My two thousand twenty five elite two has the compost toilet. The toilet is too high for my wife. I want to remove it and replace it with the regular rv. Flush toilet. Has anyone done that and how difficult is it.
Welcome to The Forum, Douglas!
I read mention of one case of this change on these pages. Somebody else should chime in that knows the particulars.
Your black tank is down there below. You'd have to connect the water supply. You'd know whether you have a hose-bib outside, up front streetside for the tank rinse. If you're somewhat handy it should be easy enough. As you're working your mod ask any questions here (pictures help).
BTW, the standard toilet which we have is not as tall but still somewhat tall.
It has been done - not sure if it was detailed in the forum anywhere. We had the compost previously and will again in the new Ollie and yes, it sits fairly high.  One out of the box remedy is a small custom-made riser that fits snugly around the foot area.  I was going to do that, but we sold the Ollie before I got around to it.
RB
Cindy,  Russell and  "Harley dog" . Winchester TN
2027 EII on the production board. "Ramble On"
2026 Chevrolet 2500 ZR2, 6.6L L8T gas V8
Our 2016, Hull # 145 has the composting toilet.  Underneath there is nothing but fiberglass floor.   No connection what so ever.  If a future owner ever wants to revert to a standard toilet, that would be one problem that needs to be solved.
Scotty
The Foybles in Wood 2026 catalog shows a footstool that goes around the front of the composting toilet. Looks like it fits just below the urine container on the toilet.
https://drive.google.com/file/d/17XFL_5ine1WusHVKYguUBRmkj2KnJUN_/view
Not sure if this is still in production but if it is, it may save you some work.
Tony
2017 Legacy Elite II Hull #251 (with updates)
TV:  2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2)
Forum members have also used the Squatty Potty as a toilet stool, notching the leg to fit over the lip of the shower. If you have a wooden floor in your shower, you can put a dowel in the bottom of the Squatty Potty legs and a matching hole in the shower floor. This keeps the stool in place, and easy to remove.
https://a.co/d/0ixPew5p
Steve - Northern Ohio, USA
Facebook - Instagram
On 11/17/2026 at 12:37 PM, Douglas Brabston said:
too high
It really is too high for even relatively tall people, partly because of the dropped shower pan.  We have manage to learn to shimy onto this thrown but I have pondered adding either a teak shower insert or something else to reduce the drop. Who wants to feel like a 3-year old with legs dangling? Ok, I am exaggerating but only slightly.
@Douglas Brabston My 2018 Ollie II is set up for doing just that. When I take the compost toilet out of the trailer for cleaning, I can see a cut out in the floor and the black tank below and the water line is in place with a shutoff valve. I think you might need at least a toilet flang. Take your compost toilet out and inspect what you have in your Ollie.
But, you should check with OTT company to make sure you are all set and/or what parts you might need.
