I’m not even sure that’s what they are called.  But mine have started to fail, even wiggling out on occasion. 😩So I want to buy 2 new ones. I can’t find them on the internet and the mothership doesn’t have them for sale.
Any ideas?
An occasional good cleaning and a shot of WD-40 will make these things last a long time.  Pay particular attention to the little "ball" in one end and the "push button" in the other and also give the holes in the bumper a little shot of lube (WD-40 or something similar) from time to time.
p.s.  you might also take a look in Tractor Supply if that is easier - they used to carry these pins.
  • Like 7
  • 4 weeks later...
I replaced mine a number of years ago. Don't recall my source. You should search for marine stainless steel quick release pins. You will find a variety of lengths and diameters with and without leashes.  The marine grade are spendy but they will not corrode.
Fieldbrook, Ca
Dennis and Melissa; your first photo appears to show the small 'ball' in the end of the pin is missing.
Perhaps it's my eyesight.
That small ball is the only thing that will keep the pin from making its way free.
2023 Elite #1403--2019 Ford F150--2.7 Ecoboost V6--10 speed auto--without Max Tow
I use spray white lithium grease, then wipe off the excess with a paper towel.  Lasts longer than WD-40.
Any marine supply store will have them.
Try West Marine.
Another thought - if pin detent ball is frozen, then the pin could conceivably back out.  Make sure the plunger and detent ball are lubed and move freely.
Edited by Jim and Chris Neuman
Thanks everyone.  I bought 2.  One is already functioning as a replacement.  The other has been added to the Ollie's garage. 🙂
On 11/18/2025 at 7:52 PM, johnwen said:
Also, try "pip pins"  🙂
Yep. That's how I was taught of few 'centuries' ago!
I had to take one of my pins off the ring, put it on the workbench, and I used WD-40 over and over again to work it into the pin, standing up on end (locking-balls) facing down, and worked the button until it would stay freed up.  I kept flushing it until about 40 gallons of rust came out of the pin and I saw clear WD-40 flowing. I then used to dry lube and worked it into the ping constantly pushing the button to work it through.
That was 2 or 3 years ago and that stubborn button pin has been fine since.
Might be one of those annual things-to-do to put on the list, that I don't have yet.  LOL
Chris
2016 Legacy Elite II  o-o  Hull #110  o-o  "Rock'in 110"  o-o  Wayfinder (old) o-o  Twin Bed
2020 RAM 1500 Limited 5.7L
Augusta, Georgia
