Moderators Wayfinder Posted January 9 Author Moderators Posted January 9 @Tideline77 I forgot. I ordered them from 4 STATE TRUCKS. https://www.4statetrucks.com/ 1 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Moderators Wayfinder Posted January 14 Author Moderators Posted January 14 (edited) I only have 1 day before I depart for the Eggs & S'Mores rally in FL. No time to install springs with the need to work today. oh well. The UPS guy, who was quite large, carried both 50 lb boxes of Alcan springs in a bear-hug style. I was impressed. I'm ready with some awesome new tools. Edited March 14 by Wayfinder Removed grease gun pic 6 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Geronimo John Posted January 15 Posted January 15 (edited) Chris: Some thoughts about the standard wet bolts vs step bolts for trailer springs: Standard bolts generally used for light duty trailer shackles using a 9/16" diameter shackle bolts without a zirk fitting. Step Wet Bolts Bolts are used for heavy duty axles where the step is necessary for proper function with bronze bushings. I believe that all of the OTT trailers, and the most other heavy duty trailer spring shackle bolts are step bolts. Yet Alcon is using a standard bolts. This got me wondering about the topic. Wet bolts sandwich the springs between the subframe mounting "tabs". With the step, the step bolts mechanically limit the clamping of the springs. The result is that the bolt head is prevented from turning in the mounting tabs by two means. First, the splines. Secondly the friction on the tabs by the step and the nut itseld. As a result of the design, the spring always has some clearance allowing it to more freely rotate relative to the bolt center line. My concerns are: The Alcans could easily be over tightened thereby forcing the mounting tangs against the springs. This process would result in the spring binding in the tabs and facilitate the stripping of the bolt splines thus creating a "spun bolt". A spun bolt will act as a crude bearing causing the mounting tab holes to quickly wear. And the repair is rather difficult. Been there myself. Use of Nylock's in high torque situtations often results in the Nylock becoming impossible to remove with hand tools. To do so, one will likely want access to air tools or electric grinders to literally cut the nut off. Trying to do so with a hack saw and punch will be tedious, especially it appears that their bolts are very high quality grade 8. As such, failure of a wet bolt will complicate life a lot. The only way I would want standard bolts for a splined application is if the bolt head head was fixed using a Hex Capture Washer. After two years of working with OTT Jason, this approach ended up being the only acceptable long term repair for a spun bolt spline. DIY - Dexter EZ-Flex Center Bolt Spline Repair (20 APR 2024).docx What are your thoughts about Alcon not using step bolts on our springs? Thanks GJ Edited February 17 by Geronimo John typo 5 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
2008RN Posted January 17 Posted January 17 @Geronimo John I have to agree with you. about using the Step wet bolts. When I was installing the Alcan springs in the Oli. I used the wet bolts from Alcan and found when Torqued down to the specs, I could not get grease through the sides on the Bushing. I finally measured the step bolts and the measured the springs and carriers. I found that the should bolt allowed just over .010 slop. This allowed grease to come out of the sides and allowed the shackles and springs to move freely. This allows the EZ-Flex to move freely, and do what it was designed for. All of the stress is on the bolt itself and is not on the threaded shoulder thus allowing a lower torque. 2 1 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
Moderators Wayfinder Posted February 15 Author Moderators Posted February 15 (edited) Well, thanks to my buddy Steve, we had a good time putting on the new springs at a great location. He's paying me back for helping him put his springs on. Based off what Lew at Alcan said, this is around 200 Oliver's receiving the springs. Pretty good. Once the weather clears I'll do the first 50 mile ride, come back, and retorque the U-Bolt nuts again to 90 pounds. Oh, and between two of you (us), do not lose your 7/8 inch deep impact socket, and do not forget to pick one up before starting the job. LOL Or, driving to the store to get one will delay you. LOL Helpful tools and hints: The new Ryobi impact drill, grease gun, and 4x4 hydraulic jack were all amazing - made things easy. Best to also have two small bottle jacks, 2x" & 4x" wood for cribbing. Not to mention PB Blaster, or equivalent, for the old U-bolts nuts, and small wire brush to clean off those old U-bolt threads before attempting to remove the nuts. One nut got bound up and I had to use old muscles and extra leverage to get the nut off. (Fun times). LOL Edited February 15 by Wayfinder Tried to re-upload images, but the forums is making images look bad. Not sure why. 1 5 1 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
