Sandman Posted 16 hours ago Posted 16 hours ago Hello friends, I sanitized our Oliver Legacy 1 as directed and after returning the plumbing to "normal" configuration, have the water pump running continuously when turned on. I have good pressure at all fawcets. Is there air in the pump from a foamy bleach mixture that has to be purged somehow. Thanks in advance! Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Moderators topgun2 Posted 16 hours ago Moderators Posted 16 hours ago I assume that the water pump was functioning normally before you started the sanitization procedure. I'd guess that you have a loose fitting - the first place I'd check is the fittings around the water pump itself. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Sandman Posted 16 hours ago Author Posted 16 hours ago Yes it was. Thanks I'll check those next. Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Snackchaser Posted 16 hours ago Posted 16 hours ago The pump stops running when the pressure set-point is reached. So it’s pumping, but not reaching full pressure. This happens when there is a leak on either the suction or output side of the pump. If the leak is on the output side, it’s easy to find because it will be leaking water. However, if it’s on the suction side, it will suck air but it will not be leaking water. The most common cause is the suction side filter right next to the pump. You won’t see any signs of leakage, but make sure the cap is on straight and tight with o-ring. I assume you have re-checked proper valve line-up and full closure, and any open faucets. Other than that, it’s unlikely a leak developed by just sanitizing. Good luck, Geoff 3
Sandman Posted 16 hours ago Author Posted 16 hours ago Thanks! Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
jd1923 Posted 14 hours ago Posted 14 hours ago @Sandman did you bleed the air out of the system? Toilet, both sinks and outdoor shower, hot and cold sides? Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Sandman Posted 1 hour ago Author Posted 1 hour ago Thank you all for the suggestions. I checked all the valves for correct positioning and confirmed that all connections were tight. I checked the seating and O-ring on the suction-side filter as well and it seems tight. I purged all the lines and primed the pump again in boon dock configuration. I still have some air leak but thankfully no water leak> In retrospect, we always have turned off the pump immediately after use, so may have had a pre-exisitng air leak that I didn't know about. I will be at the dealer in April and will have it checked there. I appreciate the quick responses. Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Steph and Dud B Posted 33 minutes ago Posted 33 minutes ago (edited) Several people have reported that the o-ring was missing where the pre-pump filter screws onto the suction side of the pump. Ours was, and we had problems with losing prime and air in the lines. To check, disconnect the flex water line, then unscrew the filter assembly from the suction side of the pump. Super easy. The o-ring is size 9/16 x 3/4 x 3/32". Edited 33 minutes ago by Steph and Dud B Typo 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
