Ronbrink Posted May 29 Author Posted May 29 4 minutes ago, CRM said: So, if I'm understanding this correctly, this thermostat shuts down the fan and compressor together by sending a "shutdown" signal to the unit by mimicking off button on the unit's remote? The Cielo is independent of the remote and actually turns OFF the power to the Atmos 1° below the low temp setting then turns ON the power to the Atmos 1° above the high setting. There is zero power draw during the shutdown period. When using the thermostat, the remote must be turned OFF and the phone app used to control. The remote can be used for normal operation of the unit, but for enhanced features like Comfy Mode the app is used. Selecting the proper temp setpoint will determine if the fan or compressor runs longer at shutdown. I will address that another time. There is also a Comfy Max Mode, which mimics a home HVAC set for heat/cool, but I think the fan is continuous. Did this answer your question? 1 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
CRM Posted May 29 Posted May 29 12 minutes ago, Ronbrink said: The Cielo is independent of the remote and actually turns OFF the power to the Atmos 1° below the low temp setting then turns ON the power to the Atmos 1° above the high setting. There is zero power draw during the shutdown period. When using the thermostat, the remote must be turned OFF and the phone app used to control. The remote can be used for normal operation of the unit, but for enhanced features like Comfy Mode the app is used. Selecting the proper temp setpoint will determine if the fan or compressor runs longer at shutdown. I will address that another time. There is also a Comfy Max Mode, which mimics a home HVAC set for heat/cool, but I think the fan is continuous. Did this answer your question? That seems like a perfect solution to the "always on" fan issue! Shouldn't this thermostat work for other units that have a remote control to control them? 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 4.30 axle and tow package.
Ronbrink Posted May 29 Author Posted May 29 9 minutes ago, CRM said: That seems like a perfect solution to the "always on" fan issue! Shouldn't this thermostat work for other units that have a remote control to control them? As I understand it, the Cielo line of products is primarily marketed for mini splint air conditioners, but obviously found to be comparable with other types. SDG that sells and installs the Drieha Atmos 4.4 uses these IR Cielo thermostats in some of the Class B RVs they mostly deal with. I haven’t read of any other brands of rooftop units being controlled by a Cielo, but guess it may be possible. I agree, a perfect solution! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
CRM Posted May 30 Posted May 30 2 hours ago, Ronbrink said: As I understand it, the Cielo line of products is primarily marketed for mini splint air conditioners, but obviously found to be comparable with other types. SDG that sells and installs the Drieha Atmos 4.4 uses these IR Cielo thermostats in some of the Class B RVs they mostly deal with. I haven’t read of any other brands of rooftop units being controlled by a Cielo, but guess it may be possible. I agree, a perfect solution! This is from the description on their Amazon store- "Product Usage Instructions: Breez Max connects to a 2.4 GHz Wi-Fi network. It is compatible with any mini-split, window or portable unit that has an IR remote control. If your device doesn't work out of the box, please contact Cielo Customer Support to make it compatible." Looks like any unit that works with an IR remote has a good chance of working with this thermostat. Might have to start a new thread at some point to track what other AC units it actually does work with? Thanks again for this. 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 4.30 axle and tow package.
rideadeuce Posted May 30 Posted May 30 (edited) 14 hours ago, Ronbrink said: In said mode, once custom temperature or humidity comfort ranges are dialed in, the Atmos will turn on power when the high setting is exceeded and subsequently turn off power when the lower setting is exceeded. This is ‘HUGE I didn’t think I needed this since already having the remote and other app control but I believe I am going to try it. Being able to more clearly refine the control is what we all want. Thx for sharing the product and evaluation. … now, where to place it? USB power makes things interesting. Edited May 30 by rideadeuce 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Ronbrink Posted May 30 Author Posted May 30 (edited) 13 hours ago, rideadeuce said: … now, where to place it? USB power makes things interesting. The Cielo has to be positioned for line-of-sight with the Atmos controls in the air distribution panel. And yes, an AC outlet or USB port is needed in close proximity; however it is equipped for hardwiring. When learning how to use the Cielo, I sat at the dinette and plugged into an AC outlet via the supplied 5V adapter; the supplied base stand for flat surface staging was also used. Being a wall-mount is best securement in a rolling earthquake, I first tried it on the forward bulkhead to the upper left of the wet bath door, but didn’t like the cord dangling down the wall and it seemed a bit less responsive due to the distance. I then placed it between the two curbside upper cabinets near the under cabinet USB ports above the cooktop, but the 90° orientation didn’t work as well and there would be concerns of rising heat if cooking. Finally I placed it as shown in the pic, whereby the cord runs in and out of the galley cabinet and plugs into said USB port. I used Velcro for the mount, and may eventually hardwire the Cielo through that upper cabinet and tap into the wiring within the access screw port for a cleaner installation. As positioned, the Cielo is in clear view from bed, and I like that the backlight is dimmable or can be turned off. Edited May 30 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted May 30 Author Posted May 30 9 hours ago, CRM said: Looks like any unit that works with an IR remote has a good chance of working with this thermostat. Might have to start a new thread at some point to track what other AC units it actually does work with? Thanks again for this. Good idea! It also claims ‘The smart air conditioner controller is compatible with over 20,000 models of mini-splits, window, or portable units’. Maybe there will be some owners of SOB units willing to try the Cielo Breez Max and report their findings. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
CRM Posted May 30 Posted May 30 47 minutes ago, Ronbrink said: Good idea! It also claims ‘The smart air conditioner controller is compatible with over 20,000 models of mini-splits, window, or portable units’. Maybe there will be some owners of SOB units willing to try the Cielo Breez Max and report their findings. It would be very interesting to see if it works with the Houghton units. Hopefully someone with one will see your solution and give it a shot. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 4.30 axle and tow package.
