Cort Posted June 25 Author Posted June 25 On 6/20/2025 at 8:09 AM, John Dorrer said: This has nothing really to do with Oliver. 3500 lb axels and 6 year old trailer. The main contributing cause for these 4 leaf failures, are living near the coast, driving on chemically treated roads, resulting in rusting. The OP was clear on his driving on a washboard road with deep chuck holes. This is a sure way to have 4-leaf spring failure. Starting in 2022 Oliver went to the 5200 lb axels. There have been few if any failures on the trailers from 2022 to present. I don't know if this referred to me or someone else. In my case the Oliver I ended up buying did not have rust issues and the roads I was driving on were not washboard with deep chuck holes - just very rocky. I guess you can break these springs in many different ways. 2 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Cort Posted June 25 Author Posted June 25 On 6/20/2025 at 1:08 PM, Geronimo John said: Likely you are a bit younger and more agile than this ROF (Retired Ole Fart) and could get a both sides done a LOT faster. While boondocking, do suggest a sheet of sturdy plywood for the jacks. WIll make your life a lot easier than moving the floor jack around the sand/dirt without it. GJ Actually not! I FINALLY got both sides done but the U bolts on one side took hours and then there were the hours of making mistakes...Thanks for the plywood idea I carry several traction mats which have helped out a lot with jacking at times - and in fact came in handy with this job. 2 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
John Dorrer Posted June 25 Posted June 25 6 minutes ago, Cort said: I don't know if this referred to me or someone else. In my case the Oliver I ended up buying did not have rust issues and the roads I was driving on were not washboard with deep chuck holes - just very rocky. I guess you can break these springs in many different ways. I was replying to richdev🙃 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Cort Posted June 25 Author Posted June 25 On 6/20/2025 at 3:11 PM, raye said: Cort: Nancy and I in Boulder City, Nevada will be leaving here and passing through Flagstaff around noon or so. Heading east. If you have not resolved your Leaf Spring problem, as you know I travel with a lot of tools in the event... like yours. Nancy is checking to see if she can find your cell number, but you may have it. Will be towing the 2019 Oliver Elite... so easy to see Off the Grid, as well. Nancy did not have your cell number and have no way to contact you, otherwise. You met our Cattle Dogs and we can figure out if you need help, or not. Once we leave here, we are pretty much Off the Grid. Ray Thanks so much, Ray and Nancy, for dropping by. Ray and I spent several hours trying in vain to get the shackle bolts I think they are calle off (the two in the front). What we didn't realize is that we were working on the wrong bolts. I was using the "Trailer Smith's YouTube channel directions but he must have been referring to a different type of spring. ((I don't know how that's possible actually (lol)) The trailer Smith has people locking down the back nuts and then twisting the front ones loose with a breaker bar. Those front ones, though, have splines that keep them dug in. (I was able to get the rearmost bolts off that attack the other end to the trailer off using his procedure - so maybe I just had very stuck bolts.. I have a nice breaker bar, but no matter which position Ray and I tried we couldn't budge them. I was thinking of getting a compact wrench, but then Steve called and he said to work on the back nuts, and those came free easily! Thank you, Steve! 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Geronimo John Posted June 25 Posted June 25 (edited) 14 minutes ago, Cort said: FINALLY got both sides done but the U bolts on one side took hours and then there were the hours of making mistakes... As previously posted, for most of us there certainly is a rather large learning curve involved in spring and/or axle upgrades. But the knowledge gained by DIY is priceless. GJ PS: A can of Blaster is an essential tool for rusted anything. Sorry none of us mentioned that in any of our posts about springs. Amazing. Edited June 25 by Geronimo John PS added. