Trainman Posted July 2, 2020 Share Posted July 2, 2020 Well to date my biggest dislike is where the fresh water tank drain valve is located. It's just in a very not convenient place to get to, I have to raise the mattress, take off the door, and reach down on my hands and knees to open it, close the same procedure. If that round excess door they put there was for that use, then you would have to bend your arm backwards to use it. I guess I could install a small excess door like the one in the bathroom located about the valve. My other trailer had this valve located outside, but being an all weather trailer this wouldn't work out too well for the Oliver. Anyone came up with other ideas that work better for them. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Link to comment Share on other sites More sharing options...
Moderators mossemi Posted July 2, 2020 Moderators Share Posted July 2, 2020 You could always convert that valve to a 12v valve and add a switch. ScubaRx did that for the Boondocking port. Mossemi Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
John E Davies Posted July 2, 2020 Share Posted July 2, 2020 (edited) On my trailer the small round hatch is for the Suburban hot water heater bypass valve, I can’t reach the fresh drain through that hole because the big air duct is in the way. Another round hole a foot forward would give access, but it doesn’t bother me to rotate the mattress 90 degrees to go in through the top. I rarely drain the tank - I tow with it full - and when I do, I am often operating other valves and inspecting for leaks.... John Davies Spokane WA Edited July 2, 2020 by John E Davies 1 "Mouse": 2017 Legacy Elite II NARV (Not An RV) Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 33" LT tires, airbags, Safari snorkel. Link to comment Share on other sites More sharing options...
Overland Posted July 2, 2020 Share Posted July 2, 2020 (edited) If you've got the Truma, then you can open the Truma drain and turn the pump on. It will drain the fresh tank in no time. You could do the same with any faucet, but it would take longer. Edited July 2, 2020 by Overland 2 1 Link to comment Share on other sites More sharing options...
Ray and Susan Huff Posted July 2, 2020 Share Posted July 2, 2020 (edited) 2 hours ago, Overland said: If you've got the Truma, then you can open the Truma drain and turn the pump on. It will drain the fresh tank in no time. You could do the same with any faucet, but it would take longer. For those without the Truma, what about the outdoor shower? Slow, as well, I suppose. Edited July 2, 2020 by Susan Huff Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold) Link to comment Share on other sites More sharing options...
Moderators mossemi Posted July 2, 2020 Moderators Share Posted July 2, 2020 I am usually at home when I drain my freshwater tank and I just let it run on my ground which can always use the water. And for me it is simple to flip the bed on edge and lift off the hatch lid which I then use to prop up the bed at 90°. And as JD mentioned, it’s a good time for a visual inspection of the water pump and valves. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
Mainiac Posted July 2, 2020 Share Posted July 2, 2020 How often does anyone drain the tank? I drain it when flushing, sanitizing, or winterizing. Have to get in there to move other valves anyway to accomplish those tasks 1 2 Link to comment Share on other sites More sharing options...
