Well it is Spring in the Ozarks. The birds are looking for nesting sites. I am not real pleased that a pair decided our AC cover made an excellent bird house. If you look closely you will see they also took out part of the the foam insulation. Hopefully, only a small corner removed so will not impact performance.  Any ideas of how to prevent this in the future?
One of those duh moments. I found when I was washing the Ollie.   I finished my wash job. Then took off the cover and cleaned out the nest. Of course scattering debris all over the freshly washed roof. Sigh!
Edited by ThomB87
grammar
Bill Thomas 2019 Elite II Hull # 534
2020 Chevrolet Silverado HD 2500
A full custom made cover is what we plan to use.
 https://calmarkcovers.com
-Patriot
Edited by Patriot
Thanks! I will look for the AC cover. Ms. Bertie is keep in a carport with sides to protect her from sun and weather. So I do not need a full cover. I was worried about insects but never thought about birds. I may cut off their food supply.
AK - while I've seen ac cover that have a cinch rope at the bottom, I would not trust that to keep the cover in place while traveling down the road.
ThomB87 - Probably no need to "cut off their food supply" once you get a cover.  But, I did have a bird build a nest on the folded steps under my CalMark cover one year.
On 3/28/2020 at 3:49 PM, ThomB87 said:
Must be the optimum spot - I had a bird condo in the same spot.
Edited by BackofBeyond
If anyone orders an AC cover would you mind posting up a link? We don’t have our Ollie yet so I don’t know the dimensions of the AC unit n order to place an order. Thanks!
-Patriot
20 hours ago, Maverick said:
This is the same cover I purchased some time ago and it fits nicely.
Thank you Maverick, order placed.
Here are pictures with the cover and the product code. My trailer is a 2019 with the Dometic Penguin II AC. Note the suggestion to block the holes while waiting on the cover is a good one. The birds started rebuilding within a day of moving our Ollie back under the carport. I would not leave this on for travel only for storage. The cover should work for dirt daubers as well as birds.  I am sure you could get order on other sites as well.
  • 1 month later...
My experience with rubber snakes is that they simply don't move - and - the birds eventually figure this out too.😪
