One tank ran dry, so I moved to the other tank—the furnace did not turn on. Then I filled the empty tank—the furnace will still not turn on. The pointer is pointing to the full tanks (both are full now) and I've moved the thermostat from on to off several times.
Any ideas?
(By the way, I searched for "Furnace does not turn on", "Gas does not turn on and no heat and got posts on axles and other things).
2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Will the range light? After changing out tanks or after prolonged storage, we sometimes have enough air in the lines that the furnace has a difficult time lighting or won’t light at all. I will usually then light the range briefly to at least purge the air from the lines to the range top. Usually the furnace will then light.
  • Like 7
Robert and Cheryl, Louisville, KY, Legacy Elite II Hull #1390 Oliphino, TV F250 Tremor
If a tank valve is opened too quickly the flow of gas can be shut down. Turn the valve slowly at first, but only enough for gas to begin to flow; then wait several seconds before turning the valve fully open. It is always good practice to purge the lines as @Rolind suggests in the manner described.
Edited by Ronbrink
Thanks! At first the range would not light but after a couple of trys it did. The furnace appeared to click on briefly (the fan came on - cold air) and then stopped.
Thanks for the tip! 🙂
Agreed, this should be standard operating procedure. My wife does this by habit every time she asks me to turn the gas on. Then we switch fridge to LP and the hot water heater on LP (when boondocking).
I've never had to turn the gas on slowly, did not realize there is an internal safety valve.
Did you check the fuse in the 12V fuse panel?
I had a similar issue a few days ago.
Ran out one tank, furnace stopped lighting. (It quit trying after two or three failures to light.) I shut off the empty tank, turned on the full tank, and flipped the tank selector to the full one. Indicator turned green. Furnace lit right off.
Next morning, no heat again. Checked the tank. Indicator on selector was red. Flipped it back and forth, no joy. Closed the full tank valve and reopened it. Voila! Indicator green, all is right with the world. Just weird though.
BTW - I never turn both tanks on. I operate off of one until it’s dry. Then switch. I just don’t want the automatic switchover to do its thing and ME not realize I’m eating up my reserves!
Only had to do the purging of air using the cooktop once. I think the Truma WH instructions mention that fix for a non-lighting condition.
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
RealTruck hard tonneau cover
Rove R2-4K DashCams
Yeah, opening the cylinder valve too fast can trigger a safety feature inside the tank; specifically an ‘excess flow valve’, at least as best I understand it.
I installed GasStop valves on each tank, which has an integral purging feature. Also great for use with gas grills, fire pits, etc., when auxiliary lines are connected to a spare tank or directly to one of the Oliver tanks
When a tank is empty likely an appliance was on.  When the propane gas stops flowing, the line pressure is equalized to atmospheric.  With connection of a fuller tank, and opening the valve there is a surge of flow.   The OPD thinks there is a line rupture (Too high flow) and cuts off the flow.
Until now, I had always thought I had to disconnect the hose from the tank to reset the OPD.  Apparently not according to AI.  AI says just turn off the valve.  Here is more AI thoughts.  (LOL that sounds weird.... AI Thoughts???):
  • Safety feature:
    The OPD is designed to protect against dangerous situations like rapid gas release, which could occur if the tank valve is opened too quickly or if there is a sudden high demand for propane.
  • How it works:
    When the flow rate exceeds a predetermined limit, the OPD valve within the tank automatically closes, restricting the gas flow.
  • What to do if this happens:
    If your propane tank stops flowing gas due to high demand, simply turn off the tank valve for a few seconds and then slowly open it again to reset the OPD.
Other potential reasons for low gas flow from a propane tank:
  • Low tank level: As the propane level in the tank decreases, the pressure also drops, leading to reduced gas flow.
  • Faulty regulator: A malfunctioning regulator on the tank can also limit the gas flow.
  • Cold weather: In cold temperatures, the vaporization rate of propane can be reduced, causing lower gas pressure.
  • Improper connection: A loose or damaged hose connection to the tank can restrict gas flow.
Some heaters, maybe all have a feature that will stop further attempts    to ignite after a certain number of failed attempts.  Our is three.  If this happens it can often be reset by turning the heat off and then back on.
I don’t trust AI interpretations. Seems like everybody is trying to ram AI down your throat. Google returns an AI “synopsis” ahead of actual search hits, Yahoo Mail was summarizing my emails. I shut that off. Fully half the time it was getting it wrong - often exactly wrong.
AI just grabs web content. That could be from sponsored sites, or crowdsourced sites that may or may not even be correct.
I tend to skip right over the AI summary, blow past the sponsored sites, and scroll down to a source that at least sounds objective and reliable.
