Dave Mazone Posted November 7, 2024 Posted November 7, 2024 Can anyone direct me to the Amazon product we use for the bumper molding between the propane covers? Dave & Terri Mazone 2022 LII Hull #1019 TV: 2001 Chevy Silverado 2500 HD diesel, Crew Cab (4WD)
Steph and Dud B Posted November 7, 2024 Posted November 7, 2024 I got mine from OTT. Out of curiosity, did yours pull loose in the middle? Our first seal came loose in the middle and would be sticking out when we got to our destination. I assumed it wasn't properly adhered at the factory and I replaced it after careful prep. The second one started doing the same thing. I think it's caused by airflow from underneath the propane cover while traveling. I removed the center section that had come loose, creating a small air gap, and it may have stopped the problem. 2 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderators topgun2 Posted November 7, 2024 Moderators Posted November 7, 2024 THIS is what I bought for the dog house. But, it is still in my workshop unused because I've not needed it - yet. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators SeaDawg Posted November 7, 2024 Moderators Posted November 7, 2024 (edited) We used simple door edge molding. Ours in 2008 just sat raw hood against raw base. It's been pretty good for 15 years Edited November 7, 2024 by SeaDawg 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Patriot Posted November 7, 2024 Posted November 7, 2024 (edited) @Dave Mazone If you order this for your LP tank lid and base - https://www.amazon.com/dp/B00QAJJJ3Y?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 and you have a twin bed configuration, consider ordering enough material to run two strips along the rough edges of the bed rails if you have a twin bed model. Let’s just say it really takes the edge off. 😊 Edited November 7, 2024 by Patriot 1 2 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️Recent Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Dave Mazone Posted November 8, 2024 Author Posted November 8, 2024 3 hours ago, Steph and Dud B said: I got mine from OTT. Out of curiosity, did yours pull loose in the middle? Our first seal came loose in the middle and would be sticking out when we got to our destination. I assumed it wasn't properly adhered at the factory and I replaced it after careful prep. The second one started doing the same thing. I think it's caused by airflow from underneath the propane cover while traveling. I removed the center section that had come loose, creating a small air gap, and it may have stopped the problem. Thanks. Mine did a similar thing, not quite in the center. This is the 2nd time for me too. Thanks for the tip. Dave & Terri Mazone 2022 LII Hull #1019 TV: 2001 Chevy Silverado 2500 HD diesel, Crew Cab (4WD)
DavePhelps Posted November 11, 2024 Posted November 11, 2024 I put this on 6 or 7 years ago and it still looks like new. Check the thickness of your cover to be sure the trim will fit. There are different grip ranges available. https://www.amazon.com/dp/B00QAJJJ3Y?ref=ppx_pop_mob_ap_share&th=1 4 2015 Oliver Elite 1, Hull 107 2025 GMC Sierra HD 2500 AT4, 6.6 L8T (gas)
Moderators topgun2 Posted November 11, 2024 Moderators Posted November 11, 2024 1 hour ago, DavePhelps said: I put this on 6 or 7 years ago and it still looks like new. Yep - same stuff I referenced above. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
MAX Burner Posted February 17 Posted February 17 On 11/11/2024 at 7:29 AM, DavePhelps said: I put this on 6 or 7 years ago and it still looks like new. Same here, Dave -- based on your suggestion. We also put it along the bed rails as we were getting sliced by the unfinished fiberglass edge whilst making the beds. Also put it around the spare tire cover to protect it during a wheel change, FYI. 4 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
