capture device for the water. Thanks!
Roger.  Thanks.
Edited by Geronimo John
I read this post in SDG’s FB on general humidity control measures and thought these tips may be of interest:
On 3/31/2025 at 8:54 AM, CRM said:
I'm more concerned with how low the CFM's can go at it's lowest setting for controlling humidity and I couldn't get that info on the Atmos when I was researching it.
Just an observation. I went to the Cow Barn last Friday to check on the Oliver and run the Atmos on the LFPs in order to drop the SOC below 75%. I do this routinely when in storage for lengthy periods to cycle the batteries and exercise the charging system, which has dual chargers kicking in at that specified level of charge. As the Atmos was running to cool the interior, I referenced the User’s Manual and learned how to operate the Sleep Mode. The unit was whisper quiet and I could only tell when the compressor was running by watching the VictronConnect app as it kicked in. During the interim however, I was also watching the humidity levels as the Atmos cycled in this mode. I observed a 5% fluctuation in the humidity between compressor cycles, which remained steady for the duration of this Sleep Mode test. As it may relate, the interior temperature inside the Oliver was 87° upon arrival (stored inside a totally enclosed storage facility), outside temp was 85°. Because the dehumidifier had shut off due to a full reservoir, a reading of 58% was observed, outside relative humidity was high (>70). During initial operation in Cool Mode, the interior temp dropped to 76° and humidity to 50% in 20 minutes. For the remainder of operational time in Sleep Mode the compressor cycled with a 3° fluctuation in temp and humidity range of 49-54%.
I came across the following post by a member of the iRV2.com community, by CC220 and dated April 2024, which may be of interest to some. Yes it is very lengthy but interesting, so if so inclined give it a read. As an owner, I concur with this author’s overall assessment of the Drieha Atmos 4.4 and look forward to furthering my personal experiences this coming summer.
I just returned from SDG in Elkhart, IN ...after having the Dreiha Atmos 4.4 rooftop AC installed in place of the Dometic Penguin II our Coach House Platinum 220TB had been equipped with. Floridians and others living in the southeast, know full well the sweltering heat and oppressive humidity these climate zones generate in the summer, and their demand for consideration when scheduling outdoor activities and travel plans.
Reducing the palpable humidity and creating a light breeze, immensely improves the air quality and comfort coefficient ...even when the temperature is lowered by just 2 or 3 degrees. The prospective ability to mitigate the steamy southeastern summertime 'misery index'...is what originally captivated my interest when reading about the Atmos 4.4 on the LTV FB owner-enthusiast forum.
The unit is amazingly quiet, and I could envision an owner mistakenly leaving the unit powered on ...believing it had been turned off. Apparently, there is an 'LED light function' but appears available only when the unit is installed in a ductless configuration. (No part of the actual unit is exposed in our rig's ducted system mounting ...just a flush mounted filter cover.
Admittedly, there are some 'unknowns' pertaining to the Dreiha corporation and their products, but obviously not of the type that dissuaded me from purchasing. Dreiha isn't (yet) a household name in this country, and in like fashion; Truma, required several years to attain brand recognition within the RV industry and amongst RV shoppers. Possibly adding to consumer name recognition challenges, is my understanding that the Atmos 4.4 is marketed and sold under another name ...as a virtual twin.
We don't yet have access to sufficient user feedback in this country to evaluate long term reliability, but SDG owner; Kevin Searer's commendable reputation and the very favorable impression I received from him, leaves me confident that product warranty support won't be a problem. I'm glad to see Kevin and his great crew receiving well deserved recognition from the LTV community, and seeing more partnerships developing through which Dreiha brand HVAC products can be distributed, installed and serviced.
To my knowledge SDG has expanded their dealership distribution network into Florida (CTM Customs) and if I recall correctly, a Solar-RV systems company in Texas. I thought it worthwhile to share some test results which compares operational efficiency of the Dometic Penguin II against the Atmos 4.4 AC.
When using the Atmos AC function in either 'Dehumidifier' or 'Auto' mode ...its compressor and fan will alternatively cycle on and off during preset work intervals, greatly reducing an otherwise, constant high amperage power draw. The alternating compressor/fan cycle, seems in principal ...somewhat similar to variable speed compressors used in mini-split HVAC systems.
That work/rest interval also explains the mind-boggling 'time remaining' estimates (shown in screenshots) produced by my Victron Multi-plus II inverter-charger, when the Atmos 4.4 is operating it's fan cycle in 'Dehumidifier Mode' on battery power. (I only tested using the Dehumidifier Mode, as that is most relevant to my climate zone, while also rendering the longest operational off-grid run times)
28 July 2024, 12:00pm
Elkhart, IN (SDG HVAC parking lot)
Ambient temp: 80 degrees, partly cloudy.
