Buddhabelly Posted November 8, 2025 Posted November 8, 2025 Everything seems to work fine except one place and that's the temp control. After I set the temp the furnace keeps running and doesn't turn off when it reaches the temp I set. Never had this issue before. My guess is the temp sensor has gone bad but, I can't seem to find where it's located. I can turn the furnace off manually. Does anyone have any suggestions on where to look and how to check to see if it works correctly? Hiroshi 2023 Oliver Elite #1299 2024 Lexus GX550 Overtrail
jd1923 Posted November 8, 2025 Posted November 8, 2025 (edited) Hull #? Signature? Please update asap... Edited November 8, 2025 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators topgun2 Posted November 8, 2025 Moderators Posted November 8, 2025 10 hours ago, Buddhabelly said: Does anyone have any suggestions on where to look and how to check to see if it works correctly? Sorry but I don't have one of those "fancy" things. But, I assume that you've submitted a Service ticket? Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Rivernerd Posted November 8, 2025 Posted November 8, 2025 13 hours ago, Buddhabelly said: After I set the temp the furnace keeps running and doesn't turn off when it reaches the temp I set. Never had this issue before. My guess is the temp sensor has gone bad but, I can't seem to find where it's located. I can turn the furnace off manually. Does anyone have any suggestions on where to look and how to check to see if it works correctly? Do you have the CP Plus wall control unit for your Truma furnace? Could you attach a photo of the display on the unit when the furnace is still running but the set temperature has been reached? And, an update to your footer showing hull number, model year and installed options would be very useful to those of us trying to help. Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Buddhabelly Posted November 8, 2025 Author Posted November 8, 2025 (edited) Yes, mine is a Truma CP plus. I've tried different temps and it doesn't matter. It justr keeps running past the set temp. i.e.62 and still heating at 72 degrees. Need to turn if off manually. I turned in a service ticket and can't get anywhere with them. They just don't seem to understand what I am saying. Finally gave up along with my AC problem. It you guys that saved my hide on the AC. Forgot, it's a 2021 model Elite 1 Edited November 8, 2025 by Buddhabelly Hiroshi 2023 Oliver Elite #1299 2024 Lexus GX550 Overtrail
Rivernerd Posted November 9, 2025 Posted November 9, 2025 The photo of the cat is cute, but a photo of the CP Plus wall unit display when the furnace is still running, when the temp in the cabin is beyond the set temp, would be more useful. It might enable progress toward diagnosis of your issue. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Buddhabelly Posted November 11, 2025 Author Posted November 11, 2025 My error. This is a pic of my Truma and a pic of the temp settng running and a differnt temp gauge so the difference after running for awhile. Was 70 degrees inside and furnace still running. I can turn it off manually but, doesn't turn itself off when it reaches it's temperature. Any suggestions would help... 1 Hiroshi 2023 Oliver Elite #1299 2024 Lexus GX550 Overtrail
Snackchaser Posted November 11, 2025 Posted November 11, 2025 3 hours ago, Buddhabelly said: Any suggestions would help... Reading your post peaked my curiosity about the Truma, particularly from the mention of a Temperature Sensor. . . which is typically part of the thermostat. So I looked-up the Combi and sure enough, there is a Temperature Sensor that is separate from the control panel. Accordingly, there is a temperature off-set adjustment in the control panel to account for temperature variances depending on where the sensor is mounted verses the room temperature. Perhaps that was inadvertently reset, which could account for your temperature miss-match. I’d check that first. Review your manual for instructions on how to change the off-set. I don’t know where the sensor could be mounted, but it shouldn’t be too difficult to find by following the wire from the unit. It’s probably a simple thermistor, basically a resistor that changes resistance with temperature change. These are easy to test with a multimeter in the Ohms setting. If the resistance value changes with a little heat applied from your fingers, then it’s probably okay. Let us know what you find and good luck. Cheers! Geoff 1 2 1
Buddhabelly Posted November 21, 2025 Author Posted November 21, 2025 Thanks for trying to help me out guys, Just can't figure it out so I'm having an electrican come over and see what's going on I'll let you know what he finds. Hope he dosen't make be feel stupid. Hiroshi 2023 Oliver Elite #1299 2024 Lexus GX550 Overtrail
Tom and Doreen Posted November 21, 2025 Posted November 21, 2025 I believe the temperature sensor is mounted just below the controls. 2 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
Buddhabelly Posted Saturday at 12:05 AM Author Posted Saturday at 12:05 AM Forgot, Electrican found the issues with my temp issue. The sensor and Elite 1 is behind the front speaker in the corner. Unpluged the sensor, blew out with canned air and reinstalled it and it works fine. Thinks it might have been a bad connection from the get go. Who know, it works now and that's all that matters. Thanks guys for trying to help. Appreciate it. 4 Hiroshi 2023 Oliver Elite #1299 2024 Lexus GX550 Overtrail
