Rumline Posted March 26, 2018 Posted March 26, 2018 We're considering getting custom fitted sheets made ahead of our pickup in June. Does anybody who has the KTT latex mattress upgrade have measurements handy for the mattress? Are the length and width actually 30 x 75"? What is the depth, from the top of the bunk underneath to the top of the unladen mattress? I was just planning to get a "regular" rectangular sheet made but if anybody has the radius of the back corner that might be helpful to other readers. 2018 OLEII #344 | 2018 Ford Expedition
Moderators topgun2 Posted March 26, 2018 Moderators Posted March 26, 2018 Rumline - I do not have that exact mattress, but the optional mattress I have measures: 8 5/8 thick 74 long 29 7/8 wide All I can tell you about the radius is that at the 45 degree (middle) point of the arc the mattress is 1 inch shorter than it is where the arc starts. Hope this is some help to you! Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Townesw Posted March 27, 2018 Posted March 27, 2018 I just tried to measure our new KTT mattresses and it is not as easy as you think it is. They are "about" 29-29.5 wide by 74-74.5 long by 7-7.50 deep depending on where and how you measure them. My wife ordered 2 sets of AB Lifestyles 30x75 Bunk sheets and they fit well enough that we ordered 2 more sets for spares. The bottom sheet is fitted on all 4 corners. The top sheet is fitted on the bottom 2 corners. She also ordered quilted top mattress covers that fit well but I can't find the source of those. If you're interested I will continue to look. Hope this helps. Bill 2 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Rumline Posted March 27, 2018 Author Posted March 27, 2018 Thank you for the replies. I saw the AB Lifestyles sheets, and they look quality, but I'm not sure I would like a half-fitted top sheet. I mean it sounds like a nice idea but I like to stick my feet out to regulate temperature and prefer my top sheet to float. I was looking at "Advanced Bedding" but they're almost twice as expensive for roughly the same product (300 thread count cotton). Maybe I'll contact AB Lifestyles to see if they can make a regular top sheet. 2 2018 OLEII #344 | 2018 Ford Expedition
rideandfly Posted March 29, 2018 Posted March 29, 2018 AB Lifestyles made memory foam mattresses for our twin Ollie probably during the summer of 2016. They should have mattress dimensions with proper radius. If they can't find order information, please PM, I will get the order number and may also have a top view drawing of the mattresses in Ollie. 1
Overland Posted March 30, 2018 Posted March 30, 2018 Oliver used to stock full size templates for the mattresses. You might give Anita a call and ask if they have them and can ship one to you.
rideandfly Posted March 30, 2018 Posted March 30, 2018 Found this drawing that came with our 10" memory foam mattresses, they fit nicely and are very comfortable. Assume top view mattress dimensions are all the same, installed in Hull 75. 1
Geronimo John Posted May 4, 2018 Posted May 4, 2018 Bill: Thanks for the template! SHEETS: I have read many reviews of the "Cot Sheets" being sold on Amazon and frankly the quality of the sheets sold seems to be pretty poor. Does anyone have a good sheet set recommendation in addition to the AB Lifestyles ones listed above? Thanks, Geronimo John TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Overland Posted May 4, 2018 Posted May 4, 2018 I'd just get a twin bed set from the store. You'll have to tuck a little bit more, but frankly, the 'correct' sized sheets that we got from AB Lifestyles aren't anything to write home about. The top sheet is very narrow - more like a ribbon than a sheet. Pretty useless, actually. And the material is O.K., but nothing special. We've kept the fitted sheets on to keep the mattresses clean, but just use sleeping bags on top now.
Try2Relax Posted May 5, 2018 Posted May 5, 2018 You are correct that there aren't any cot sheets that are any good, about 200 thread count. What I have found that works well is just using a king size sheet and tucking the fold into the wall, then only one sheet is needed. Of course, I only use flat sheets. Randy One Life Live It Enjoyably 2017 F350 6.7L SRW CC LB 2015 Oliver Elite II Hull #69