Battery bank State of Charge: 100%
Dometic Penguin II, Set point: 75 degrees
151 amps: High setting, 130 amps: Low setting
Time remaining on battery @ present rate: 3 hrs 52 minutes
1 August 2024 8:48 am
Columbus, GA
Ambient temp: 77 degrees
(With humidity: "Feels like 84 degrees" Weather Channel)
Atmos 4.4, Set point: 75 degrees
** Dehumidifier mode
Between 77 - 111 amps (compressor cycle)
Between 4 - 7+ amps (fan cycle)
Time remaining on battery @ present rate: (compressor/fan)
Between 6 hrs 27 minutes - 3 DAYS 10 hrs!!
Testing initiated with a 4-5 minute compressor cycle, followed by a fan only cycle.
** When compressor kicked off, and circulation fan was activated, amps decreased from 8.55 to 5.21.
Just over half an hour into the test, the projected 'battery discharge time remaining' topped out at over 3 DAYS ... while the battery bank State of Charge REMAINED at 97 percent.
I documented an unbelievable 35 minutes of AC cooling, with only 28.3 amps used. That current rate of efficiency would extrapolate to over 90 minutes of AC operation ...for less than 90 amps expended. INSANE!
At 1:42 pm. Temperature was 94 degrees
(With humidity: "Feels like 108" Weather channel)
At 4:40 pm. Temperature was 97 degrees
(With humidity: "Feels like 111" Weather channel)
Mid-test number crunching & predictions:
If the theoretical efficiency deviates little from operational expectations ...my 600ah battery bank would provide 9 hours of CONTINUOUS dehumidifier mode AC run time.
The increased ambient temperature clearly altered the rate of energy expenditure, with compressor operation rising to a peak of 111 amps (40a less than the Dometic on 'High' setting) and fan cycle amps at 7+ ... with the alternating cycles appearing to occur in shorter intervals.
** Batteries finally died at 7:15 pm
TOTAL run time was approximately 10 hours 15 minutes **
Cost vs performance analysis:
The conclusion of testing revealed that the Atmos impressively exceeded the projected run time by more than one hour ...with the battery bank finally signing off after approximately 10 hours 15 minutes.
A commonly cited 'AC on battery' energy formula, suggests that a 100ah lithium battery will yield approximately 45 minutes of AC operation. Thus, my 6 x 100ah battery bank would only be expected to provide 4.5 hours of continuous AC runtime.
Consequently, the 10 hours 15 minutes of Atmos 4.4 AC run time ...appears roughly equivalent to having added SEVEN more 100ah lithium batteries. At a cost of $970 each
($6790 for 7 x 100ah Battle Born units) ...
OR
Installation of the Atmos 4.4 AC, for approximately 1/3 of the cost.
I'm no electrical engineer, and therefore unqualified to say with certainty how much impact the three 200w rooftop solar panels may have had on the Atmos' operational longevity, however ...since the 'fan only' cycles of several minutes duration usually required less than 80 watts, I'm led to believe that the solar panels did contribute to the run time.
Bearing in mind that the 3 hour 52 minutes of Dometic Penguin II run time was attained while connected to the same 600w rooftop solar array augmenting the 600ah powerbank ...clearly, no advantage was ceded to the Atmos.
The Dometic's 'always on compressor' state, imposed significantly HIGHER power demand penalities of between 20-40 ADDITIONAL amps (versus the Atmos') while switching itself from 'low' and 'high' compressor settings.
** It's vital to consider that the Dometic AC did in fact, have the benefit of operating with the SAME SoftRVstart module (that greatly reduces the inrushing power spike imposed upon the battery bank) as did the Atmos, when demonstrating its superior energy efficient design, by operating in excess of 6 hours longer.
The heat pump function on the Atmos not only operates to lower temperatures, and is quieter ...it also reaches set temperature much faster. The bonus feature from my perspective, is the Atmos' remote control interface, providing the ability to function independently from the problematic Firefly system that Coach House has discontinued use of.
True, the wall mounted remotes and bluetooth phone app are viable workarounds for the Firefly's tempermental touch-insensitive main screen interface ...but I prefer the stability of decentralized, direct control of Coach systems.
Truma's Aventa and Houghton rooftop AC units offer better performance than the Dometic, but I determined the Dreiha Atmos 4.4 to be the better value. SDG does also sell and install 12v HVAC units and mini-split systems, however ...their increased complexity/mounting space required and lack of a dehumidifier mode, were reasons for me to disregard consideration.
Last Saturday, I was surprised to find HVAC technicians at SDG working on the weekend ...they were installing 12v mini-split HVAC systems in 3 Ram ProMaster vans that would soon be serving as ambulances.
Beyond installation of a lithium battery bank/3K inverter-charger/optimized DC DC charging system, I now believe that fitment of a substantially more efficient HVAC system (mini-split or next-generation rooftop unit, like the Atmos) ...to be the next most significant systems upgrade one can make for conservation of their rig's vital battery bank power.
