DanielBoondock Posted May 10 Posted May 10 Meta thread of small mods and things I got for the trailer and found worked well, for your entertainment and interest … First up, the Kelty Trash Pak garbage bag It’s big and fits perfectly attached to the front Seabiscuit box. Made to attach to a back spare tires or other places, there’s lots of strapping so plenty of options. If animals are around you can hang it or put it in the truck. It’s waterproof, super sturdy and big enough to separate out compose vegetable scraps, recycling and trash. Quick, it’s been discontinued and is on sale for $90, so get it while you can if interested from Kelty, REI or or favorite outlet. Second in that picture is the Icon Trailer lock. If you follow lock picking - like the Lock Picking Lawyer channel where he picks hitch locks in under a minutes, you’ll know that most locks don’t slow anybody down who has a little determination. Brute force they can drill out, either the cylinder or the body. This lock is nearly immune to all that. Case hardened steel with a structure that’s hard to cut. Anti drill spinner on the lock, and a tumbler system that’s very difficult to pick. In addition I have a chain around the wheels that’s similarly hard to remove, I’ll detail that later. Finally in that picture is CG Gear RV mat over by the door. It’s double layer loose woven plastic material that was designed for helicopter temporary pads for the US Air Force. They needed something that could be thrown down in the field apparently which wouldn't hold dirt or sand. Indeed it just drops through and it always stays clean. 2 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
DanielBoondock Posted May 10 Author Posted May 10 Lighting is everything … Oliver does a fantastic job with lighting, there’s a ridiculous amount of it in such a small trailer, but it’s all white. Not restful at night, a reddish light just like a campfire does wonders for slowing you down at the end of the day before going to sleep. And the problem is LED’s are just too actinic, you can’t get a bare LED to soften up, but is there a way? Philips figured it out with the Hue system. I think Hue lights work by having an inner phospher coating. So, use tuned LED’s to excite the phosphor which then gives broadband emission. At any rate its the only LED’s I’ve seen that look good. We’ve got them all over the house and my family is addicted to the soft, warm reddish glow at night. Here’s what I did in the trailer. Now the theory of lighting says three levels ideally. Upper, middle and lower. Oliver follows this, except the upper lights are down spots, ideally you have up spots and the ceiling reflects. Here you can easily get two level lighting with Hue Get a Hue bridge and these lamps. Two desk lamps (for the twin), one for bedside and the other for the dinette. The lampshade looks dark green but that’s reflection, it’s all a soft matching white. Internal battery and you can plug in the charger to the TV plug as shown Two Hue under bed down lights to illuminate the floor. This is surprisingly pleasing and effective, just hide the wires under the carpet and use the plug as shown. Attach with two 3M Commander velcro-velcro non permanent strips and they’ll stay in place for travel. No internal battery, must be powered. And corner of the kitchen. Again battery powered, you can see the charger cable which plugs into the kitchen overhead socket What these do is give soft, out of your eyes ambient light that - while it’s white here during the day - can change color to dark reddish at night. The placement is perfect to cover all the major hidden areas and it creates a triangle of coverage. I can’t tell you how comforting it is to come into a strange place and have your trailer interior lit up with such soft perfect lighting. Then for the outside get the party lights - all controlled by the same Hue bridge (link to the item as I don’t have them set up at the moment. Put them under the awning, suction cups on the side, etc. Plug into the outdoor socket. https://www.amazon.com/Philips-Hue-Festavia-Ambiance-Dimmable/dp/B0FML94K5G These aren’t cheap but you get what you pay for! 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
jd1923 Posted May 10 Posted May 10 1 hour ago, DanielBoondock said: No internal battery, must be powered. Very nice! Is there anything comparable in 12V lighting? Love soft lighting, but the installation could be improved. I imagine this is just your first take. Cut the wire, drill 1/4” or smaller hole behind the light to a power source in the basement. Then no clumsy adapter or wires showing. Our Charley would say, what’s all this new stuff in my spot down here, Dad?! 🤣 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DanielBoondock Posted May 10 Author Posted May 10 (edited) 47 minutes ago, jd1923 said: Very nice! Is there anything comparable in 12V lighting? Love soft lighting, but the installation could be improved. I imagine this is just your first take. Cut the wire, drill 1/4” or smaller hole behind the light to a power source in the basement. Then no clumsy adapter or wires showing. Our Charley would say, what’s all this new stuff in my spot down here, Dad?! 