(I had to turn off the valve, AND remove and reattach the POL connector to get the tank selector to show green. )
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Thanks Galileo and everyone - I learned a lot :). The indicator switch turned out to be the clue - I just had to keep closing and opening the tank valve until it showed green - and now I know to open slowly and am prepared for the next time 🙂
Edited by Cort
  • Like 7
Me too.  My point exactly.....
For the last 59   27 years we share the same procedure.  Off, Disconnect, Reconnect, On, Bleed line.  But I did not want to contradict another owner as I have no idea how his regulator works.  But AI says........
CRAZY HORSE Fact Check:  REVISED:  OPV's were only introduced in 1998.
Edited by Geronimo John
I didn’t know that the “recent” change to LP tanks (whatever you call that overfill prevention device - when the shape of the valve knobs changed, and propane places stopped rifling the I’d ones)  did anything except prevent it from being filled to more that XX percent of full by volume to allow for expansion.
I think the POL (“Press-to-lite”) coupler/valve is what did the shutoff if there’s too much flow. I could easily be wrong, but I remember even “old” tanks would shut off with high-flow devices. (I have a 140,000 BTU “King Kooker” burner that was good at this.)
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
On 3/5/2025 at 2:46 PM, Galileo said:
I don’t trust AI interpretations...
Yep, AI will only allow the young to be lazier than how they've been brought up!
Teaching my class this week, one new student logged into the Zoom meeting with an AI interpreter of some kind. I'm willing to bet, that she by counting on technology, will learn and retain far less than the average student! Give me a break! "Just Say No" when anything pops up on your screen!
I've never noticed anything colored green on the tank selector. Am I missing something or perhaps our older hull is different. I turn it left until the first tank is empty or near empty as shown on our Mopeka sensor, then I switch to the RH tank. Never noticed a color, or maybe I'm colorblind!
Sorry if I’m using the wrong term or if my not including a picture is making it less obvious.
Whatever that Thingamabob that connects the two tanks together and has a little lever that swings left and right is called. Ours has a little indicator that shows 2 green “sectors” if the tank is supplying gas. I think it shows red if no gas (but it might show black - I’m 400 miles from the trailer at the moment).
Anyway, it’s the contraption that is supposed to automatically switch tanks when the primary one runs out of gas. I never use that function as I don’t wanna end up with both tanks empty because it switched and didn’t tell me.
If the little indicator is dirty, or you are just viewing through the round access port of the front of the propane enclosure, you may never see the indicator. (So you may not want to deviate yourself colorblind just yet!)
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Thingamabob
= Regulator.
if you mean to NOT have the automatic change over feature of this Regulator engaged then this "little lever" should point to the tank that you would like to use.  When that tank is empty then simply move the "little lever" such that it points to the other tank.
Thanks, me too so I've not noticed the green. I too like to know when to refill the first tank!
6 hours ago, topgun2 said:
= Regulator.
Since I could screw that up fairly easily, I opt for the old school methods of assuring that one tank stays full: closing the valve.
”Regulator” sounds like such a pedestrian moniker. Shouldn’t it be something more ostentatious like “Regulator with automatic tank selection and gas status indicator”?
Anyway, the 30-second “orientation” we received on delivery day was all of the insight I have on the device. I’d have to actually READ the manual to have any confidence in my ability to operate it without shooting myself in the foot.
Back in my motorcycle riding days, there was a “on” setting on the fuel taps that left about 8/10 of a gallon in the tank to limp home on “reserve” when you spaced out and forgot to monitor your fuel. That’s how I use the “regulator”.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
  • 2 months later...
Yes, you are correct. I had never notice the color line before, hard to see if you have the doghouse attached. I open the valve on the curbside tank and use that until empty and then switch to the other so I know when one is empty. The down side is you can run out on a could night and the furnace would stop. Now that I have the Mopeka sensors, I guess i could start using the auto switching feature. But since having them I just make a manual switch when it reads about 10% full.
I had a similar issue once—ended up being air in the gas line after the tank ran dry. I had to light the stove first to bleed the line, then the furnace kicked on. Might be worth a try. Also check the fuse just in case.
This indicates that the sail switch in the furnace is not operating properly.
This happened to me several times the first year I had the trailer until I added a filter behind the air inlet grate in the aisleway.  Fine lint was being ingested through the inlet vent and wrapping around the sail switch which finally made the sail switch stick.  I removed the switch from the outside and removed the spun on lint and it worked fine for a while.  I did that 3 or 4 times.   It finally needed to be replaced so I did and got a backup switch as well.  Now 2 years later I've not had to bother with it although I check to make sure lint is not accumulating again.  The filter did the trick for me.  We full time so the furnace gets used plenty.  The furnace will not light unless the fan blows the sail switch to a position for a determinate amount of time and then allow propane to pass for ignition.  The fan just blew cold and then shut down and made me think I was out of propane :)
Good luck,
Edited by johnwen
