Nan Posted December 3, 2019 Share Posted December 3, 2019 I need to clean out the window tracks. Can the weatherstrip that is removed to do this be placed back on the windows, or do I need to put a new weatherstrip on each window? Thanks Link to comment Share on other sites More sharing options...
Moderators mossemi Posted December 3, 2019 Moderators Share Posted December 3, 2019 The white weather strip the covers the outside track of the sliding window is reusable. Be sure to have fun while cleaning the window tracks. Mike Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
Nan Posted December 3, 2019 Author Share Posted December 3, 2019 7 hours ago, mossemi said: The white weather strip the covers the outside track of the sliding window is reusable. Be sure to have fun while cleaning the window tracks. Mike Any tricks I need to know? Two of the windows were leaking rain into the camper and I hope this will fix the problem. Thanks. Link to comment Share on other sites More sharing options...
KarenLukens Posted December 3, 2019 Share Posted December 3, 2019 (edited) Leaking Windows need to be sealed. I've used duct tape across the top of the windows for a quick fix, plus I added rain gutters over all of the windows and that helped a lot. My old 85 pace arrow motor home never had a window leak in the 30 years we used it but the Oliver windows need to be all torn out and resealed when it comes off of the line. We also had to seal everything on the roof that had been overlooked by Oliver on our build. Plus, the rain gutters that were put in our windows at the factory actually blocked the drain holes, so they would fill up completely with water and run over inside. I ended up removing the windows built in gutters, cutting and modifying the plastic by putting drain holes where they should have been. The thing that you should do is just pull out the windows as soon as possible and then remove any old caulk and then install and seal them properly yourself. I used a dremel tool to cut the drain holes in the plastic gutter liners and to enlarge the drain openings. Ours leaked from day one until I did this. It was by far, Oliver's biggest fail in our long list of problems that we have all fixed on our own. Don't wait like I did while trying to find the leak. Ours were never sealed at the factory. Edited December 3, 2019 by KarenLukens Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II Link to comment Share on other sites More sharing options...
Nan Posted December 3, 2019 Author Share Posted December 3, 2019 (edited) 45 minutes ago, KarenLukens said: Leaking Windows need to be sealed. I've used duct tape across the top of the windows for a quick fix, plus I added rain gutters over all of the windows and that helped a lot. My old 85 pace arrow motor home never had a window leak in the 30 years we used it but the Oliver windows need to be all torn out and resealed when it comes off of the line. We also had to seal everything on the roof that had been overlooked by Oliver on our build. Plus, the rain gutters that were put in our windows at the factory actually blocked the drain holes, so they would fill up completely with water and run over inside. I ended up removing the windows built in gutters, cutting and modifying the plastic by putting drain holes where they should have been. The thing that you should do is just pull out the windows as soon as possible and then remove any old caulk and then install and seal them properly yourself. I used a dremel tool to cut the drain holes in the plastic gutter liners and to enlarge the drain openings. Ours leaked from day one until I did this. It was by far, Oliver's biggest fail in our long list of problems that we have all fixed on our own. Don't wait like I did while trying to find the leak. Ours were never sealed at the factory. Thanks for the information. This should be a trip for a 73 year old Grandmother to do! Edited December 3, 2019 by Nan Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted December 3, 2019 Moderators Share Posted December 3, 2019 We’ve never had a leak from our windows. Before removing windows try cleaning the tracks to see if that solves any leak issue. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Landrover Posted December 3, 2019 Share Posted December 3, 2019 Another tip you might want to consider. While you have the rubber weather strips removed. Place them in a bucket with a solution of bleach and warm water let them sit for approx 20min then rinse. This will Remove the back spots mold on them and they’ll be white again. 2 Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎 Link to comment Share on other sites More sharing options...
KarenLukens Posted December 3, 2019 Share Posted December 3, 2019 5 hours ago, Nan said: Thanks for the information. This should be a trip for a 73 year old Grandmother to do! Honestly, you can tell right away if they need to be resealed by running a strip of duct tape over the top of the window seal. Run it so that the top of the tape is stuck to the hull and the rest covers the top window seal. If your leak stops with the duct tape over it after the next rain, then it needs to be resealed. Or just continue with using the duct tape as a quick fix. Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II Link to comment Share on other sites More sharing options...
Moderators mossemi Posted December 4, 2019 Moderators Share Posted December 4, 2019 Nan, see this post. Mike Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
Nan Posted December 4, 2019 Author Share Posted December 4, 2019 29 minutes ago, mossemi said: Nan, see this post. Mike Thank you so much! Link to comment Share on other sites More sharing options...
choied Posted January 4, 2020 Share Posted January 4, 2020 (edited) On my 2017 LE2, I had serious condensation and some window seals leaking apparently on my last trip to the Northwest. When I got home I got to investigating by removing the window shades and the inner clamp ring. The window shades can be removed by taking a flat-head screwdriver and getting between the shade and the window next to clamp and giving the screwdriver a turn. This will pop-off the shade which is held on my tension at six spots (3 on top and 3 on bottom). Removing the clamp ring can be done by unscrewing some screws from around the window on the inside of the trailer. After removing these two items - you should be able to see some of if not all of the insides of the window frame .... depending on how they cut and/or shimmed the window into the fiberglass. I had my daughter inside with a flashlight and I was outside hosing the window under the light fixture. After a few starts and stops after a few "hey dad, there is water coming in" ... we discovered a small imperfection in the sealant applied to the window frame on the top of the unit......otherwise known as the "leak"....lol. You could see the water on perfectly sealed spots simply traveling down the body of the trailer, but in this one spot... the water appeared to be entering the trailer. The window is mainly sealed using the sealant that you can see from the outside .... looks like white silicone. On the inside of the window frame (once you have taken it off) you will see foam tape. This is not a sealant and will not prevent water from entering the unit. So I will now be removing my windows and sealing them up with butyl tape. If you have never seen or used butyl ... you should know that using it is a "no brainer". Stuff should last a very very very very long time and provide users with peace of mind. I like my mind at peace. On the light fixtures, I simply removed the screws and used plumber's putty. Stuffed into the screw holes and spread some around the top of the rubber gasket .... like an umbrella. This was a quick fix, but I think it will hold until I have to replace the lights down the road. Edited January 17, 2020 by choied 2016 RAM 2500 LARAMIE MEGA CAB 4X4 2017 OLE2 - King Bed - Hull # 253 Link to comment Share on other sites More sharing options...
Ken_Judy Posted January 14, 2020 Share Posted January 14, 2020 Shortly after delivery of #381 it was discovered to have a defective window. Oliver service replaced it and removed and reinstalled all the other windows using butyl tape. Since they were seeing such good results with the butyl tape he also made sure that production removed the foam tape that came with the windows and installed butyl tape instead 1 2 Link to comment Share on other sites More sharing options...
Patriot Posted January 24, 2020 Share Posted January 24, 2020 (edited) On 1/13/2020 at 7:17 PM, Ken_Judy said: Shortly after delivery of #381 it was discovered to have a defective window. Oliver service replaced it and removed and reinstalled all the other windows using butyl tape. Since they were seeing such good results with the butyl tape he also made sure that production removed the foam tape that came with the windows and installed butyl tape instead The plant production manager told us during our most recent Jan 21 plant tour they are using butyl tape to seal the window frame to the outer shell. I ordered and today received rain gutter material in advance prepping for our delivery in early May. So I am open to pointers/suggestions on install. It appears to be straight forward. First I will need to get this roll warmed up and straightened out. Edited February 7, 2020 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor North Carolina 🇺🇸 Link to comment Share on other sites More sharing options...
