Tideline77 Posted 20 hours ago Posted 20 hours ago On 1/14/2026 at 12:58 AM, jd1923 said: On 1/13/2026 at 5:29 PM, Geronimo John said: Some owners have height restrictions. This unit "stands tall" at about 14", a good 5" taller than our OEM Dometic. A hard deal killer for besome owners for sure. Agreed, but... Looking at the specs I see a 3.25" difference (14.5" - 11.25"). It would be 5" to your low-profile Houghton. I promised @Tideline77 measurements which I took yesterday. My son Adam climbed up the scaffolding and place an 8' 1x3" on top of the A/C unit hanging off to the curbside. I measured the height and did not believe the number, so I measured it in the same way off the streetside, same number! I measured exactly 9' 8.5" on BOTH sides! This is great news and thank you for measuring ! 👍🏻👍🏻👍🏻 Robert E 2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
Geronimo John Posted 17 hours ago Posted 17 hours ago 3 hours ago, Tideline77 said: This is great news and thank you for measuring ! I have since updated the post. The 5" increase is from my Houghton A/C height. JD's remeasured and it is 3.25" higher than the Dometic Penguin II. In our case, there is no way I could back it into our storage area. Especially since there is a ramp at the entrance and that kicks the area behind Ollie's axles up even further. So if height of your storage areas is close, it would be wise to double check. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators mossemi Posted 7 hours ago Moderators Posted 7 hours ago I saw the Furrion Chill Cube today at the RV Super Show in Tampa and it is indeed very impressive. And now the really good news, Furrion will introduce a low profile model in April according to the gentleman that gave me the demo. It is advertised as 15,000 BTU's and also has a heat pump. Mossey 1 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
CRM Posted 6 hours ago Posted 6 hours ago 8 minutes ago, mossemi said: I saw the Furrion Chill Cube today at the RV Super Show in Tampa and it is indeed very impressive. And now the really good news, Furrion will introduce a low profile model in April according to the gentleman that gave me the demo. It is advertised as 15,000 BTU's and also has a heat pump. Mossey Looks like it's just a rebadged Turbro / Pioneer. 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
jd1923 Posted 6 hours ago Author Posted 6 hours ago 37 minutes ago, mossemi said: I saw the Furrion Chill Cube today at the RV Super Show in Tampa and it is indeed very impressive. Thank you Mossey, for this information! I don’t follow tech news much, just research what I need when I’m working on something. I’d hate to be contrary, but I believe this product hit the market last year! It has other brand names like Turbro and Pioneer! It sure looks like these models (in shape and position of condenser fan). This is likely another clone. Too bad, but TBD! 😎 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
