Jps190 Posted May 25 Posted May 25 (edited) FIDISP 12 Volt Water Pump, Portable Transfer Pump, 330GPH Larger Flow, 1/10HP Electric Utility Pump with On/Off Switch, 2 * 6’ Water Hose Kit for Garden Pools Aquariums Hot Tub https://a.co/d/0hzZ7HoS Camco Durable Sewer Cap with https://a.co/d/0h5qZBVm Been using this for 4 years. Takes 3 minutes to fill black tank and takes up minimal space. As a bonus it is simple to hook to a hose bib to flush out. John Edited May 25 by Jps190 2 John and Kim 2021 GMC Sierra 2500 AT4 6.6L Duramax 11350 GVWR 3048lb Payload 2021 Oliver Elite II. Hull #887. 600 Watt Solar Mod
DanielBoondock Posted June 2 Author Posted June 2 Proof of concept; onboard (inboard?) water conditioning and filtering. Quote PSA: Some will think this is way overkill for water and that’s perfectly fine, but we’re really into clean water, and it has the added benefit of not leaving water spots or leaving deposits in the system. And for the mooch camping we’re doing at a relatives which has incredibly hard water it’s a lifesaver so there 😉 The problem has been the water softener and iron filter. So far it’s all be a modular system I move around. A pain but flexible. I gave up on putting the tanks onboard as they’re a bit too tall for any of the storage. But poking around I found that the panel under the bedside drawer is just sitting there so … Pros All contained nicely Puts weight in the back near the wheels (I’ve got plenty in front) Always set up so just takes two hookups, one from the faucet and two to the back water input. For waterpoint boondocking (e.g. national parks) I haven’t used it. Too much to futz with pulled off at some waterpoint and usually blocking the road. Since it’s permanent those hoses won’t kink, they’re a pain as they want to kink up if you use them modular Easy to access the valves for backwashing and regenerating by just taking the drawer out which is easy It just works out nicely with the lines having the right amount of coil Cons Not so great for city water. Unless I jack into the line internally I have to keep the hatch open which isn’t optimal But that’s fine, just use the tank and pump until/if I decide to make it more permanent Takes up the back storage But that’s odd storage anyhow, I finally settled on putting a folding chair and table there, plus dirty laundry shoved through the interior hatch. And now this frees up that storage elsewhere. The tanks have been knocking about, mainly in the truck. The main filter has been in the Sea Biscuit back storage, but now I can put the chairs and whatnot there And … that’s it? I’ll sit with this a few days but I think I like it and will start to make it permanent 👍 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
Steve and MA Posted June 3 Posted June 3 2 hours ago, DanielBoondock said: Proof of concept; onboard (inboard?) water conditioning and filtering... Very clever use of basement space. Never thought of removing the panel under the nightstand to gain a few inches of height. Blutech didn't offer their low profile filter system at the time we set ours up, and most softeners small enough for the basement have limited capacity between recharges, so we installed our filter/softener system in our TV, which also has two Blutech hose reels with quick connects for intake from city water and output to the Oliver fresh tank. The reels each hold 50' of hose, so reach hasn't been a problem. Even when full hookups are available, we fill the fresh tank and rarely use the city water port. The basement door stays shut. We also have the Nature's Head, so we only deal with fresh and gray. We run out of fresh water about the same time the grey is full. The inaccuracy of the gauges isn't much of a problem since the grey can't overfill from a single fresh tank, and we haven't ever run out of fresh water before knowing it was low. Steve 1 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
DanielBoondock Posted June 3 Author Posted June 3 9 hours ago, Steve and MA said: Very clever use of basement space. Never thought of removing the panel under the nightstand to gain a few inches of height. Second choice was opening the hatch under the bed and possibly raising the bed some way to make a space. I’ve got Froli installed plus the condensation mats which might be enough, if I opened a hole in them. Fortunately this works better and makes good use of the space. I rearranged everything last night and like it better than before Quote Blutech didn't offer their low profile filter system at the time we set ours up, and most softeners small enough for the basement have limited capacity between recharges, so we installed our filter/softener system in our TV, which also has two Blutech hose reels with quick connects for intake from city water and output to the Oliver fresh tank. The reels each hold 50' of hose, so reach hasn't been a problem. If this didn’t work I was going with that approach Quote Even when full hookups are available, we fill the fresh tank and rarely use the city water port. Good to know thanks! Yeah I was leaning in that direction, why use city water at all when you only need to fill the tank every couple days? Quote The basement door stays shut. We also have the Nature's Head, so we only deal with fresh and gray. We run out of fresh water about the same time the grey is full. The inaccuracy of the gauges isn't much of a problem since the grey can't overfill from a single fresh tank, and we haven't ever run out of fresh water before knowing it was low. Good tips … OK yeah with your encouragement this is a go - it’s already basically done. I just need to brace the tanks, maybe I’ll get the Blutech mounting frames or something else. Final bit is I just need some power, right now it has a 120V adapter but it’s 12V so I’ll go that route. For the time being I’ll use a small portable power bank. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
DanielBoondock Posted June 4 Author Posted June 4 OK the filterification of the Oliver is done and tested. Just need a little padding/bracing, I think a foam pad between the tanks is all I need. It’s so tight in there they’re already pretty secure. Here’s a block diagram of what I ended up with The reasoning is that all this filtering greatly reduces water pressure and slows the fill basically. I don’t need the Offgrid Filter (down to .5 u paper filters + UV sterilize) for the fresh water tank, just the softening is sufficient. So I have a loose “To fresh tank” quick connect line when filling, just three easy connections for waterpoint and to tank, just using the softener/Fe I open the offgrid line and snake the hose into a 5 gallon drinking water tank to fill that up. Plus power - I need to get a 12V cig output into the basement The third is for spraying off the truck + trailer. Softened so that ideally it leaves no water spots I don’t know how this worked out but somehow, with the water tanks taking up that back space (leaving room to toss dirty clothes around them) I seem to have more storage overall. I’ll take it though 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
DanielBoondock Posted 56 minutes ago Author Posted 56 minutes ago Trail cam! The Sierra EV has one of if not the biggest screen in the industry, massive 17” tablet, and GM’s got IMO the best cameras in the industry. Anyhow I can have two trailer cams, I’ve got one on the back for transparent trailer etc. I put the second on as a trail cam Spent a long time thinking about where to put it. Up top is pretty well covered with the other cameras, I realized the ground was the weak spot. Use cases you all will be familiar with Shows levelers/chocks etc. When driving on/off levelers it’s impossible to tell where you are and I often overshoot and bung them up as there’s few inches of margin with dual axel When offroad, or even parking lot speed bumps, will be really nice to see them coming instead of guessing for known obstacles. Sometimes I have to drive over a curb too Fun and a good idea to keep an eye on the trailer suspension Backing up to a stop. At my park I have the cement parking stop placed where I want it, but I can’t tell where it is until I hit it. Installation was ridiculously easy. This and only this cross bar was perfect as its the only one not holding anything up, so I could simply zip tie to it. And of course they have these genius cable runs on the two edges. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
