John Dorrer Posted October 27, 2024 Posted October 27, 2024 I can't find anything on this topic on the Forum. I have tried window seal, window gasket, window seal gasket, etc Our gasket has shrunk close to an inch at the top. Some have replaced it in black. Who is the source for white or black gasket? What is the product #? John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
rich.dev Posted October 27, 2024 Posted October 27, 2024 John, these posts should help you, happy reading! https://supersizelife.com/replacing-your-rvs-window-seals/ https://www.pellandent.com/Half-Inch-Glass-Vinyl-Seal 1 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
jd1923 Posted October 27, 2024 Posted October 27, 2024 Same price as when I bought ours in black last year. I bought 17 ft, they sent 18 and I had over a foot left over. Total shipped was $99. https://www.pellandent.com/Half-Inch-Glass-Vinyl-Seal 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted October 27, 2024 Moderators Posted October 27, 2024 Ours is original and black. It’s also about an inch short at each window. I keep the gap on the upper part of the window. I’d replace them but the rubber is still good and the gap doesn’t seem to be an issue. Mike 7 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Bob and Elizabeth Posted October 28, 2024 Posted October 28, 2024 We got ours through Oliver. Mike Sharpe helped us. 1 Hull 737 OE ll “LET IT RAIN” 2016 Ford F-250 diesel
jd1923 Posted October 28, 2024 Posted October 28, 2024 John @John Dorrer, when you install yours cut each length about 1 1/2” longer than the original piece you remove. This makes up for the shrinkage you have and the shrinkage that will occur to.the new rubber. Start at the bottom and push hard to compact the rubber to make room for the extra length. Be firm and patient. If some end up a little too long you can always cut a little off but you can’t add length. A hose cutting tool works well as it is hard to use a razor/box cutter when the piece is in place and it cuts square. https://a.co/d/gNDM9QE 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted October 28, 2024 Posted October 28, 2024 @John Dorrer here is what I used. It worked perfect and only $8. https://www.harborfreight.com/finger-release-ratcheting-pvc-pipe-cutter-62588.html 1 4 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Galileo Posted June 8, 2025 Posted June 8, 2025 (TLDR: this entry is a rant that’s not worth the time to read. Just me whining. You have been warned!) I knew I’d find the source for this material here! I’m more than a bit disappointed that the stuff costs $5.17 per foot plus shipping - especially when the material is clearly not very good at resisting stains - and apparently shrinks - though that could be an installation error. Kind of “our product is terrible, but we have you over a barrel. Hah!” It’s not that $100 is a big deal in the grand scheme of things - just that it’s - for lack of a better phrase - a cheap cash-grab. It’s like they’re thumbing their nose at folks who have their windows having to spend $100 every couple of years to keep their windows looking nice. Last year, I removed the seals, scrubbed them with a couple of different cleaners and a toothbrush. That got off most of the stains. Then I took them for a little soak in a strong bleach water solution for about an hour. That got them virtually new-looking again. Of course, that may well have been more than $100 worth of my time and labor. That, and I’ll bet that the seals won’t come that clean a second time. So - now that I’ve ranted and whined about having to fork over $100 - every couple of years - I’m gonna go out, pull the seals off the windows - again, throw them in a bucket of bleach water, and scrub them in the morning. Then, I’ll look for some way to coat or seal them so they don’t do this again. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
CRM Posted June 8, 2025 Posted June 8, 2025 8 minutes ago, Galileo said: So - now that I’ve ranted and whined about having to fork over $100 - every couple of years - I’m gonna go out, pull the seals off the windows - again, throw them in a bucket of bleach water, and scrub them in the morning. Then, I’ll look for some way to coat or seal them so they don’t do this again. I recommend buying them in black. They don't get moldy, well maybe they do but at least it doesn't show... I also recommend putting them in the freezer a little while to shrink them and then fit them in as tightly as you can when you install them. I used this method a while back and no stains or shrink gaps yet. 1 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Galileo Posted June 8, 2025 Posted June 8, 2025 (edited) On 6/8/2025 at 2:36 PM, CRM said: I recommend buying them in black. They don't get moldy, well maybe they do but at least it doesn't show... I also recommend putting them in the freezer a little while to shrink them and then fit them in as tightly as you can when you install them. I used this method a while back and no stains or shrink gaps yet. Yes, black seems to be the way to avoid the unsightly black mildew - or whatever it is. They’ll still get dirty of course, it just won’t be so obvious. I hadn’t thought about cooling (previously “cooking” oops!) the new seal material first. I was figuring that the stuff doesn’t really shrink all that much, it more likely gets stretched as it’s being installed. I was planning on kinda “compressing” it as I install it. Mine had those 3/4”-1” gaps, but I just made sure they were at the top when I cleaned and reinstalled them. I don’t think they really do anything at the top. They just keep most dirt and junk out of the bottom of the track. Edited June 10, 2025 by Galileo Fat fingers, autocorrect 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