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Cort Posted June 25 Author Posted June 25 On 6/20/2025 at 6:17 PM, Geronimo John said: That leaves you with two more springs begging to fail. Suggest if the cost of the ALCON's are a concern, then get four of the Dexter PR4's. It is 2400 # rated. Steve mentioned that as well + a less well-balanced trailer. I have the leaf strings off both sides - as I noted, the u-bolts were a challenge on one side. They started off very easy and got torturously more difficult as they got closer to the end. I was afraid I was going to break them or the breaker bar 🙂 but they're off. I'm going to try to find a way to get the 4 Alcan springs to Flagstaff. At some point, I expect to do the 3500-5200 upgrade. I will check with Alcan to see if the same springs can be used for both axles. First, though, I'm checking with the National Forest Service to make sure this area is not going to be closed down. The other side of 180 was. Thanks for everyone's help. 1 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Cort Posted June 25 Author Posted June 25 5 minutes ago, Geronimo John said: As previously posted, for most of us there certainly is a rather large learning curve involved in spring and/or axle upgrades. But the knowledge gained by DIY is priceless. GJ PS: A can of Blaster is an essential tool for rusted anything. Sorry none of us mentioned that in any of our posts about springs. Amazing. Once again, I have learned so much! I hardly knew what an axle or leaf spring was prior to this (let along a compact wrench, which I didn't need). I hit them again and again with silicone lubricant - I don't know how much good this brand did and if there's a better one I will get it. I am going to get a wire brush to try to clean down those rusted nuts. 1 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
BoondockingAirstream Posted June 25 Posted June 25 Cort and I discussed several options at his remote campsite. He is going to be an Excellent Mechanic after working on these two leaf springs. #1 Removing the nuts from the bolts on the center connections... Even with two of us attempting... removing a nut was not cooperating. The nut on the bracket on the frame, Cort had already removed, using a 24"+ breaker bar. One of us holding the head of the bolt from rotating and breaker bar... no luck at all. Someone may have a technique to offer, as the nut was not going to cooperate. That got our attention immediately. Cort is a master navigator getting into tough areas. With the forward Axle firmly attached... Getting OUT is opposite everything. Easy IN, can be a Difficult OUT. #2. We discussed "Backing Out", but needed prep time to get everything ready would take some reversing the Forward 'getting into this space' to Backward 'reversing to get out without some extra eyes or in and out of the tow vehicle'. The broken leaf spring could be tied up for clearance, shocks removed. Sounds easy... but not a linear departure and possble shoveling to make additional space 'more attractive'. Angles going IN are not the same as getting OUT. (2) Replacing the Leaf Springs need these 'four stubborn nuts from the bolts', removed. Replaced with Six new greased replacement nuts and bolts. (3) Have a mechanic with equipment to Remove and Replace with the Replacement Leaf Springs and nuts. Also guide the Master Boondocker Cort backing out. Cort is very patient. Methodical is the word and he likes to consider all options. (4) When getting to our campsite leaving the next day, I thought about contacting the Forest 'Service'. They have resources and people to help citizens. This could be #1, there were hundreds of campers in this large area and certainly had USFS patrolling the area. (5) Cort's tow vehicle was detached and could drive into Flagstaff for supplies and leaf spring pickup. The City was swarming with a massive number of tourists, including lots of campers in the forested areas, as we drove out. Narrow hard pack dirt roads and lots of wide RV's... But, lots of possible access for help and getting his Leaf Springs ordered and picked up. Our third day in the Gila National Forest... the weather bureau predicted heavy showers... we broke camp. Once out of the Gila National Forest, heading north to Highway 40... heavy rain for an hour and a FREE washing. We arrived back home around midnight. Exhausted but out of the back country. Cort will have a more interesting story to tell. I also would like to know how the nuts were removed. They are also Metric... Learn something every day. 1
Cort Posted June 25 Author Posted June 25 3 hours ago, BoondockingAirstream said: Cort and I discussed several options at his remote campsite. He is going to be an Excellent Mechanic after working on these two leaf springs. #1 Removing the nuts from the bolts on the center connections... Even with two of us attempting... removing a nut was not cooperating. The nut on the bracket on the frame, Cort had already removed, using a 24"+ breaker bar. One of us holding the head of the bolt from rotating and breaker bar... no luck at all. Someone may have a technique to offer, as the nut was not going to cooperate. That got our attention immediately. Cort is a master navigator getting into tough areas. With the forward Axle firmly attached... Getting OUT is opposite everything. Easy IN, can be a Difficult OUT. #2. We discussed "Backing Out", but needed prep time to get everything ready would take some reversing the Forward 'getting into this space' to Backward 'reversing to get out without some extra eyes or in and out of the tow vehicle'. The broken leaf spring could be tied up for clearance, shocks removed. Sounds easy... but not a linear departure and possble shoveling to make additional space 'more