🤣 Thanks jd. Yeah set this up in Hohenwald and haven't touched it since. Before doing anything drastic involving cutting tools I'm going to sit with it a good long while - like the first year, to make sure it's the way I want it, it works long term, etc. And I may not mess with it, this works really well and I'm not noticing the cables as long as they're relatively tidy. On 12V I don't think Hue does a lot of that except possibly the Hue LED strips, but pretty sure those don't give you the phosphor, just a white plastic diffusor. EDIT: Those floor lights are 24 V so you could put two batteries in series, or some combination Edited May 10 by DanielBoondock Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
jd1923 Posted May 11 Posted May 11 (edited) 2 hours ago, DanielBoondock said: Thanks jd. Yeah set this up in Hohenwald and haven't touched it since. Before doing anything drastic involving cutting tools I'm going to sit with it a good long while - like the first year, to make sure it's the way I want it, it works long term, etc. And I may not mess with it, this works really well and I'm not noticing the cables as long as they're relatively tidy. On 12V I don't think Hue does a lot of that except possibly the Hue LED strips, but pretty sure those don't give you the phosphor, just a white plastic diffusor. EDIT: Those floor lights are 24 V so you could put two batteries in series, or some combination Yes, good idea to live with new accessories for a while, proper install when certain. 24V now we're talking! Most AC adapters convert to some lower DC voltage. All you need is a small DC-DC converter which runs off your 12VDC system, so no inverter or shore power needed. https://www.amazon.com/dp/B01D082AX8/?th=1 @Snackchaser introduced us to this device to power a Starlink Mini, without using their adapter, instead running on house batteries. I have one installed in our truck for the Starlink. Adding one under the rear dinette would be simple to power those lights! 😎 Edited May 11 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DanielBoondock Posted May 11 Author Posted May 11 13 hours ago, jd1923 said: 24V now we're talking! Most AC adapters convert to some lower DC voltage. All you need is a small DC-DC converter which runs off your 12VDC system, so no inverter or shore power needed. oh damn there you go again, I don’t need this but Victron integration would be nifty so I want it so now I’ll invent reasons to get it 😅 Been getting by on ATT and a Wi-Fi router so far, the only time I didn’t get good coverage was Lewis Meriweather near Hohenwald. But yeah when I ‘retire’ next year maybe I’ll pick up Starlink as a business expense. Problem is the inverter is always running, I need it to cook, and I’ve got big boy batteries so yeah, for sure I’ll make some excuse lol … 1 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
DanielBoondock Posted May 11 Author Posted May 11 (edited) Blutech water system - this is worth it. I got the boondocking system on Black Friday with the works Flanking the spare is the CHI filter (chlorine - - hydrogen sulfide-iron) and right is a regular resin water softener. In bumper storage is the Offgrid filter, you can see pics of that on their website but it is small and fits perfectly. Basically it’s a three stage sediment and a UV sterilizer Super handy to have the three way outlets, I’ll attach a hose for a quick spray down of the truck or trailer. They have a stainless spray nozzle that is stupidly overbuilt. Quick connects on all the hoses. This is water spout connected normally and you can see the quick connect on the left that makes it really quick and easy Quick connects on the camper So why all this for a small camper? Good tasting and safe water is one thing, but the treasured component is the softener. I’m mooch camping and the water here is ridiculously hard so it’s necessary. But in general you get no water spots, easy clean up, no mineral buildup in the system or pots, and the kitchenware all stays spotlessly clean. Well worth it in time and energy saved day to day. The main filter stores in the back as shown. The cylinders go in the truck, or I’m keeping them in the closet. However they sell a bracket so I’m seriously considering mounting them as you see them now since they fit there so perfectly. I’ll post about progress on that project. Edited May 11 by DanielBoondock Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
jd1923 Posted May 11 Posted May 11 22 minutes ago, DanielBoondock said: Problem is the inverter is always running, I need it to cook, and I’ve got big boy batteries Yeah, we run our inverter 24x7x365 but it is nice when all the lighting is low-amp running on 12VDC. 😎 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DanielBoondock Posted May 18 Author Posted May 18 On 5/11/2026 at 9:15 AM, jd1923 said: Yeah, we run our inverter 24x7x365 but it is nice when all the lighting is low-amp running on 12VDC. 😎 Good point and fortunately it turns out it’s all 12V except the 24V floor lights. I’m with you, additionally my piano is 12V so I’m on a mission to convert everything to simplify the wiring 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
