ZLarryb Posted March 30, 2025 Posted March 30, 2025 Thought this might help someone else out. The water pump was not working. The main switch light was on and functional. The bathroom switch was functional. No noise from the pump at all. I opening the compartment and immediately saw that one of the wires had come loose from the pump. I plugged it in and all is well. I think I will go back in and try to tighten the connection. Hull 1467 4 1
Ronbrink Posted March 30, 2025 Posted March 30, 2025 1 hour ago, ZLarryb said: one of the wires had come loose from the pump Good catch! Same thing happened to me early in ownership; crimped the spade connector for a tighter fit, no further issues. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
tallmandan Posted March 30, 2025 Posted March 30, 2025 @ZLarryb I could be wrong...but in your photo it appears that your plastic twist connector fitting on your water line has loosened with vibration. This has been a reoccuring issue with my trailer and I periodically check all the twist fittings for tightness. In your photo, it's the line toward you with the black plastic tie-down that is out of place. I have loosened the black plastic tie downs, placed a thin piece of rubber or silicone (even a piece of a rubber band) between it and the twist fitting and then re-secured it. This has helped prevent loosening of those fittings. Just something to check....? 5 2020 Elite II #627, 2026 Toyota Tundra Platinum Hybrid, Colorado
Moderators Mike and Carol Posted March 30, 2025 Moderators Posted March 30, 2025 We also experienced this on a trip in 2017. Both wires were loose and I had to feel around the bottom of the pump to figure out where they were supposed to attach. Crimping has prevented this from happening since. Mike 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
ZLarryb Posted March 30, 2025 Author Posted March 30, 2025 I really want to check this but I am not sure what this is "plastic twist connector fitting on your water line". There are lot of fittings down there. ;-} Please take a second and help, thanks
Patriot Posted March 30, 2025 Posted March 30, 2025 Always nice to pass along a quick fix! Thanks! 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators mossemi Posted March 30, 2025 Moderators Posted March 30, 2025 5 hours ago, tallmandan said: I could be wrong...but in your photo it appears that your plastic twist connector fitting on your water line has loosened with vibration. This has been a reoccuring issue with my trailer and I periodically check all the twist fittings for tightness. In your photo, it's the line toward you with the black plastic tie-down that is out of place. ZLarryb, the plastic connector/tee fitting nut is the red notation. the black plastic tie-down is the yellow notation. the green arrow is pointing to the green "witness marks". Witness marks are sometimes used to mark a 2 part connection like a nut and bolt or in this case it marks both sides of the water pipe connection. It is marked during installation on both sides of the connection and it is a quick visual confirmation of a connector being in the original position or not. Due to the angle of your picture, I can’t verify its position because I can’t see both side of the mark, but you can do a quick verification. Mossey 2 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Columba Posted June 2, 2025 Posted June 2, 2025 On 3/30/2025 at 6:32 AM, ZLarryb said: Thought this might help someone else out. The water pump was not working. The main switch light was on and functional. The bathroom switch was functional. No noise from the pump at all. I opening the compartment and immediately saw that one of the wires had come loose from the pump. I plugged it in and all is well. I think I will go back in and try to tighten the connection. Hull 1467 This very same thing has happened to me! Thanks for posting this! I had no idea why my water pump wasn't working...until I found this. I'm a newbie and trying to sanitize my freshwater system before filling the freshwater tank. I'll be camping somewhere in a couple of weeks with no access to city water. Thank you, thank you, thank you!! Lisa Jones and "Columba", Hull #1475 4
rich.dev Posted June 17, 2025 Posted June 17, 2025 @ZLarryb those white John Guest push to connect fittings are notorious for coming loose, check them all periodically like this 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Columba Posted June 19, 2025 Posted June 19, 2025 My plastic connector/wire providing power to the pump keeps coming unplugged while trailering or when using water. What is the best tool to use or best method of firmly securing this connection in place so this doesn't continue to happen? I'm a newbie so appreciate your patience with my question. Thanks! Lisa Jones and Columba (Hull #1475)
Ronbrink Posted June 20, 2025 Posted June 20, 2025 (edited) 15 hours ago, Columba said: My plastic connector/wire providing power to the pump keeps coming unplugged while trailering or when using water. What is the best tool to use or best method of firmly securing this connection in place so this doesn't continue to happen? I'm a newbie so appreciate your patience with my question. Thanks! Lisa Jones and Columba (Hull #1475) You can carefully compress the rolled edges of the female spade connector using needle nose pliers to create a tighter fit onto the male spade. Try doing this in-place while connected, if room allows, to prevent over compressing. Otherwise, disconnect and gently squeeze the rolled edges for a tighter fit. Alternatively, replace the female spade connector either by crimping on a new one or splicing a short section of terminated wire with the proper fitting. Edited June 20, 2025 by Ronbrink 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted January 2 Posted January 2 (edited) On 6/20/2025 at 1:21 AM, Ronbrink said: You can carefully compress the rolled edges of the female spade connector using needle nose pliers to create a tighter fit onto the male spade. For those of who are "Ham Fisted", I have found that my "carefully" crunching is not carefull enough. I suggest unplugging the connection and use a small pair of vice grips. I can crunch it in a much more measured manner. GJ Edited January 2 by Geronimo John 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted January 2 Posted January 2 5 minutes ago, Geronimo John said: For those of who are "Ham Fisted", I have found that my "carefully" crunching is not carefull enough. I suggest unplugging the connection and use a small pair of vice grips. I can crunch it in a much more measured manner. GJ You are correct, I have used that technique upon occasion when a more critical application of pressure is required for a fix. Thanks for your insight! 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