Ronbrink Posted May 30 Author Posted May 30 (edited) 4 minutes ago, CRM said: It would be very interesting to see if it works with the Houghton units. Hopefully someone with one will see your solution and give it a shot. And the Truma for that matter! EDIT: Dometic Penguin ll, as well! Edited May 30 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted May 30 Posted May 30 3 hours ago, Ronbrink said: Dometic Penguin ll, as well! The ONLY good thing re the Dometic P2 is it does turn off when fan set to AUTO and temp is reached! 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rideadeuce Posted May 30 Posted May 30 3 hours ago, jd1923 said: The ONLY good thing re the Dometic P2 is it does turn off when fan set to AUTO and temp is reached! The problem starts every time it starts back up! 😆 I know this is a very individualized thing but I actually like the unit and/or fan only running continuously, especially if it is quiet. It was the loud start and stops of the DP2 that woke me up during the night, etc. I am very hot natured and live in the humid SE. What Ron has figured out is better than the other options of timing out, manually shutting off the unit, or using the AUTO mode with no ability to refine temp settings. Hope everyone has a great weekend! 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Ronbrink Posted June 2 Author Posted June 2 On 5/30/2025 at 1:59 PM, rideadeuce said: What Ron has figured out is better than the other options of timing out, manually shutting off the unit, or using the AUTO mode with no ability to refine temp settings. I’m sharing my experience in hopes of helping other Oliver owners resolve the inherent humidity issue, regardless of the brand of a/c unit they may have. If found to work with a particular unit, perhaps others can share their experiences. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted June 2 Author Posted June 2 (edited) On 5/29/2025 at 5:36 PM, Ronbrink said: Selecting the proper temp setpoint will determine if the fan or compressor runs longer at shutdown. I will address that another time. The following has been found beneficial in ‘Setpoint’ selection in Comfy Mode, but may be applicable with use of Comfy Max Mode, as well; TBD. It is important to know that a setpoint one or two degrees below the upper range of temperature selected will have the fan run more than the compressor prior to power shutdown; whereas a setpoint of three or four degrees will have the fan and compressor turn off in sync, and the outside blower fan runs a half minute or so before total shutdown of the unit. Here’s a screenshot of the Custom Settings for my ‘Day’ Comfy temperature range. Although I have the Vertical Swing set to Auto, there are nine other positions to choose. Once the Atmos is running in a Comfy Mode, the Swing can be temporarily changed. I find this useful when sitting or lying in bed (head at rear) and don’t want the cold air oscillating downward onto me. Pos 1 can be selected to set the Swing to blow straight out. The Fan speed can also be changed, as well. These interim changes will revert back to the original settings next use. Edited June 2 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted June 16 Author Posted June 16 (edited) Here’s some observations in using the Cielo Breez Max phone app, the phone’s Bluetooth must be turned on to pair the device and Wi-Fi is initially required to operate the A/C via the app. Once the A/C is powered up and set to run at a desired mode of operation and Wi-Fi is discontinued, the A\C will continue to run as set, but changes cannot be made. However, to make changes or when it comes time to turn off the A/C Wi-Fi is once again needed. I know this based on my experience a couple weeks ago, wherein I started the A/C using the phone app while at my house in order to run the Atmos via the inverter while in transit to the COW Barn for storage. Once stowed and ready to leave, I was unable to turn off the Atmos and found it necessary to use my wife’s cell hotspot in order to do so. Fast forward to yesterday, when I activated a recently acquired Starlink Mini and went back to the COW Barn to check on the Oliver and perform some tests. To no surprise, the SLM worked flawlessly, as well as the Cielo/Almos. It wasn’t a terribly hot day for Texas due to pending inclement weather, outside temp was 88°/relative humidity 77%; the Oliver registered 89°/72%. Yep, the dehumidifier was shutdown with a full reservoir and