jd1923 Posted February 15 Posted February 15 56 minutes ago, Wayfinder said: Well, thanks to my buddy Steve, we had a good time putting on the new springs at a great location. He's paying me back for helping him put his springs on. Good work, Chris. I know you will be happy towing your next time out! 😂 I'm guessing you did this at Steve's since both Olivers are there. GREAT carport with concrete pad, I'm jealous! We have a 3/4 acre parcel, but I can't figure out a spot 25 ft off property lines for the city, that's easy to back into, and is level. I'll have to keep hiding our Oliver behind the Tuff Shed where it partially blocks the southern exposure. Yeah, now 200 Alcan-upgraded Olivers! Welcome to the club! 😎 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Wayfinder Posted February 17 Author Moderators Posted February 17 (edited) I did a final torque of the U-bolts after 200 miles and the nuts only needed 1 to 3 quarter turns. I must say though, like others noted before me, I did have some minor.... "disruptions" (not damage) inside the trailer after that 200 miles - never seen before disruptions. I did have a rear upper cabinet door open for the first time ever, but at the same time, I noticed that the latch was free-floating on the panel and on all three rear panels. They were obviously lose before the trip, so they are snugged up now. Add that to the annual inspection list. Also for the first time ever, I had a bottle of salsa open up inside the fridge. No glass broken. So the bottom of the fridge must have been very bumpy to unscrew a lid. I will inspect plumbing area and electronics soonest. (updated: all good so far) Why do I mention this? Well, I'm thinking, and this is just me, so you do you, but I should have removed that lower/smallest 5th plate. Let's face it, that thicker steel is not going to break easily, especially with the second leaf being so extra long. But, oh well, I have 5-leafs now - all good. I'll just ensure things are buttoned up tighter. I can carry more alcohol and steaks now too. Overall, I did notice a HUGE difference with driving over bridges and not-so-perpendicular railroad tracks. The camper did not rock back and forth nearly as much as with the 3500 pound, ten year old, springs. 4-Leaf: 2250 x 4 = 9,000 lbs (just my recommendation after 200 miles - just things to consider - others here have only used 4-leafs) 5-leaf: 2750 x 4 = 11,000 lbs Edited February 17 by Wayfinder Because I never proof-read 1 1 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
John and Debbie Posted February 17 Posted February 17 1 hour ago, Wayfinder said: I did a final torque of the U-bolts after 200 miles and the nuts only needed 1 to 3 quarter turns. I must say though, like others noted before me, I did have some minor.... "disruptions" (not damage) inside the trailer after that 200 miles - never seen before disruptions. I did have a rear cabinet door open for the first time ever, but at the same time, I noticed that the latch was free-floating on the panel and on all three rear panels. They were obviously lose before the trip, so they are snugged up now. Add that to the annual inspection list. Also for the first time ever, I had a bottle of salsa open up inside the fridge. No glass broken. So the bottom of the fridge must have been very bumpy to unscrew a lid. I will inspected plumbing area and electronics soonest. Why do I mention this? Well, I'm thinking, and this is just me, so you do you, but I should have removed that lower/smallest 5th plate. Let's face it, that thicker steal is not going to break especially with the second leaf being so extra long. But, oh well. Too late now. I'll just ensure things are buttoned up tighter. Overall, I did notice a HUGE difference with driving over bridged and not-so-perpendicular railroad tracks. The camper did not rock back and forth nearly as much as with the 3500 pound, ten year old, springs. 4-Leaf: 2250 x 4 = 9,000 lbs (just my recommendation after 200 miles - just things to consider - others here have only used the 4-leaf) 5-leaf: 2750 x 4 = 11,000 lbs "Overall, I did notice a HUGE difference with driving over bridged and not-so-perpendicular railroad tracks. The camper did not rock back and forth nearly as much as with the 3500 pound, ten year old, springs." We noticed that also and had some movement of items in the trailer in the first few hundred miles. All has settled in now and we like how it rides. John 3 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Moderators Wayfinder Posted February 17 Author Moderators Posted February 17 1 hour ago, John and Debbie said: We noticed that also and had some movement of items in the trailer in the first few hundred miles. All has settled in now and we like how it rides. John Thanks John for the feedback. That's what I was hoping would happen. It was sort of cool to see the black sealant squeezing out between the leafs when I did the final snug-up of U-Bolts. Just interesting. 1 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