DanielBoondock Posted May 18 Author Posted May 18 Probably the single most useful thing I got, maybe these are already know to the community Antimbee Transparent Heavy Duty Clear Suction Cups https://www.amazon.com/dp/B0B67TRPMX Incredibly handy to be able to slap these on any nearby wall. Most you find are heavy duty but the fit with the decor perfectly For example as a towel dry 2 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
DanielBoondock Posted Saturday at 04:27 PM Author Posted Saturday at 04:27 PM (edited) Spice drawer! Surely somebody figured this out but here's my solution, 3 oz jars. Stainless lids and nice thick glass. Holds 1/2-3/4 of a typical store bought which is plenty. There are the only ones I could find that fit height wise https://www.amazon.com/dp/B07KX8S1Z7 https://www.amazon.com/dp/B0797LHWYK Edited Saturday at 04:28 PM by DanielBoondock 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
Moderators topgun2 Posted Saturday at 05:16 PM Moderators Posted Saturday at 05:16 PM 47 minutes ago, DanielBoondock said: Surely somebody figured this out but here's my solution Yep - James Oliver constructed the spice rack/paper towel holder for the very first Oliver made way back when - see below. 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Boudicca908 Posted Saturday at 10:59 PM Posted Saturday at 10:59 PM (edited) 6 hours ago, DanielBoondock said: Spice drawer! Is that below the sink? I have one of those Sand-Free Mats and it's the bomb! I think someone at the Oliver Rally had one. It's heavy but came with a bag. Edited Saturday at 11:26 PM by Boudicca908 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
DanielBoondock Posted Saturday at 11:54 PM Author Posted Saturday at 11:54 PM 51 minutes ago, Boudicca908 said: Is that below the sink? I have one of those Sand-Free Mats and it's the bomb! I think someone at the Oliver Rally had one. It's heavy but came with a bag. Yeah exactly the tiny drawer in front of the sink. Shorter because the sink takes the depth. I was keeping cleaning supplies there but was kind of wasted as that was just for storing them while traveling. Anyhow I’ve since put the collapsable buckets and cleaning stuff in another drawer leaving this one. Not much else you can do with it but easy and perfect for the spices. I guess you could use it for bigger utensils, but I have the Foy utensils divider which takes everything. Problem is regular spice jars are too tall, I was using the OXO camping spice kit, but then that’s kicking around. So happy to find these slightly undersized ones. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
Boudicca908 Posted Sunday at 04:45 PM Posted Sunday at 04:45 PM 16 hours ago, DanielBoondock said: Not much else you can do with it LOL -- I have all my remote controls in there, where Oliver Delivery team placed them -- but also these things: my fire lighters; a clear plastic travel "soap box" that I use to collect miscellaneous "mystery parts" that I find now and then; I keep 'em just in case; sandwich baggie with bulldog clips, paperclips, rubber bands and twist-ties small flat koozies small pliers and a screwdriver with changeable tips; pens, pencils, sharpie markers; small box of magnets; a pad of sticky notes; my extremely condensed "GO LIST" that is my pre-travel checklist -- it sits on top and I only have to take a peek to be sure I'm ready. But I like your use as spice drawer. My spices wouldn't fit in there, though. Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted Sunday at 05:28 PM Posted Sunday at 05:28 PM (edited) 1 hour ago, Boudicca908 said: LOL -- I have all my remote controls in there, where Oliver Delivery team placed them -- but also these things: my fire lighters; a clear plastic travel "soap box" that I use to collect miscellaneous "mystery parts" that I find now and then; I keep 'em just in case; sandwich baggie with bulldog clips, paperclips, rubber bands and twist-ties small flat koozies small pliers and a screwdriver with changeable tips; pens, pencils, sharpie markers; small box of magnets; a pad of sticky notes; my extremely condensed "GO LIST" that is my pre-travel checklist -- it sits on top and I only have to take a peek to be sure I'm ready. But I like your use as spice drawer. My spices wouldn't fit in there, though. We always called it the "kitchen junk drawer." Had one in every home we've owned, now including the Oliver! No remotes in ours, but most of the other stuff on her list, yes! 🤣 We have a spice rack above the cooktop in the overhead cabinet. Ours too would not fit in the junk drawer. I wanted all the many remotes, nicely held in the nightstand drawer. This picture is old and btw we traded in the Rummikub game for a Carbles board which doesn't fit in the nightstand! With our new A/C installation, I mounted the two most important remotes (fan and A/C) on the wall. We have two (2) TV remotes (since I always misplace one) so that one is always bedside on my custom shelf! I did screw into the interior of the nightstand drawer (should have used tape), but only 3M 4950 VHB tape on the fiberglass. Holds these shelves tight! More ideas Dan! 😎 Edited Sunday at 05:51 PM by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Boudicca908 Posted Sunday at 05:35 PM Posted Sunday at 05:35 PM On 5/10/2026 at 12:45 PM, DanielBoondock said: Meta thread of small mods and things I got So, are you going to the Oliver Rally in October? And are you going to open your Ollie for tours? ;-) 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