attractive'. Angles going IN are not the same as getting OUT. (2) Replacing the Leaf Springs need these 'four stubborn nuts from the bolts', removed. Replaced with Six new greased replacement nuts and bolts. (3) Have a mechanic with equipment to Remove and Replace with the Replacement Leaf Springs and nuts. Also guide the Master Boondocker Cort backing out. Cort is very patient. Methodical is the word and he likes to consider all options. (4) When getting to our campsite leaving the next day, I thought about contacting the Forest 'Service'. They have resources and people to help citizens. This could be #1, there were hundreds of campers in this large area and certainly had USFS patrolling the area. (5) Cort's tow vehicle was detached and could drive into Flagstaff for supplies and leaf spring pickup. The City was swarming with a massive number of tourists, including lots of campers in the forested areas, as we drove out. Narrow hard pack dirt roads and lots of wide RV's... But, lots of possible access for help and getting his Leaf Springs ordered and picked up. Our third day in the Gila National Forest... the weather bureau predicted heavy showers... we broke camp. Once out of the Gila National Forest, heading north to Highway 40... heavy rain for an hour and a FREE washing. We arrived back home around midnight. Exhausted but out of the back country. Cort will have a more interesting story to tell. I also would like to know how the nuts were removed. They are also Metric... Learn something every day. 🙂 It turned out to be very simple. We were working on the wrong bolt ends. I was misguided by a YouTube video which described securing the nuts on the back and working on the bolts on the front. Steve informed me, though, that we would have been working on the nuts on the back of the shackle.. Once I did that, they came off easily (lol) It is not going to be a linear departure. Ray was kind in saying the trailer was in a bit of a difficult spot. After a long and exhausting day I walked ahead to check out a meadow ahead. I thought the coast was clear but later I had missed the narrowed path directly ahead of the van (Lol). It'll just take some maneuvering. 1 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Cort Posted June 25 Author Posted June 25 Alcan leaf kit has been ordered. Something I didn't know. They can ship to a UPS outlet using USP or FED Ex. THey're be here in a couple of days. 3 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Geronimo John Posted June 26 Posted June 26 12 hours ago, Cort said: They started off very easy and got torturously more difficult as they got closer to the end. I was afraid I was going to break them or the breaker bar 🙂 but they're off. Sounds like the nuts may have been Nylocks jamming themselves to a total stop. Happens when they are installed too tightly. Cutting them off has generally been one path. The other is to break the bolt/Ubolt with a hack saw. If they were not Nylocks, then Blaster overnight is the easy way. 10 hours ago, BoondockingAirstream said: I also would like to know how the nuts were removed. They are also Metric... Learn something every day. On an OE2? Not likely. Would be worth asking Jason that question. Or they were an after market swap for some reason. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
DaveAndBecky_NorthernMI Posted June 26 Posted June 26 On 6/20/2025 at 5:06 PM, Geronimo John said: Moderators: As such, it would be a wonderful public service for OTT to put out a Service Notice about how to inspect these springs and at what point they recommend upgrading to a heavier spring. For those of those of us choosing to monitor the springs until they can be upgraded, inspection guidance from Oliver would be very helpful, particularly the sag seen prior to failure. 1 2022 Oliver Elite II Hull#1047 "Saunter" Solar Pro 390 aH Lithionics 2022 Ram 1500 5.7L Hemi
Cort Posted June 26 Author Posted June 26 12 hours ago, Geronimo John said: Sounds like the nuts may have been Nylocks jamming themselves to a total stop. Happens when they are installed too tightly. Cutting them off has generally been one path. The other is to break the bolt/Ubolt with a hack saw. If they were not Nylocks, then Blaster overnight is the easy way. On an OE2? Not likely. Would be worth asking Jason that question. Or they were an after market swap for some reason. They were not Nylocks - glad to hear about the hacksaw idea - I was thinking about that. I think in the video the guy said they just cut them off at the shop. 1 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Geronimo John Posted June 26 Posted June 26 42 minutes ago, Cort said: I think in the video the guy said they just cut them off at the shop. Torch, hand grinder, hack saw , or even a cold chisel. All will do the job, just a matter high your PITA threshold is. Mine is pretty low, and for weight conservation I carry a Dremel Kit with reinforced cut-off wheels. They last a LOT longer than the non-reinforced ones. But they are also more