I have been trying to program the TV to utilize the radio speakers. I went onto the Oliver University instruction site but the programming instructions given did not match the functions on my TV controls. I suspect that the Oliver University instruction was for a different model Furrion TV.
I have a 2018 Oliver Elite II. Has anyone been able to have the TV audio come on the radio speakers and if so how did you program it? Thanks
Yes you can program to use the speakers - our 2018 was set to do so - I can not remember the process and alas we no longer have Ollie to use as reference. The instruction manual had the details. Good Luck.
RB
Formerly of #359
2027 EII on the board.
Try using the search feature.  My search for "speakers" returned 114 posts and here are 2 that may be of interest.  One of the post is for the Furrion tv and radio and the other is about Jensen equipment.
Good luck,
When we purchased our 2015 Oliver was no help in getting the TV audio to the radio speakers.  I determined how it should be done, at the time I sent the written procedure to our sales person,, who knows what he did with it.
Attached is my procedure that works for us.
Oliver TT Television Speakers via Radio.doc
Horace & Dianne
Chesapeake, Virginia
Used this Oliver video for setting up sound from Furrion stereo speakers when using Jensen TV on our 2015 LE2 #75. Don't know if Furrion TV works the same way.
Bill 2015 LE2 2024 F-350 6.8L
Mossey:
Thanks for the link. I did do a search myself but did not find the one from ShallowGal.
I also looked at the Oliver University TV video and in the Furron owner's manuel but neither solved the issue.
ShallowGal's 2017 and my 2018 Ollie's apparently have the same model Furron TV and radio. (We do not have the TV Audio TV Speaker option to turn off the TV speakers.)
ShallowGal's procedure of switching the radio Input Mode to "ARC" was the answer to getting the TV audio onto the radio. Simple one step procedure.
Thanks Mossey.
 NEW Question: The radio has a USB connection on the front panel. The owner's manual does not say what size/series this USB connection is. I have a memory stick with music on it but the memory stick does not fit into this Furron USB connection. Does anyone know what USB connection size/series it is and how I would be able to connect my memory stick?
I don't have your radio, so I don't know which usb connector works, but you can buy little adaptors on walmart, best buy, or Amazon to convert usb to usbc, etc.
This picture may help.
From the pictures sent by Mossey, I am guessing that it could be either the USB 2.0 Standard-A or the USB 3.1 Standard-A.
Monday I will call Furrion to see which USB they use, so I do not order the incorrect plug to switch from the Furrion to the memory stick..
I will pass on to all what they say.
Thanks Mossey and SeaDawg.
