parkervet Posted July 3, 2020 Posted July 3, 2020 How to fix a stuck stabilizer jack in 2016 elite II?
John E Davies Posted July 3, 2020 Posted July 3, 2020 (edited) Stuck how? Does it blow the fuse? Make bad sounds? Have you tried cranking it with the emergency crank handle? The handle fits on the square shaft that sticks out the top. It might just be gummed up and need servicing. Please elaborate, John Davies Spokane WA Edited July 3, 2020 by John E Davies SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Ray and Susan Huff Posted July 3, 2020 Posted July 3, 2020 8 minutes ago, John E Davies said: Stuck how? Does it blow the fuse? Make bad sounds? Have you tried cranking it with the emergency crank handle? The handle fits on the square shaft that sticks out the top. It might just be gummed up and need servicing. Please elaborate, John Davies Spokane WA @John E Davies I'm concerned about your stabilizer jack. What is that hole in the center of the side (silver part - whatever that is). Looks like it is drilled as there are shavings under it. Just wondering. Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
Moderator+ ScubaRx Posted July 3, 2020 Moderator+ Posted July 3, 2020 That hole is not in my jacks. It appears that it has been drilled and tapped. Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Ray and Susan Huff Posted July 3, 2020 Posted July 3, 2020 Maybe @John E Davies will clue us in 😉 1 Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
John E Davies Posted July 3, 2020 Posted July 3, 2020 (edited) Sharp eyes! You are the first to comment on that. I said a bad word when I first saw them. The jack is the front one, it has a plastic rain/ switch cover. The screws are self tapping and when the factory built it, they did not care that shavings were going everywhere. They don’t hurt anything. There were no shavings inside the gearbox. ... the drilled holes do not pass all the way through. ... https://olivertraveltrailers.com/forums/topic/4094-how-to-vip-3000-electric-stabilizer-jack-service/ .... I wasn’t trying to hijack the thread, I just wanted to show what the drive shaft looks like. The two in back have no plastic covers. John Davies Spokane WA Edited July 3, 2020 by John E Davies SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderator+ ScubaRx Posted July 3, 2020 Moderator+ Posted July 3, 2020 Sometimes when you run the jack up too far, the torque converter in it will get jammed/cross-threaded/buggered (pick a term you like). At any rate, the motor is unable to make the internal screw turn up or down. This happened to me several years ago. I put the jack handle on it and really had to push/pull hard to break it loose. But, once done, it operated normally and has ever since. Remember, it may be hard to break loose. 1 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderators Mike and Carol Posted July 3, 2020 Moderators Posted July 3, 2020 10 hours ago, parkervet said: How to fix a stuck stabilizer jack in 2016 elite II? More details would be helpful. I had a rear jack stuck in the up position, like Steve did. I removed the mattress to access the top of the jack and used the supplied jack handle to lower the jack until the gears caught and then it worked fine. I try not to raise the jacks to the click-click-click position for that reason. Mike 5 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators SeaDawg Posted July 3, 2020 Moderators Posted July 3, 2020 Years ago, we painted a line on our Jacks so I could see where to stop them before the click clack noise . 3 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Patriot Posted July 3, 2020 Posted July 3, 2020 1 hour ago, SeaDawg said: Years ago, we painted a line on our Jacks so I could see where to stop them before the click clack noise . I like this idea and have added it to the to do list. 👍🏻 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John E Davies Posted July 3, 2020 Posted July 3, 2020 (edited) I don’t worry about clack clack clack. I run them all the way up until they make that unpleasant sound, but then I run them all back DOWN a fraction. I suspect that the rare times that these jacks freeze up is because the clutch has stopped in mid-clack and it binds up somehow ..... I have no idea if this is true. I have never read this. I am probably just wasting your time. If mine ever jam I will come back and post an update. 😀 FYI there is no way to lube the clutch, it is sealed tight. John Davies Spokane WA Edited July 3, 2020 by John E Davies SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators Mike and Carol Posted July 3, 2020 Moderators Posted July 3, 2020 3 hours ago, SeaDawg said: Years ago, we painted a line on our Jacks so I could see where to stop them before the click clack noise . This is exactly what we do. I found that the paint would wear off so I now use some thin white tape to mark where to stop. Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators SeaDawg Posted July 3, 2020 Moderators Posted July 3, 2020 Parkervet, what's your battery level? Are you plugged in? Our jacks won't operate if the voltage on the battery is too low. They might start, then quit. Fuse? Bad ground? Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Trailblazers Posted July 7, 2022 Posted July 7, 2022 On 7/3/2020 at 8:34 AM, Mike and Carol said: More details would be helpful. I had a rear jack stuck in the up position, like Steve did. I removed the mattress to access the top of the jack and used the supplied jack handle to lower the jack until the gears caught and then it worked fine. I try not to raise the jacks to the click-click-click position for that reason. Mike Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Trailblazers Posted July 7, 2022 Posted July 7, 2022 Thanks Mike for the tip. One of my rear jacks would not come down. I thought it was shot, on day three of a three week trip. Saw your post, so gave it a try. I went under the bed and hand cranked it down some and then it worked fine. Thanks so much! 1 1 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