CH220 is offline
Thanks for posting this information !
we appreciate it very much
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
On 3/8/2025 at 7:01 PM, Steve Morris said:
My house, built in 1976 with apparently no building codes observed, is severely under-powered and under-wired. It is an all-electric home with a heat pump for heating/cooling, and only has 150A service. The entire garage is on one 20A breaker, with two wall outlets, one ceiling outlet, and two ceiling light sockets (one of which has a screw-in outlet for four LED shop lamps.)
There are way too many continuous and/or intermittent loads on that one 20A breaker: the aforementioned LED shop lights, garage door opener, 40 year old chest freezer, dorm fridge, stationary air compressor, 3-4 Battery Tender Juniors, the Oliver, an extension cord to my truck to run the fridge/freezer at home, a buried extension cord to an outdoor weather station and security camera, occasional woodworking tools, two Makita 2-slot battery chargers, a Bose Wave radio w/Raspberry Pi attached, cable TV signal booster, and probably more that I'm forgetting.
So, I keep the Xantrax set low to limit how much it draws from the house. The only loads are the fridge, battery charger, parasitic loads, and occasionally the AC. The vast majority of the time the trailer isn't plugged in to the house at all. The batteries can handle any typical loads, and even AC if I'm not using it continuously.
Steve you got it going on in your Garage!
2017 Oliver Elite II Hull 292
2018 Nissan Armada
Tampa, FL
On 3/30/2025 at 12:50 PM, jd1923 said:
Can you please confirm if the Tosot you have runs on R410A or R32 refrigerant? With R32 it means it is equal to the Atmos today. The Gree last year was advertising R410A and it's hard to know what you're getting since this Amazon ad and other sources often do not specify. See this article for the superiority of R32:
https://aircondlounge.com/types-of-refrigerant-in-air-conditioning/
Still a good "Spring Deal" on Amazon now at $1, 020 + tax, delivery included. Wish we lived in one of your no sales tax states! With the high AZ sales tax, this comes to $1,105. The Atmos is $1,350 + $150 shipping + tax (both numbers without StartStart).
https://www.amazon.com/TOSOT-Conditioner-Non-Ducted-Rooftop-High-Efficiency/dp/B0CDWR5RP9/?th=1
The Turbro soft start you show in the picture is $84 plus tax, also on Spring Sale today:
https://www.amazon.com/TURBRO-Installation-Compressor-S15-Plus/dp/B0DK8BXHWH/
OUCH! Just followed the link, not $1,299.99 for Tosot
2018 Nissan Armada
Tampa, FL
Gary-  looks like the tariffs are hitting all of them. Was getting reading to order a Greenland Inverter AC unit and the price jumped $300 overnight. On top of that, now they're out of stock at the moment too. Think I'll wait until the tariff situation is resolved and hope my 16 year old Coleman holds out a little longer...
  • Wow 2
I'm seeing $1200 with shipping.
Still less than $1500 total on the Atmos (with $150 shipping, no SoftStart on either).
https://www.sdgelkhart.com/product-page/atmos-4-4
I witnessed @Ronbrink's installed Atmos and it was excellent. Still not sure the Tosot is of the same quality. Right now, maybe $300 more on the Atmos to be sure with reputable US rep in SDG.
I would love the Greenland inverter A/C that @CRM is also interested in. If I was to learn it is quieter than some reviews show. And I too am waiting another year.
1 hour ago, jd1923 said:
The TOSOT AC is manufactured in China.
Hopefully not at the same factory where the OTT springs are made.
  • Haha 2
Hopefully when my Dometic dies the tariff’s will have settled down.
2018 Nissan Armada
Tampa, FL
Issue is bearing the noise until then! If I lived in Florida I would have already installed one.
I believe they all are, except for the Aussie Houghton A/C (unless they off-shore their manufacturing like the rest). Atmos German designed, China built.
I made the above comments on April 18th, at which time I played around with the Sleep Mode on the Atmos. Upon departure of these routine visits I always check to be sure everything is turned Off, except for the dehumidifier. Admittedly, there have been a few times after locking up the Oliver and then the COW Barn when I question whether or not the dehumidifier was turned back On, or the closet light and water pump turned Off and thus, back inside to check all again. I recall everything to be in good order so back to lockup and departure. Well, when I went back on April 24th to pay rent I was baffled to see a puddle of water upon entering the COW Barn; my first thought being somehow the roof developed a leak from recent heavy rains. However, when entering the Oliver I felt the cool and comfortable 73° interior and noticed the Atmos’s fan was On, then realized the puddled water was condensate. YIKES, it was SO QUIET I didn’t even realize upon last departure it was still running!