expensive. Worth the cost IMO. As a result, I don't carry a torch, hand grinder, hack saw , or even a cold chisel. GJ 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Cort Posted December 21 Author Posted December 21 (edited) I never finished this up. I'm sure I set a record by being there for six weeks. GIven that I'm also working full time I was only able to work on it intermittently. Still, it was a long pull. Along the way, the last lug nut on the last tire I needed to remove, stuck. Given Ray's warnings, I was already planning to replace the lug nuts and had them ready. I ordered a lug nut removal kit from Amazon and got the lug nut off. Those kits are cheap and effective and many are available. Given how soft the lugs that come with these trailers are, they're a good thing to have. I ordered this one https://www.amazon.com/dp/B0869BR8MG?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1 (Since the extractor is terminally attached to the bad lug nut I need to get another one :)) Then I got all the way to the last leaf spring and couldn't get it quite to fit. It was very close but time after time I couldn't get the nub of the plate to fit into the hole in the axle. When I brought it to a repair shop the guy looked at the trailer and said he was surprised - he expected to see something that was really off but it looked fine - the wheels were running true. Still it needed to be done and they were able to get everything to fit. (They also fixed a water pipe that broke on the rough roads. (Stay away from roads on the very southern end of mountains down from Flagstaff). Some things I learned. I should not have counted on a video which apparently showed a generic trailer - not an Oliver - it was inaccurate - and cost me a lot of time and energy. I should have gone straight to experienced Oliver people on the forums for help. I should have worked on one whole side at a time instead of one leaf spring at a time. At one point I had the trailer totally lifted up on 4 jacks - and when I was putting a tire on the trailer fell off the rear right one. I would not lift the entire trailer again. 🙂 The Alcan leaf springs are monsters compared to the leaf springs that came with the trailer. They appear to be about twice as heavy. I'm very happy to have them. Not all was good with Alcan, though. Despite the fact that I tightened the four bolts holding that plate in unison one of the nuts on the new jammed. It really jammed. I could not get it off with an impact wrench! don't know what happened, but I was astonished that a brand-new bolt/nut could get stuck like that. . (The shop got it off). I believe the bolts that go through the plate are far longer than they need to be. They stick way down - and could get hit more easily - and they take more time and effort to get on and off. I emailed Alcan about this and they did not return my email. More concerning was the fact that some of the shackle bolts were too short. They were so short that only about half the nut would fit on it. The repair shop advised putting longer shackle bolts in and we did. Everything has worked fine since then, and as I said I'm very happy to have those beefy springs on 🙂 (I still plan to upgrade to heavier axles). (The next fun came when a week after this got done the engine on my 2 year old van seized. It took several months to get that worked out.) Thanks, in particular, to Steve for all his help and guidance, as well as to everyone else. 🙂 Edited December 21 by Cort 1 1 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Geronimo John Posted December 22 Posted December 22 7 hours ago, Cort said: At one point I had the trailer totally lifted up on 4 jacks - and when I was putting a tire on the trailer fell off the rear right one. I would not lift the entire trailer again. Bet that experience resulted in a few "bad words" as another famous owner has had. Glad you were not hurt and figured it out. One suggestion that many owners have adopted when working on the tires and/or axles, or for that matter anything under Ollie, is to leave the trailer connected to your 6,000 pound anchor (TV). When doing so, tie flagging to the steering wheel as a reminder not to drive off. The anchor will help stabilize things a bit. Another is to try always to do such work on a "Hard Stand" such as asphault or concrete. If not on such a surface, place dunnage under your jack feet to reduce the possibility of one of the jacks sinking in a soft spot. This has happened before. GJ 5 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted December 22 Posted December 22 7 hours ago, Cort said: Not all was good with Alcan, though. First complaint of Alcan Springs written on this Forum! When these U-bolts are torqued down there is about 1 1/4" extra length in threads which is needed for assembly so you do not have to have everything lifted perfectly into place. They are just as low as the bottoms of the shock studs. If wet bolts were too short, they could not be mounted. ALL of mine have exactly two threads