DaveAndBecky_NorthernMI Posted yesterday at 03:23 AM Posted yesterday at 03:23 AM (edited) We have Elite II Pro package with 3 Lithionics batteries. Currently boondocking near Capital Reef Utah. I checked batteries mid-morning with good sun and saw 2-3 amp draw on each battery. I came back after a good day of sun to same draw and batteries down 15% in a day with no usage. Inverter off. Norcold refrigerator on propane. Here’s what I’ve done Restarted inverter Reset inverter breaker (red switch streetside bed) Power cycled batteries Reset all AC breakers while watching amp load - nothing changed pulled each DC fuse one at a time - no change checked all wire connections in dinette by pantry. No loose wires Batteries are taking charge from generator but show same loss as soon as generator turned off. Any ideas where to check next? Thanks in advance Oliver crew! Edited yesterday at 03:24 AM by DaveAndBecky_NorthernMI 2022 Oliver Elite II Hull#1047 "Saunter" Solar Pro 390 aH Lithionics 2022 Ram 1500 5.7L Hemi
jd1923 Posted 23 hours ago Posted 23 hours ago 55 minutes ago, DaveAndBecky_NorthernMI said: I came back after a good day of sun to same draw and batteries down 15% in a day with no usage. You should be getting +A from your solar. So 2-3 amps/battery, is say -8A total with everything off? You should be getting approx. +12A from your solar, given the fridge on LP. That means during the day your about net -20A. That's a large draw! The one time this happened to us, I had the hot water heater on AC (electric). Are you certain no change with all the breakers OFF? You wrote you restarted the inverter. Did you leave the inverter OFF for a period of time to measure draw with it off? Do that to be sure it is not anything 120VAC provided by the inverter. Hard to imagine anything DC taking that much power. Do you have any special DC accessories? Also, pull your 30A jack fuses, one at a time. A jack could perhaps be shorted in a way where it's drawing power to ground through the motor. Do you have a fridge cooling fan or other fans? Battery heaters ON? I cannot think of anything else DC that could draw so much amperage. Hope the best for you two! Bummer to have this worry when you're in such a beautiful place. 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DaveAndBecky_NorthernMI Posted 22 hours ago Author Posted 22 hours ago (edited) 20 minutes ago, jd1923 said: You should be getting +A from your solar. So 2-3 amps/battery, is say -8A total with everything off? You should be getting approx. +12A from your solar, given the fridge on LP. That means during the day your about net -20A. That's a large draw! The one time this happened to us, I had the hot water heater on AC (electric). Are you certain no change with all the breakers OFF? You wrote you restarted the inverter. Did you leave the inverter OFF for a period of time to measure draw with it off? Do that to be sure it is not anything 120VAC provided by the inverter. Hard to imagine anything DC taking that much power. Do you have any special DC accessories? Also, pull your 30A jack fuses, one at a time. A jack could perhaps be shorted in a way where it's drawing power to ground through the motor. Do you have a fridge cooling fan or other fans? Battery heaters ON? I cannot think of anything else DC that could draw so much amperage. Hope the best for you two! Bummer to have this worry when you're in such a beautiful place. JD we have Truma on demand hot water. Turned off. No change. Inverter I only turned off for a short time. Can try shutting off for longer period tomorrow. No custom fridge cooling fans. I do think Norcold fan has gotten louder. I turned off fridge and still see draw. No special DC accessories. i will try jack fuses in AM. Edited 22 hours ago by DaveAndBecky_NorthernMI 2022 Oliver Elite II Hull#1047 "Saunter" Solar Pro 390 aH Lithionics 2022 Ram 1500 5.7L Hemi
Snackchaser Posted 22 hours ago Posted 22 hours ago (edited) Check to make sure that your brake "breakaway switch" wasn't accidentally pulled out. If so, the electric brakes have been on the whole time. Four brakes would draw 3-4 amps each. If you were reading 2-3 amps draw on your Lithionics battery App, then that's only one of the 3 batteries. So it's actually 9-12 amps. Add in the solar input and it's about right for what the brakes would draw. Good luck, Geoff Edited 22 hours ago by Snackchaser 1 3 1
John Dorrer Posted 15 hours ago Posted 15 hours ago (edited) 8 hours ago, DaveAndBecky_NorthernMI said: We have Elite II Pro package with 3 Lithionics batteries. Currently boondocking near Capital Reef Utah. I checked batteries mid-morning with good sun and saw 2-3 amp draw on each battery. I came back after a good day of sun to same draw and batteries down 15% in a day with no usage. Inverter off. Norcold refrigerator on propane. Here’s what I’ve done Restarted inverter Reset inverter breaker (red switch streetside bed) Power cycled batteries Reset all AC breakers while watching amp load - nothing changed pulled each DC fuse one at a time - no change checked all wire connections in dinette by pantry. No loose wires Batteries are taking charge from generator but show same loss as soon as generator turned off. Any ideas where to check next? Thanks in advance Oliver crew! We have a 2022 and when I see something like your situation, my brain goes to "Inverter Breaker". We have the 3 Lithonics batteries and 3000 Xantrex Inverter. We spent the night at Oliver after pick-up and plugged in. The next afternoon we packed up and moved to David Crockett State Park and plugged in. That evening I opened the Lithonics app only to find my batteries down to 73%. Shore power wasn't charging the batteries. I reached out to Oliver and Mike sent me a picture of the breaker. He stayed on the phone and walked me through checking the breaker, which was tripped and resetting the breaker. All was good for 2 months and it happened twice more. Oliver sent me a new breaker. In October 2024 we were boondocking, turned on the inverter to cook oatmeal, and 30 seconds in the microwave shut off. Jason was at the Texas Rally and ran tests. In February 2025, during service, it was determined that the issue was the breaker. Since they were no longer using the breaker and didn't have any, we lived with things until we got home. We were plugged in for the trip, so really was not inconvenienced. I order two new ones. I followed the shut down procedures, solar off, inverter breaker off, then each battery. Start up is reversed. I discovered to my horror that problem was very loose connects, resulting in pitting of the cable ends. Arching was obviously occuring. I replaced the breaker and now will check the connections each fall after our last trip. While your breaker might not be the issue, I would really check it over. Just make sure you completely power down per the sequence mentioned in this post. Good Luck. Please provide an update. During this period we experience a few weird things, which we attributed to the loose connectors. I suggest you send a service ticket request to Oliver so they can provide input. support@olivertraveltrailers.com Edited 15 hours ago by John Dorrer Typo 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
DaveAndBecky_NorthernMI Posted 13 hours ago Author Posted 13 hours ago 9 hours ago, Snackchaser said: Check to make sure that your brake "breakaway switch" wasn't accidentally pulled out. If so, the electric brakes have been on the whole time. Four brakes would draw 3-4 amps each. If you were reading 2-3 amps draw on your Lithionics battery App, then that's only one of the 3 batteries. So it's actually 9-12 amps. Add in the solar input and it's about right for what the brakes would draw. Good luck, Geoff Snackchaser was spot on. I got up this morning and found the emergency breakaway switch had gotten pulled out during setup. I put it back in and voila, back to 0 draw. Thanks you all so much for the responses. I was really stressing out about this issue. 1 3 1 2022 Oliver Elite II Hull#1047 "Saunter" Solar Pro 390 aH Lithionics 2022 Ram 1500 5.7L Hemi
HDRider Posted 13 hours ago Posted 13 hours ago Wow. This forum is worth its weight in fiberglass. 4 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Steph and Dud B Posted 3 hours ago Posted 3 hours ago Check your brakes. Extended run time like that can cause damage to the magnets or wiring. Not always, but sometimes. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
