GeoffChapman Posted November 26, 2025 Posted November 26, 2025 I have an Oliver Elite 1, 2020. I was winterizing it and before I winterized the outside shower station I removed my lithium batteries and remained connected to shore power. When I went to turn on the water pump, it did not come on; the entire 12v system is not working, while the 120v system works fine. I called Oliver, and they thought I probably have to put the batteries back in to make it work. Does anyone know if there is a way to get the 12v system working without any batteries in the Oliver. I have the FreedomX Remote Panel with the Xantrex Freedom XC 2000 Inverter. Thanks for any help! Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
Moderators topgun2 Posted November 26, 2025 Moderators Posted November 26, 2025 Other than adding a device to change 120 volts to 12 volts, as far as I know you will have to put the (or at least one 12 volt battery back into the Ollie in order to get 12 volts to the water pump (or anything else that runs off 12 volts for that matter). As long as it is charged up, basically any old 12 volt battery will work for your purpose. I always have one or two 12 volt AGM batteries laying around in order to use with a small trolling motor I have. This would be more than adequate to power that water pump. Unfortunately, you are in Pittsburgh and I'm in the mountains of western North Carolina. Good luck! Bill 5 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
GeoffChapman Posted November 26, 2025 Author Posted November 26, 2025 Thanks Bill. I wonder - what if I were to use 12v leads off my Jackery battery and connect them directly to the leads of the pump? All I want to do is run it for 5 minutes… Thoughts? Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
Geronimo John Posted November 26, 2025 Posted November 26, 2025 Just be mindful of the polarity. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
GeoffChapman Posted November 27, 2025 Author Posted November 27, 2025 Was wondering about that. I haven’t looked carefully at the pump motor, and there will be no 12v power to run a test. Any wisdom on which lead is + or -? 1 Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
Snackchaser Posted November 27, 2025 Posted November 27, 2025 With all other loads turned off (as to not overload the Jackery) just hook your Jackery neg to the ground buss with all the yellow wires, and the Jackery positive to the big red wire input of your 12 volt fuse panel . Your pump will then operate as normal. Otherwise you will have to cut the wire splice at the pump to feed it. 3
GeoffChapman Posted November 27, 2025 Author Posted November 27, 2025 Right! Thank you. Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
GeoffChapman Posted November 27, 2025 Author Posted November 27, 2025 Need some more guidance, please. I'm not very experienced at electricity, but I am game if it is safe. Forget the Jackery. Can I use one of my 12v lithiums instead? "With all other loads turned off (as to not overload the Jackery) just hook your Jackery neg to the ground buss with all the yellow wires, and the Jackery positive to the big red wire input of your 12 volt fuse panel . Your pump will then operate as normal. " Looking carefully - here's my shot at a safe 12v power disconnect the 120v land line take one of my lithium batteries, turned off and use a jumper cable, connecting the: negative to the 'ground buss with all the yellow wires' and positive to the naked bus on the far side of the 12 volt fuse panel? (left side of photo) turn lithium battery on turn off all 12v lights, etc turn on water pump and finish the winterizing Is this good? Corrections? Happy Thanksgiving!!! Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
Moderator+ ScubaRx Posted November 27, 2025 Moderator+ Posted November 27, 2025 17 hours ago, GeoffChapman said: Thanks Bill. I wonder - what if I were to use 12v leads off my Jackery battery and connect them directly to the leads of the pump? All I want to do is run it for 5 minutes… Thoughts? Would work perfectly. Less trouble, winner winner. 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
GeoffChapman Posted November 30, 2025 Author Posted November 30, 2025 Need more help, please. I have put the lithium batteries back in, unplugged the shore power and the FreedomX Remote Panel with the Xantrex Freedom XC 2000 Inverter both are running and supplying power to the 120v system. The 12v system does not come on. Is there a fuse I've thrown - or a switch on the inverter that needs to be pushed to make the 12v system come on? Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
dewdev Posted November 30, 2025 Posted November 30, 2025 Did you turn on the power switch on the Xantrex? This power switch does not need to be turned on if you have the Xantrex remote panel, you can turn on the unit from that push button switch. 2018 Oliver Elite II, Twin Bed, Hull #354, new 3- 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
GeoffChapman Posted November 30, 2025 Author Posted November 30, 2025 I have pushed the power switch on the Xantrex and on the Remote. The remote lights up, as does the Xantrex. Are these button switches 'on' when depressed (in) and 'off' when out? Should the Xantrex be "out" and the Remote be 'in'? Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
GeoffChapman Posted November 30, 2025 Author Posted November 30, 2025 (edited) What is this switch? Might it cut off the 12v system? Edited November 30, 2025 by GeoffChapman Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
Moderators topgun2 Posted November 30, 2025 Moderators Posted November 30, 2025 52 minutes ago, GeoffChapman said: Is there a fuse I've thrown - or a switch on the inverter that needs to be pushed to make the 12v system come on? Yes, It is likely that you have "tripped" one (or both of the "breakers" that look exactly like the one in the picture you post right above this post. If either of the two of those are tripped then you should see a little yellow "flag" that will stick out the side of that black plastic. In order to reset it all you have to do is push the little yellow flag back in. Bill 1 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
GeoffChapman Posted November 30, 2025 Author Posted November 30, 2025 (edited) Bill, thank you!! The fuse on the side of the battery compartment (not the one in the photo) had been tripped. Reset it and Success!! Pump and the rest of the 12v system came on. Winterization is now complete. Thank you all!!! Edited November 30, 2025 by GeoffChapman 1 2 Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
Ronbrink Posted December 1, 2025 Posted December 1, 2025 15 hours ago, GeoffChapman said: Bill, thank you!! The fuse on the side of the battery compartment (not the one in the photo) had been tripped. Reset it and Success!! Pump and the rest of the 12v system came on. Winterization is now complete. Thank you all!!! If that 12v circuit breaker with manual reset trips again, plan on replacing it! I replaced the cheap, low quality stock breaker in my OLEll with a high quality Blue Sea Systems breaker. Problem solved! 4 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted December 2, 2025 Posted December 2, 2025 On 11/26/2025 at 4:29 PM, Snackchaser said: With all other loads turned off (as to not overload the Jackery) just hook your Jackery neg to the ground buss with all the yellow wires, and the Jackery positive to the big red wire input of your 12 volt fuse panel . Your pump will then operate as normal. Otherwise you will have to cut the wire splice at the pump to feed it. I personally would hook a jackery to the battery cables in the battery box for maintenance purposes when winterizing with the house batteries removed. GJ 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