protruding from the Nyloc nuts when torqued. Best to replace axles and leaf springs at the same time, so not to double your effort. I ordered D52 axles through Alcan as an authorized Dexter dealer. Dexter did not pack the axles properly and they were damaged in shipment. Alcan took the lead and got me a rush replacement order, asked Dexter to secure the axles on a doublewide pallet, got my shipping costs refunded and allowed me to keep the damaged axles for spare parts! We sent at least a dozen emails back and forth. There was not one time where Lew or Tim did not reply within 1-2 hours or by 8AM when I sent an email after hours. Just this morning I retorqued the U-bolts, for the last time, since all nuts on all U-bolts were still at 90 ft-lbs after not too many miles. I've been restoring cars, trucks, and trailers for over 45 years. Alcan Springs are very good custom parts and everything was complete. Lucky again you did not damage the Oliver, or hurt yourself, allowing a jack stand to slip. You did not show pictures of said issues. Good pictures and more on the "Alcan experience" can be found here => 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Cort Posted December 22 Author Posted December 22 (edited) 14 hours ago, Geronimo John said: Bet that experience resulted in a few "bad words" as another famous owner has had. Glad you were not hurt and figured it out. One suggestion that many owners have adopted when working on the tires and/or axles, or for that matter anything under Ollie, is to leave the trailer connected to your 6,000 pound anchor (TV). When doing so, tie flagging to the steering wheel as a reminder not to drive off. The anchor will help stabilize things a bit. Another is to try always to do such work on a "Hard Stand" such as asphault or concrete. If not on such a surface, place dunnage under your jack feet to reduce the possibility of one of the jacks sinking in a soft spot. This has happened before. GJ Oh yes, many exclamations 🙂 Nice idea keep them connected - that would have stopped things. Right -0 I was working on a dirt road - which softened up considerably after a big rain - causing jack stands to sink and droop. Another thing to take into account ... Edited December 22 by Cort 2 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Geronimo John Posted December 22 Posted December 22 34 minutes ago, Cort said: Oh yes, many exclamations 🙂 Nice idea keep them connected - that would have stopped things. Right -0 I was working on a dirt road - which softened up considerably after a big rain - causing jack stands to sink and droop. Another thing to take into account . I periodically mention especially these two safety tips, mostly for new owners to the forum.... and to keep especially these three safety tips "top of mind" for us older ones. 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Cort Posted Tuesday at 05:02 PM Author Posted Tuesday at 05:02 PM On 12/21/2025 at 5:45 PM, jd1923 said: First complaint of Alcan Springs written on this Forum! When these U-bolts are torqued down there is about 1 1/4" extra length in threads which is needed for assembly so you do not have to have everything lifted perfectly into place. They are just as low as the bottoms of the shock studs. If wet bolts were too short, they could not be mounted. ALL of mine have exactly two threads protruding from the Nyloc nuts when torqued. Best to replace axles and leaf springs at the same time, so not to double your effort. I ordered D52 axles through Alcan as an authorized Dexter dealer. Dexter did not pack the axles properly and they were damaged in shipment. Alcan took the lead and got me a rush replacement order, asked Dexter to secure the axles on a doublewide pallet, got my shipping costs refunded and allowed me to keep the damaged axles for spare parts! We sent at least a dozen emails back and forth. There was not one time where Lew or Tim did not reply within 1-2 hours or by 8AM when I sent an email after hours. Just this morning I retorqued the U-bolts, for the last time, since all nuts on all U-bolts were still at 90 ft-lbs after not too many miles. I've been restoring cars, trucks, and trailers for over 45 years. Alcan Springs are very good custom parts and everything was complete. Lucky again you did not damage the Oliver, or hurt yourself, allowing a jack stand to slip. You did not show pictures of said issues. Good pictures and more on the "Alcan experience" can be found here => Thanks! I think somehow a few of the wrong bolts got sent. Here the Ubolts - probably not a big deal but taking them on off multiple times as I tried to get everything aligned was work. 2 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
David and Gail Posted Tuesday at 08:14 PM Posted Tuesday at 08:14 PM (edited) @JD1923, Is this the picture you’re looking for? Edited Tuesday at 10:49 PM by David and Gail Typo 2018 Ram 1500, 4x4, 5.7 hemi , Anderson WHD 2025 Oliver Legacy Elite ll, Hull # 1585,Platinum pkg, Twin bed floor plan, Street side awning option
