Tony and Rhonda Posted July 17 Posted July 17 The feet on our stabilizer jacks are pretty rusty. Is this normal for our age camper? If it's normal wear and tear, I'll leave it as is. If not, I'll remove, de-rust and repaint. The caulking where the jack penetrates the hull is not very pretty and it looks like gravity has caused it to separate from the camper body is a few places (not visible in my soft photo). What caulking is recommended? Thanks, Tony New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (still with original engine) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Rivernerd Posted July 17 Posted July 17 That's not an unusual amount of rust for an 8-year-old trailer that lives in Kentucky. I would apply Rust Mort to the jack foot plate, then a metal primer, then black spray paint. I would cut off the old caulk, then apply butyl caulk at the jack penetration point. 3 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Patriot Posted July 17 Posted July 17 Tony, As a part of regular maintenance if it were me I would remove and clean and buy a quality can of black semi gloss rattle can paint up those jack “feet”. Just me. Mine are still in good shape and have not rusted. I do not winter camp so that is likely why. Not sure if you live in a Northern State, but sodium chloride is brutal on all things metal. While you’re under there clean off the old caulk and reapply a fresh bead. Good on you for inspecting these areas! 👍🏻 There is always something to do regarding ongoing maintenance, but once you knock it, out at least for me it’s a great feeling. Thanks for posting! Patriot 🇺🇸 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Patriot Posted July 17 Posted July 17 (edited) If you feel inclined to do so. Consider replacing your square “jack foot” with a round one. Then you can install these- https://rvsnappad.com/ or https://rvsnappad.com/collections/all-singles I have had a set of three of these on since delivery day and really like them. No imprinting if parked on a black top campsite pad. Happy Trails! Edited July 17 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators Mike and Carol Posted July 17 Moderators Posted July 17 We’ve got the round jack feet. Like Patriot, I have a regular routine of cleaning up and painting the feet and the bulldog hitch. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted July 17 Posted July 17 3 hours ago, Tony and Rhonda said: The feet on our stabilizer jacks are pretty rusty. Is this normal for our age camper? First thing I noticed is the jack feet on your Oliver are much different from our Hull #113. Ours are round and flat vs. oblong and dished. I rebuilt our front jack to properly service and grease it. The first photo shows the jack stand with shaft brushed clean to metal and the foot was cleaned, but NOT painted (jack stand in mid air when pictured). I'm generally against paint, especially for the bottom where pressure will just make the paint peel. But our Oliver has mostly been in warm dry climates. The second picture is one I took when we had a steep uphill dump station. Pictured here to show the Andersen Hitches Trailer Jack Blocks. We use one of these always for the rear levelers (the two shown) and the stackable 1" blocks for the front. I don't believe the feet on our jacks will ever need anything but soap and water to clean. I would replaced the feet on yours with the round kind pictured and get a set of these Andersen products! https://www.amazon.com/ANDERSEN-Accessories-Stabilizers-Jackstand-Quickjack/dp/B0754NWJGR/?th=1 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Tony and Rhonda Posted July 17 Author Posted July 17 Thanks for the responses. The pad on the front jack is round and it looks fine. At least for now, I'll take our rear pads, brush off as much rust as possible, then repaint. @Patriot Are there advantages to using round jack pads vs. the rectangular ones installed on our camper? Which jack pads (size, model) are you using? I had no idea there were so many options to choose from. @jd1923 Your jack shafts are shiny! Ours are not but I'm considering cleaning ours up. Did you use a wire brush in a drill to clean them? The Andersen Jack Blocks are on our purchase list. Thanks, Tony New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (still with original engine) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Patriot Posted July 17 Posted July 17 (edited) 2 hours ago, Tony and Rhonda said: Are there advantages to using round jack pads vs. the rectangular ones installed on our camper? Which jack pads (size, model) are you using? I had no idea there were so many options to choose from. This is the size I ordered and they fit perfectly on the front jack and rear stabilizers. Your steel jack and stabilizer “foot” must be round as shown in the link below. (Vid) You can read about the benefits of using snap pads, and watch the video in the description- https://www.amazon.com/dp/B081HHY9VM?psc=1&ref=ppx_pop_dt_b_product_details Edited July 17 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted July 17 Posted July 17 2 hours ago, Tony and Rhonda said: @jd1923 Your jack shafts are shiny! Ours are not but I'm considering cleaning ours up. Did you use a wire brush in a drill to clean them? The Andersen Jack Blocks are on our purchase list. Tony, I clean most grimy auto parts with Go-Jo hand soap (not the pumice kind). It cleans grease and oil off the mechanics hands and does well with cleaning most parts safely without abrasives or solvents. I worked it in with very fine steel wool, that's it. I detailed this and a complete and thorough maintenance of the Stabilizer Jacks on page two of this old Forum post. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Tony and Rhonda Posted July 18 Author Posted July 18 Thanks for the links, I'll take a look. Tony New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (still with original engine) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Ronbrink Posted July 19 Posted July 19 I’ve been using this, which is a cheaper alternative to the product @Rivernerd recommended. To his point however, treating moderate to heavy rust prior to priming/painting is the best practice. Each of these product cure to a black color and thus, I apply to black-painted components of both the Oliver and TV to deter rust and restore appearance, as needed, to include the Bulldog hitch and hitch receiver, respectively. That said, I have not found a need to repaint treated surfaces where minor surface rust is being combated. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted July 19 Posted July 19 On 7/17/2025 at 8:42 AM, Patriot said: If you feel inclined to do so. Consider replacing your square “jack foot” with a round one. Then you can install these- https://rvsnappad.com/ or https://rvsnappad.com/collections/all-singles I have had a set of three of these on since delivery day and really like them. No imprinting if parked on a black top campsite pad. Happy Trails! Which size fits the round jack foot? Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted July 19 Posted July 19 (edited) 55 minutes ago, Ronbrink said: Which size fits the round jack foot? I posted this in the thread above - this is what I ordered and it fits perfectly. -https://www.amazon.com/dp/B081HHY9VM?psc=1&ref=ppx_pop_dt_b_product_details Edited July 19 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Ronbrink Posted July 19 Posted July 19 8 minutes ago, Patriot said: I posted this in the thread above - this is what I ordered and it fits perfectly. -https://www.amazon.com/dp/B081HHY9VM?psc=1&ref=ppx_pop_dt_b_product_details Yikes, how did I miss that! I read this post on Thursday and went to the website you referenced. Because there was no specific size listed for an Oliver, I answered some questions and requested their recommendation on proper fitment; their response, “I’m not sure which SnapPads are needed!”. So I fired off my question to you without revisiting your previous post. Thanks for assisting the elderly! 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted July 19 Posted July 19 (edited) 29 minutes ago, Ronbrink said: Yikes, how did I miss that! Welcome to my world Ron! 😄No worries, I feel pretty sure the Amazon pads will work for you! 👍🏻👍🏻 Edited July 19 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