DanielBoondock Posted 6 hours ago Author Posted 6 hours ago On 5/24/2026 at 10:35 AM, Boudicca908 said: So, are you going to the Oliver Rally in October? And are you going to open your Ollie for tours? 😉 Hey I just got it and already did a Tennessee trip this year! 😅 Anyhow still working, close to retirement so one big trip is all that can be managed 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
DanielBoondock Posted 5 hours ago Author Posted 5 hours ago For the composters out there … what about that black tank, can we move grey to black? Experiment … Shopping list Flojet Macerator Pump 18555-000A - 12V DC Waste Pump for Camper/RV RESTMO Water Flow Meter with Brass Inlet Twinkle Star Hose Filter Attachment Line Water Hose Filter Water hose quick connects Garden hose Goal: Transfer from grey to black utilizing the black flush out inlet port. I’d rather not make more drastic changes to the trailer so let’s see if this works Attempt #1 The pump comes with a quick switch which is handy, its sitting near the Jackery. I got a 12V cig line and used the included pump battery alligator clips to attach to that. Results: Unsuccessful, the Jackery 12V kept turning off so I kept hitting the 12V switch. The flow meter showed no transfer, but water did flow. The pump was running and the orange hose did fill up with water, but it seemed there was little transfer occurring. First I tested the flow meter to see if it was working on a fresh water outlet, it’s fine so there’s just not much flow happening. OK, so I got a 120VAC-12VDC adapter I had handy and used the 120V on the Jackery (you can see the adapter there) but that was even less successful. Conclusion: Probably not enough power. Now how can I get more power into this pump? I looked at the truck, nah too much trouble and maybe not enough line. Do I have a spare battery around? How much does the 12V outlet on the truck supply? I’ve got 7kW out the back (electric truck), maybe a higher power inverter? Or how much can the Oliver 12V cig sockets output? I looked up musing on this problem, looked at the side of the trailer, and wondered “how many engineers does it take to change a lightbulb?” The answer was right there in front of me, embarrassing, the pump even comes with battery alligators …. 🤯😅 Attempt #2 Success! The flow rate seemed a little low compared to the rated GPM. I took a video and will calculate, maybe the resistance through the cleanout jets reduces it. In theory this will stress the pump, but it’s not something being used all the time and I kept an eye on how warm the pump got. Seemed fine … So I’ll take this as a viable solution. Far less space than hauling along a today. There was no solids being caught by the filter. I try to keep solids out of the grey but anyhow not an issue. Good enough for today, I closed up shop Future direction: the only problem is having a neat solution. The lines are filled with residual water you don’t want around the campsite. A bucket (I have a collapsable with lid that’ll work great), or no leak quick connects (if such a think exists) maybe too. KISS, I think I like the bucket solution better. Overall it’s a small tidy package. The whole thing can be stored in the bumper if you take the pump out of its case. But it’s a really nice case with real latches, so I keep that in the back storage and the rest of it in the bumper. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
Jps190 Posted 4 hours ago Posted 4 hours ago The pump setup seems a little overkill. Why do you need a macerator for pumping grey water? A simple 12 volt water pump can be had for under $50. As far a lighting goes I would look at GOVEE. They have 12 volt solutions and are much less expensive. Don’t get me wrong, I love HUE lights. I have them throughout my home but they aren’t really made for a mobile solution in my opinion. My .02 John 2 John and Kim 2021 GMC Sierra 2500 AT4 6.6L Duramax 11350 GVWR 3048lb Payload 2021 Oliver Elite II. Hull #887. 600 Watt Solar Mod