jd1923 Posted February 18 Posted February 18 (edited) 21 hours ago, John and Debbie said: We noticed that also and had some movement of items in the trailer in the first few hundred miles. All has settled in now and we like how it rides. John stated this nicely. Our first time out, everything in the Attic was upside down! We had the hangers in the closet bounce off, clothes on the floor! A new suspension needs to seat and settle, period. Since our first outing, never another issue. But perhaps Chris, you left the lid on the salsa jar a bit loose last time... 🤣 Removing the 5th leaf... IMHO, good thing you left things as Alcan engineering had designed. They do not suggest the 4-leaf configuration and they know more than we do. I will say however, as an experienced auto mechanic and engineer, I have not followed all of their torque specs. Yes, you certainly need 90 ft-lbs for the U-bolts but I personally believe their specs on the wet bolts are too tight. They spec 80 on the end bolts and 65 on the centers. I went with 65 and 55 so that the suspension flows better up-n-down. The nuts are NyLok, so they're not coming off. Just my take and this does help. 😎 Cabinets opening? They are loose to begin with! OMG, such blasphemy? Did I again criticize OTT? Shame on me! Please forgive me for suggesting DIY improvements! 🤣 I rode inside our trailer once, Chris towing gently down a local paved road, before our Alcan upgrade, and EVERY overhead cabinet was rattling, even banging loudly. I added a 2" strip of foam tape on both resting pads of every cabinet and they snug nicely now and do not rattle anymore. Something like this works great and I promise you will NEVER have an upper cabinet open again! Welcome to the 200+ Alcan Oliver club and I commend you in doing this install yourself as only a very few of have done so! 😎 https://a.co/d/0b1cbrph Edited February 18 by jd1923 Made Amazon link for 1/8” tape. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
thompsonkd Posted February 24 Posted February 24 We are planning on having Alcan replace our axles and springs this summer. Several people have mentioned having Alcan position the zerks so as to make greasing easier. Can someone who has done this please post a picture of their zerks? This chore has always been difficult, and making it easier sounds appealing. Thanks. David Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L
jd1923 Posted February 24 Posted February 24 (edited) 2 hours ago, thompsonkd said: We are planning on having Alcan replace our axles and springs this summer. Several people have mentioned having Alcan position the zerks so as to make greasing easier. Can someone who has done this please post a picture of their zerks? This chore has always been difficult, and making it easier sounds appealing. Thanks. David David, @Patriot should chime in. He prefers mounting the wet bolts, Zerk fittings to the inside. You get full clearance but the down side is you have to crawl under the trailer to lube the suspension. I prefer mounting the wet bolts in the standard direction, facing out, but then I replace the straight fitting with a 45-degree Zerk fitting to get the required clearance. I usually have some reason to remove the wheels every year or two and always lube the suspension at that time anyway. Your old suspension likely has 6mm x 1 threads on the Zerks. I'm pretty sure the Alcan wet bolts use 1/4" x 28 fittings. You can verify this with Alcan. https://www.amazon.com/dp/B0DQBPTK3Y/?th=1 Get one of these too, and many of us use a battery-powered grease gun. I have the Dewalt model with the LockNLube coupler attached and just the other day, I was able to lube the suspension on my truck in minutes! https://www.amazon.com/dp/B00H7LPKKU/?th=1 Edited February 24 by jd1923 Added picture 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
thompsonkd Posted February 25 Posted February 25 Thank you JD. I am hoping that @Patriotwill weigh in with a photo. However, it might indeed be easier to lube the zerks with the 45 degree bend. So with the angled zerks, you wouldn’t have to remove the tire unless you wanted to? I am sure Alcan would put the angled zerks on if I went that route. David Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L
