WOW!  What a Christmas present.  And, at this point the weather forecast doesn't look too bad.  In fact, temps should be a number of degrees above normal.  Sure do hope that forecast holds true for you guys.
congratulations!
however much time do you have scheduled to pick up your trailer, plan on more time, slow everything down, ask lots of questions, and try to look at each and every component. turn all the switches on and off, and make sure everything works as it should. that includes turning the fridge on and off, putting it on natural gas and electricity, and also turning the furnace on and making sure hot air comes out of all of the vents.
Congratulations -- what a great way to spend Christmas!
my Oliver has camped here
High temp forecast for Hohenwald for tomorrow (Dec. 27, 2021) is 71 degrees!
Are we having fun yet?
We are just about two weeks ( 11 Jan 22 ) # 985 behind you .  Hope all goes well for your delivery .
Safe travels………
Cheers !!
Ollie 2022 LE2 # 985
2006 Dodge Ram Cummins 2500
Upstate NY/VT border
Safe travels………
Cheers !!
13th for us with 996 hull, have fun...may see you at camp 🙂
The forecast for the next couple of weeks (after this week) is for the area to get back nearer to historic averages for this time of year - it has been near record highs for the past 10 days or so.  This means that daily highs should be in the upper 40's to low 50's.  However, it is best to keep a close eye on the weather as you get near your planned delivery date for the obvious reasons.
Good luck!
p.s. Coach and Jojo should not have difficulty testing the air conditioner at delivery today.😃