thus, the high humidity condition within! Not to worry, the SLM/Cielo phone app started and ran the Atmos for 45 minutes, at which time it powered off on Confy Mode at the set temp of 75°/humidity was 45%. In approximately 20 minutes, the Atmos turned back on when the temp rose to 77°/humidity was 47%. It then ran 17 minutes before total shutdown again, humidity was 45%; no humidity spike whatsoever, YAHOO! Loving the Cielo Breez Max and the SLM is proving to be a worthy addition as well, as many of you already know. Hopefully other owners will try out the Cielo Breez Max on their respective A/Cs, and report on subsequent findings and experiences. Edited June 16 by Ronbrink 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted Saturday at 12:57 PM Author Posted Saturday at 12:57 PM On 4/24/2025 at 3:09 PM, jd1923 said: I'm seeing $1200 with shipping. https://www.amazon.com/TOSOT-Conditioner-Non-Ducted-Rooftop-High-Efficiency/dp/B0CDWR5RP9/ Still less than $1500 total on the Atmos (with $150 shipping, no SoftStart on either). https://www.sdgelkhart.com/product-page/atmos-4-4 I witnessed @Ronbrink's installed Atmos and it was excellent. Still not sure the Tosot is of the same quality. Right now, maybe $300 more on the Atmos to be sure with reputable US rep in SDG. I would love the Greenland inverter A/C that @CRM is also interested in. If I was to learn it is quieter than some reviews show. And I too am waiting another year. FYI, I recently learned that SDG is now installing the Tosot via the following quote by a member of another forum: “I spoke to Kevin about the switch from Atmos to the Tosot and he said it was because of the tariffs that the Atmos supplier imposed and he could buy the Tosot direct from the manufacturer for less. The units are identical and both produced by Gree”. This product switch was confirmed when visiting SDG’s website. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted Saturday at 10:51 PM Posted Saturday at 10:51 PM 9 hours ago, Ronbrink said: FYI, I recently learned that SDG is now installing the Tosot via the following quote by a member of another forum: “I spoke to Kevin about the switch from Atmos to the Tosot and he said it was because of the tariffs that the Atmos supplier imposed and he could buy the Tosot direct from the manufacturer for less. The units are identical and both produced by Gree”. This product switch was confirmed when visiting SDG’s website. There is a question that I do not believe has been verified. Tosot a year ago was using R-134a refrigerant. Are they now using the more efficient R-32? Anybody getting one should know this ahead of ordering. Ron can confirm, but I'm pretty sure his and other Atmos use R-32 refrigerant. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ronbrink Posted 20 hours ago Author Posted 20 hours ago (edited) 14 hours ago, jd1923 said: There is a question that I do not believe has been verified. Tosot a year ago was using R-134a refrigerant. Are they now using the more efficient R-32? Anybody getting one should know this ahead of ordering. Ron can confirm, but I'm pretty sure his and other Atmos use R-32 refrigerant. Here is a screen shot of the Tosot specs from SDG’s website: And yes, the Atmos 4.4 has the R32 refrigerant. NOTE: The above shows a 15,500 BTU cooling capacity for the Tosot, which is higher than the published 15,000 rating for the Atmos. Makes me wonder! Edited 20 hours ago by Ronbrink Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted 19 hours ago Posted 19 hours ago (edited) 1 hour ago, Ronbrink said: NOTE: The above shows a 15,500 BTU cooling capacity for the Tosot, which is higher than the published 15,000 rating for the Atmos. Makes me wonder! We must be skeptical of specs on websites. Check the product label. Likely the R32 is correct and the 15.5K BTU is incorrect, 15K instead. i had ordered Epoch Essentials 460Ah batteries and if the website was accurate 2 would have fit in the Oliver battery bay with the tray removed. The website had width and height numbers reversed. Called Epoch and they could not confirm but the distributor did and they changed my order for two 300Ah which fit in the tray. Often bad data on websites. So much on auto parts websites for sure! Edited 19 hours ago by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
mountainoliver Posted 17 hours ago Posted 17 hours ago Here’s a screen shot directly from the Tosot website: 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