jd1923 Posted February 25 Posted February 25 (edited) 4 hours ago, thompsonkd said: Thank you JD. I am hoping that @Patriotwill weigh in with a photo. However, it might indeed be easier to lube the zerks with the 45 degree bend. So with the angled zerks, you wouldn’t have to remove the tire unless you wanted to? I am sure Alcan would put the angled zerks on if I went that route. David When I added the 45-degree Zerks, I tightened them down one-finger tight. Several of them at their set point were not at the optimal direction to clear the tires. When I lube, I loosen those Zerks a half turn to get a better angle, pump the grease to fill, then lightly tighten them back into place. Also, regardless of whether your Zerks are mounted inside or out, some may not want to take grease. Using the stabilizer jacks to lift the tire, take weight off, may help. If not, you may have to loosen the wet bolt, apply grease, then retorque the wet bolts when finished. Time to retorque all suspension bolts anyway. In my experience, this happens to 1-2 bolts each time. Check with Alcan ahead of time. They may not stock these parts, and you can always bring parts with you. BTW, given the age of your hull, if you’re replacing axles and springs, you’ll want to replace the EZ Flex center links too. Many have brought these parts with them too. Alcan will be happy to install them. Since you’re replacing the main components, replacing ALL parts at the same time makes best sense (see pic, I purchased 2 of these from eTrailer. The following thread is where I documented my DIY axle/spring installation: Edited February 25 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted February 25 Posted February 25 55 minutes ago, jd1923 said: Time to retorque all suspension bolts anyway. While editing my above post, I thought again about this statement that I just wrote. Until I was educated by Alcan staff, I didn’t realize wet bolts should be torqued when doing maintenance. I’ve not noticed this in a service manual. I always thought a wet-bolt with a Nylok nut only had to be there, not overly tight nor loose. I remember having a suspension lock up in a flat bed car hauler. The mechanic at a trailer shop, merely loosened the bolts on the center link and the suspension dropped into place! I never torqued the wet bolts on the original suspension, though it was REALLY loose when I removed it. Thinking now that @Patriot has the right idea on this one. Crawl under your trailer once a year, lube the Zerks and check the torque on the wet-bolts and U-bolts. I also like removing the tires every so often, removing all gravel while inspecting, looking for punctures, clean the inner rubber. With the old-style bearings, pack them. Spin the drums and set the self-adjusters that do not always adjust adequately so the shoes are just rubbing. Im taking the wheels off anyway! 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Hokieman Posted March 14 Posted March 14 (edited) On 1/6/2026 at 2:15 PM, Wayfinder said: And when someone asks, Lew did say they recommend always leaving 20% of max spring capacity for "wiggle room". So: 4-leaf springs x 4 = 9,000 lbs - 20% (1800 lbs) = 7,200 lbs 5-leaf springs x 4 = 11,000 lbs - 20% (2200 lbs) = 8,800 lbs I’m considering replacing my suspension, still have some teardown and inspection of brakes and drums to do first. I don’t have any problems, my trailer tows great with my F250, no WDH, doesn’t porpoise or wallow, not top heavy. I plan to travel to Colorado in June to camp for a month, so I called Alcan and discussed a quote with Tim. I advised him I was interested in the 4 leaf springs rated at 2250 lbs, D52 axles. I recently weighed my trailer at a Cat scale, it was 5940 lbs fully loaded, water tank full, gray tank empty. I can appreciate why many feel best with 5 leaf springs, but 9k spring capacity with a 6k trailer allows for significant overcapacity, which I feel safe with. Alcan 4 leaf spring leafs also extend well past the weak point on the Dexter OEM springs. Attached is the quote if interested. I had a few technical questions for Tim based on legitimate concerns raised by Geronimo John earlier in this thread. 1) Why does Alcan supply splined wet bolts, but the shackles are smooth bore? It seems this would allow the grease ports to rotate out of the optimal position. Tim explained the bolts are an interference fit, so once tightened up, they shouldn’t rotate. 2) Why does Alcan use 9/16” straight shank wet bolts, as compared to Dexter 9/16” shank stepped down to 1/2” threads? Tim explained they have seen many Dexter bolts sheared off at the shoulder (likely due to over-torquing). Dexter wet bolts should be torqued to 30 ft-lbs min, 50 ft-lbs max (see Dexter instructions attached). As Geronimo John explained, the Dexter wet bolt shoulder is designed to allow the proper clearance between the hanger tabs and the spring bushing. If Alcan straight shank wet bolts are over-tightened, there may not be adequate clearance between the hanger tabs, resulting in abnormal wear and possible difficulty getting grease to purge. Alcan provides a torque spec of 65 ft-lbs, but regardless, clearance should be checked, and torque modified as needed. Hence the reason Alcan use Nylock nuts. So, Alcan takes a different approach to this application than Dexter. Lessons we’ve learned from each other are to use caution torquing your wet bolts (either Dexter or Alcan), and be mindful not to strip the splines. I recommend strongly securing the bolt head while torquing the nut. Sent from my iPad 059-867-00_ez_flex_complete.pdf Edited March 14 by Hokieman Dexter instructions added 5 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431. Blairsville, GA