Now this isn’t a testament to how wonderful the Atmos is and pleased I am with its performance, but rather that of the Hughes Autoformer I permanently installed. Fact being, the storage facility only provides 15A service and with recent severe storms that device’s surge protection may have prevented damage to my Oliver’s electrical system or even the Atmos. More importantly, upon checking the Autoformer was boosting voltage, which I have observed a few times since the install during storage. This occurs when line input voltage drops to 116 volts or below, wherein the unit’s output is automatically boosted 10% over the input. It is a known fact that insufficient voltage, both spikes and surges, can cause irrepairable damage to sensitive electronics and RV air conditioners, and the primary reason for having this extra layer of protection the Hughes Autoformer provides. There is comfort in knowing that if I inadvertently leave the Atmos On at the COW Barn, given the minimal service, or run it at a CG where service issues may occur that my electrical devices and Oliver are fully protected. ‘Nuff said!
Edited by Ronbrink
48 minutes ago, Ronbrink said:
Now this isn’t a testament to the how wonderful the Atmos is and pleased I am with its performance, but rather that of the Hughes Autoformer I permanently installed.
Autoformer's should be standard equipment in all RV's and probably would be if Hughes didn't hold the patent on it . And smart that you permanently mounted yours inside too.. Keeps it safe and secure plus no prying eyes to accuse you of "stealing power". 😄
Back in stock. I'm not familiar with the pricing history. Maybe they raised the price and then put it on sale! https://www.turbro.com/products/greenland-13500-btu-inverter-rv-air-conditioner-with-heat-pump
Thanks.. And now they're $400 more than they were when I first started looking at them!
Thankfully it's just a want and not a need at the moment. Will jump on it if the price comes back down or my Coleman poops the bed... whichever comes first.
On 3/13/2025 at 7:30 PM, Geronimo John said:
The key to your, mine, and a boat load of owners is the ABILITY to choose Off or On of the fan.  The Houghton Set 2 units do not so provide.  Hence serious humidity issues caused by this AND the fact that on the Set 2 they mount the thermistor (that controls the compressor on/off) is mounted inside the unit and does not very well reflect the cabin temperature in the middle of the cabin.
I have hopefully found a work around for both the fan control and thermistor issues, specific to the Atmos. Pending implementation measures and findings may be of interest to anyone considering this replacement unit.
Edited by Ronbrink
As eluded to in the above quote and my recent comment made in @rideadeuce’s  July 18, 2024 post entitled First highway roadtrip with Atmos 4.4 => MI, I am pleased to share the following information gleaned from other SOB forum and FB members. I learned that the Cielo Breez Max is the only wall-mounted thermostat compatible with the Atmos, which has a programmable Comfy Mode that can turn power off based on either temperature or humidity setpoints. For further information on its use and features search ‘Cielo Breez Max Detailed User Manual  / Gemaire Distributors’.
The Cielo Home app utilizes WlFi for initial settings and preferences, and to pair the Atmos remote. In said mode, once custom temperature or humidity comfort ranges are dialed in, the Cielo will turn on power when the high setting is exceeded and subsequently turn off power when the lower setting is exceeded. This is ‘HUGE’, whereby 1) both the the fan and compressor cycle on and off in sync at startup and shutdown, respectively and thus, the fan doesn’t run continuously so no more dreaded humidity spikes and 2) there is an energy savings benefit, especially when running on the house batteries. There are other benefits like being able to control and monitor the Atmos from anywhere, but the two aforementioned have been my main focus. That said, I have not yet conducted batt run durations, but will report findings when I do so.
After several tests under varying weather conditions and device settings at my Houston residence, I find this Cielo a ‘keeper’! I currently have three Comfy Temperature templates for Day, Nite and Storage; and one Comfy Humidity, which I tested this morning.
I also moved the end of the thermistor outside of the air distribution cover to test temperature sensing; still evaluating.
I found this mounting location best, given there is a power cord.
Edited by Ronbrink
  • Love 2
The Cielo Home app utilizes WlFi for initial settings and preferences, and to pair the Atmos remote. In said mode, once custom temperature or humidity comfort ranges are dialed in, the Atmos will turn on power when the high setting is exceeded and subsequently turn off power when the lower setting is exceeded. This is ‘HUGE’, whereby 1) both the the fan and compressor cycle on and off in sync at startup and shutdown, respectively and thus, the fan doesn’t run continuously so no more dreaded humidity spikes and 2) there is an energy savings benefit, especially when running on the house batteries. There are other benefits like being able to control and monitor the Atmos from anywhere, but the two aforementioned have been my main focus. That said, I have not yet conducted batt run durations, but will report findings when I do so.
So, if I'm understanding this correctly, this thermostat shuts down the fan and compressor together by sending a "shutdown" signal to the unit by mimicking off button on the unit's remote?