DanielBoondock Posted 4 hours ago Author Posted 4 hours ago 16 minutes ago, Jps190 said: The pump setup seems a little overkill. Why do you need a macerator for pumping grey water? A simple 12 volt water pump can be had for under $50. The macerator isn’t relevant, I chose this one because it’s made for this purpose and has a sewer line adapter built in. Cost isn’t a consideration for me but obviously you can do it any way you wish Quote As far a lighting goes I would look at GOVEE. They have 12 volt solutions and are much less expensive. Don’t get me wrong, I love HUE lights. I have them throughout my home but they aren’t really made for a mobile solution in my opinion. My .02 These are all 12V except for the floor lights which are 24, they can be converted to 12V easily and I’m considering it. I prefer Hue and IMO they’re entirely suitable for mobile. The lamps are the perfect size on this trailer for example, but again it’s a free country 🙂 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
DanielBoondock Posted 4 hours ago Author Posted 4 hours ago I’m unhappy with the outdoor shower. The knobs are hard to get to, the line is short and the control handle is clumsy with the ‘stay on’ option. I want something that I can attach hoses to wash the bugs off the truck and camper. I’ve looked into something more extensive - there are ones that include quick hose disconnects, but I won’t do anything that drastic this year or maybe never. And anyhow I’m not happy with any of them. OK, can I adapt the existing solution? 304 Stainless steel garden hose Adapter Bathroom shower tube to garden hose adapter, 3/4" GHT male to 1/2" G (1/2"IPS) male, lead-free, shower to garden hose adapter This just test fitting, I recommend using teflon tape. Shown is the adapter and my favorite Blutech quick adapter … so that I can attach a Real Man’s spray head 😅 But what about more length? Now that it’s hooked into my quick adapter system easy peasy Shown with a short hose, I can hook any of my hoses into this. This is a concept test but it works and I love it. To be decided is how to prevent the hose from disappearing in the hole. Most likely I’ll put a proper reverse fitting and quick connect on the existing sprayer so that’s the default setup. But it then can be quickly removed and reconfigured for whatever I’m trying to do. TBD … Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
jd1923 Posted 1 hour ago Posted 1 hour ago 2 hours ago, DanielBoondock said: I’m unhappy with the outdoor shower. It is a little wimpy, but I use the outdoor shower often when boondocking. Chris showers in the wet bath, but when the weather is good enough, I prefer being outside, not getting the bathroom wet and not adding to the gray water! All I needed was a holder. I had the one pictured but now I use a suction cup version on the window. I like the standby function built into the shower head. I dislike the fact that the trunk, the rear basement door, has to be open to extend to hose and operate the faucets! So I lay a wash cloth and bottle of body wash on it. I don't use it for much else except for cleaning shoes on occasion. I have good hose attachments for when we have campsite water. If you get too crazy, your FWT will empty quickly! I'm interested in seeing what you come up with as your work matures! 😎 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steve Morris Posted 1 hour ago Posted 1 hour ago (edited) 4 hours ago, DanielBoondock said: For the composters out there … what about that black tank, can we move grey to black? Hank White has used a portable pump as you’re describing, so it does work. Another option is to plumb your pee bottle to the black tank. Several owners have done this. An additional step would be to swap the bathroom sink drain from the gray tank to the black. Just connect the sink drain to the vent pipe and it will go to the black tank. This gives you 15 gallons of pee and sink water, and the soapy water dilutes the urine and prevents crystallization. I use a macerator pump on the sewer drain at home to pump black and gray water to my septic tank 50 feet from my driveway. Works great! Edited 1 hour ago by Steve Morris 2 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
DanielBoondock Posted 1 hour ago Author Posted 1 hour ago 3 hours ago, Jps190 said: The pump setup seems a little overkill. On further thought, actually no. I doubt any of the pump ideas you mention would work, in my description above I mention that this high powered pump is just doing the job. It’s pumping slower than the spec. I’d only go with this one personally. 21 minutes ago, Steve Morris said: Another option is to plumb your pee bottle to the black tank. Several owners have done this. An additional step would be to swap the bathroom sink drain from the gray tank to the black. Just connect the sink drain to the vent pipe and it will go to the black tank. Yeah I researched these on the forum. The sink option didn’t seem to do a lot for me. The pee bottle diversion would be a big benefit, with three of us (wife and adult son) we need to empty it several times a day. And now Natures Head has this option making it easy https://natureshead.net/multi-directional-urine-diverter-kit/ But that would involve some drilling and a permanent solution, not ready to go there as this trailer isn’t yet three months old. So I just bought a couple extra bottles. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
