Foy_Mirna Posted May 31, 2019 Posted May 31, 2019 I got tired of seeing my Anderson hitch chains looking rusted and I knew paint was only going to be temporary solution. I considered replacing the chains with plastic/rubberized covered chains but found a lower cost option. I used Techflex Flexo Clean Cut 1 1/2-Inch Braided Cable Sleeve, in black - 10 Feet. Amazon sells it for $8 - https://www.amazon.com/gp/product/B007VT09LS/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1 The 10 foot length is perfect to cover both chains in my case. It cuts clean with scissors and the ends can be burnished with a lighter. You can still see through the braiding to make sure you have no twisted in the chain and it only took a few minutes to put on over the chains. I used tie-straps braided through the last chain links on both ends to hold them in place. 7 3 Onward, Foy and Mirna Roamy Mc Roadhouse 2017 Legacy Elite II, Twin Bed Hull #227 2021 RAM 1500 Limited
Moderators topgun2 Posted May 31, 2019 Moderators Posted May 31, 2019 You da man! I've cleaned and spray painted mine each year before I put Twist into storage for the winter. However, it appears that your idea will save me that time and effort - THANKS! Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Rleog Posted June 4, 2019 Posted June 4, 2019 I just installed mine an hour ago. Thanks for this suggestion. Bob G
Patriot Posted June 7, 2020 Posted June 7, 2020 Added to my list! Thanks Foy! 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
GarryandKristi Posted March 12, 2021 Posted March 12, 2021 Hi, curious to know if the covers have worked longer term. Ours tend to rust even when kept off the ground so I am wondering if these just prevent you from seeing the rust as it would seem to me that the sleeves would not seal the chains from humidity and they would still rust? I was thinking of plasti-dip spray but that would likely be messy with links partially “rubber welded” at their junctions. Garry and Kristi Apex, NC 2018 Oliver Elite II Hull 372 TV 2015 Ram 1500 3.0 L EcoDiesel
Moderators topgun2 Posted March 12, 2021 Moderators Posted March 12, 2021 (edited) Yep - these "chain covers" are actually a mesh. Therefore, they are certainly not sealed from the elements. If your chain was rusting before putting these over the chains then they will still be rusting when you take the covers off (if you ever do that). However, you will not see that rust and the covers are easily cleaned with a strong stream of water and/or a light brush. Bill p.s. My cover don't look any different than they did the first day I installed them a couple of years ago. Edited March 12, 2021 by topgun2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators topgun2 Posted March 14, 2021 Moderators Posted March 14, 2021 Foy - Its been bugging me now for the better part to two years - get rid of those nasty galvanized shackles of yours and replace them with nice stainless steel ones!☺️ https://www.amazon.com/MarineNow-Stainless-Shackle-Anchor-Recovery/dp/B01CGYYQ7K/ref=sr_1_5?dchild=1&keywords=stainless+steel+shackles&qid=1615680988&sr=8-5 Caution - check the size before ordering. 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