CRM Posted June 8, 2025 Posted June 8, 2025 5 minutes ago, Galileo said: Yes, black seems to be the way to avoid the unsightly black mildew - or whatever it is. They’ll still get dirty of course, it just won’t be so obvious. I hadn’t thought about cooking the new seal material first. I was figuring that the stuff doesn’t really shrink all that much, it more likely gets stretched as it’s being installed. I was planning on kinda “compressing” it as I install it. Mine had those 3/4”-1” gaps, but I just made sure they were at the top when I cleaned and reinstalled them. I don’t think they really do anything at the top. They just keep most dirt and junk out of the bottom of the track. I think you meant "cooling".. but believe me I think it makes a difference. I put my in the freezer and then forced (compressed) it in as hard as I could and now it's fits just about perfect. Pretty sure I'd have at least a small gap if I hadn't done it this way. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Galileo Posted June 8, 2025 Posted June 8, 2025 3 minutes ago, CRM said: I think you meant "cooling".. but believe me I think it makes a difference. I put my in the freezer and then forced (compressed) it in as hard as I could and now it's fits just about perfect. Pretty sure I'd have at least a small gap if I hadn't done it this way. Yes - finger slipped and spellcheck liked cooking. I just noticed that while-installing them the last time, that it’s pretty easy to stretch it as you install it. That could probably be enough to cause the gap as the material ages. 1 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
mountainoliver Posted June 9, 2025 Posted June 9, 2025 When you order the new black gasket material you will have some left over after installation. Keep this leftover material and when the gasket shrinks just cut a piece of the extra and splice it in at the top. Not really noticeable if all of the ends are cut squarely and the splice is at the top and even if it’s not perfectly tight it will still keep excess junk and insects out of the tracks. 4 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Galileo Posted June 9, 2025 Posted June 9, 2025 OK folks, (TLDR - Stained window seals? Soak overnight in Dawn & Bleach water.) Now that I’ve got that whiny rant out of my system, I’ve come up with a solution that saves $100 and gives me some satisfaction. I had pulled the window seals out of all four windows last season or so, scrubbed them with a toothbrush and Comet, gave them an hour soak in bleach water, and got them somewhat clean. I even moved two of them to opposite side of the trailer so I could install them “upside down” so that the more visible part was clean. They hadn’t come completely clean, but were a lot less unsightly. As I mentioned before, because I scrubbed (abraded) them, I figured they wouldn’t come as clean a second time. I’m thrilled to report that I was wrong! I pulled them off again yesterday. Coiled them up in the bottom of a plastic bucket. I put a cup of household bleach and a generous squirt of Dawn dishwashing liquid, and sprayed about a gallon of water in the bucket. I let them soak overnight. This morning I was pleasantly surprised to find that they came even cleaner than the first time! There’s just a mere hind of a shadow of the old stain on just one small part of one seal. I would pronounce (nearly) “as good as new”! I plan to coat/seal them with the same treatment I’ve used in the nose of the trailer to make bugs release easier. So - for little more sweat equity than it would take to cut and install new ones - and $100 less - I have window seals I’m quite happy with. 3 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted June 10, 2025 Posted June 10, 2025 On 6/8/2025 at 2:36 PM, CRM said: I also recommend putting them in the freezer a little while to shrink them and then fit them in as tightly as you can when you install them. Having done our last year, I do not believe the freezer would help. It will make them stiff and hard to manage. The second part of this sentence is certainly true. I started at the bottom pushing and pushing to compact the rubber. In the end, I cut it to what looked like almost an inch long and pushed it all in the channel. We all have or had the 1” gap from a lazy original installation. Buy the black stock. I soaked our original white ones in bleach overnight and it did not remove any of the mildew. I did not try a mildew remover as suggested above. I wanted new black stock and for under $100 they look great and should stay nice since they’re not white! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted June 10, 2025 Posted June 10, 2025 1 hour ago, jd1923 said: Having done our last year, I do not believe the freezer would help. It will make them stiff and hard to manage. Well, I certainly wouldn't leave it in long enough to get stiff. Felt tighter and buckled slightly after it was installed and warmed back up, so I'm glad I did it. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Galileo Posted June 14, 2025 Posted June 14, 2025 On 6/10/2025 at 4:02 PM, jd1923 said: I soaked our original white ones in bleach overnight and it did not remove any of the mildew. I did not try a mildew remover as suggested above. I wanted new black stock and for under $100 they look great and should stay nice since they’re not white! I honestly hadn’t expected the bleach soak to get them as clean as it did. I threw the Dawn dishwashing liquid in just for surfactant reasons. I figured I’d have to do the scrubbing again - but didn’t have to. I wonder if scrubbing them the first time (last year or so) had a residual effect. At any rate, the bleach + Dawn + water overnight definitely got the gaskets to damn-near new condition. Pleasantly surprised they came out as well as they did. 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted June 14, 2025 Posted June 14, 2025 1 hour ago, Galileo said: I honestly hadn’t expected the bleach soak to get them as clean as it did. It’s likely the age difference between our hulls. If you keep up with yours every year or two they may stay nice! 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John Dorrer Posted June 15, 2025 Author Posted June 15, 2025 Sorry guys. I forgot to post back up I replaced with the black and left an additional 3/4"-1" to push in. The cutters Patriot shared the link on were awesome. I did the work prior to the Rally. 1 3 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