jd1923 Posted Monday at 04:41 PM Posted Monday at 04:41 PM (edited) On 1/6/2026 at 12:15 PM, Wayfinder said: I think Lew convinced me to just stay with the 5-leaf set, but also said I can simply remove the bottom leaf if I wish, no big deal. And when someone asks, Lew did say they recommend always leaving 20% of max spring capacity for "wiggle room". So: 4-leaf springs x 4 = 9,000 lbs - 20% (1800 lbs) = 7,200 lbs 5-leaf springs x 4 = 11,000 lbs - 20% (2200 lbs) = 8,800 lbs Carrying this thought out in comparison, Alcan to Dexter Leaf Spring packs: Dexter 4 leaf-OEM1750 LBS x 4 = 7,000 lbs (-20% = 5,600 LBS) Alcan 4 leaf-pack 2250 LBS x 4 = 9,000 lbs (-20% = 7,200 LBS) Dexter 4 leaf-SW4 2400 LBS x 4 = 9,600 lbs (-20% = 7,680 LBS) per @Geronimo John Alcan 5 leaf pack 2750 LBS x 4 =11,000 lbs (-20% = 8,800 LBS) Keep in mind besides this 20% “wiggle room” there should already be safety margin in the manufacturer’s spec capacities. But I like the additional 20% per Alcan! 😎 Edited Monday at 05:45 PM by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ronbrink Posted 20 hours ago Posted 20 hours ago On 1/5/2026 at 8:29 PM, Geronimo John said: Duhh..... They were undersprung for a 6,000 pound OE2. At 7,000 pound for sure the running gear would be stresed to the max and over the limit with about any G-forces from the road surfaces. So I guess I need to include in the 10%er's anyone near 7,000 pounds should also consider going with the super springs. As in YESTERDAY. But at 6,000 pounds and 560# tongue weight, the Dexter PB4's (2400 pound rated) seem to be a good choice. Especially at $60 a leaf vs $149 each as listed above. GJ Do you know if he Dexter PB4’s raised the height of the trailer? Is yes, by how much? Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted 14 hours ago Posted 14 hours ago 23 hours ago, jd1923 said: Alcan 5 leaf pack 2750 LBS x 4 =11,000 lbs (-20% = 8,800 LBS) We left for a trip yesterday. No Cat Scales where we live, but our city dump has scales. I go there often to recycle engine oil. With both Oliver axles on their scale, it came to only 5700 LBS. I’ve measured hitch weight separately at 580 LBS. We are packed light for a 3-day trip, so I estimate we’d pack another 220 LBS in food and clothing for a long trip adding to 6,500 LBS Max. So she’s sitting at only 5700 LBS on two axles! Shouldn’t 7,000 springs be enough? The Oliver is more top-heavy than most trailers, with its upper double hull, tall body, multiple cabinet storage at head height, rooftop A/C, solar panels and other rooftop accessories. We dropped 4000 FT in elevation yesterday! Coming down steep, hard turns, exhaust brake on, descending smoothly! The top of the Oliver stayed put, maybe leaning left or right 2” going into a hard turn. Look out your mirrors when towing to observe this. Our hull used to lean over a foot vs. just inches! Original springs, the Andersen WDH was a must! Not anymore, since the Alcan springs keeps the Oliver weight centered over its axles. This is why the OEM suspension is undersprung. It’s not only the weight it carries, it’s the total body weight it must control while towing in various conditions! 😎 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
theOrca Posted 1 hour ago Posted 1 hour ago I noticed that the splines on the Alcan bolts do NOT engage the holes of the slightly longer shackles they provide. I asked Alcan about it and they do NOT want the shackles locked to one end of the bolts. The way they accomplish this is to drill the holes in their shackles slightly larger than the holes in the Dexter Shackles. I am still not sure I want to use the Alcan shackles and bolts. In any case do not mix and match Alcan and Dexter shackles and bolts.They are engineered differently and not designed to mix. theOrca, 2020 Legacy Elite II, Twin, Hull 615 Tow Vehicle - 2016 Ram 1500, Hemi, 8 Speed with 1500# rear springs and Goodyear bags.
theOrca Posted 43 minutes ago Posted 43 minutes ago After I posted the above i went out and dug our the Dexter parts and the Alcan parts. (My axles are not in yet, so I have all parts waiting on Dexter.) I continue to be a believer in the Alcan springs, but now have my doubts about their shackles and shackle bolts. The Dexter bolts are designed to be torqued to their shoulder. That will allow full rotation and flex of the EZ Flex and Spring ends which go to the Shackle. The Alcan bolts put full clamping force on the EZ Flex and the spring end of the shackles. I cannot see how that is a good idea. It resists rotation and flex... Comments please... theOrca, 2020 Legacy Elite II, Twin, Hull 615 Tow Vehicle - 2016 Ram 1500, Hemi, 8 Speed with 1500# rear springs and Goodyear bags.
