Coach and JoJo Posted January 8, 2022 Share Posted January 8, 2022 Does anyone have Tire Minder monitoring system hooked up on your Ollie? If so, where did you install the Repeater booster for the signal? Looking for advice... Link to comment Share on other sites More sharing options...
StanBenson Posted January 8, 2022 Share Posted January 8, 2022 We have one. I plug it into the 12V jack under the booth table and set it on the floor in a towel by the bathroom door. I have also hung it from a padded bag off the hook by the bathroom door, but I worry about it bouncing around. It works great. I'm happy that we have this setup. 1 Link to comment Share on other sites More sharing options...
Coach and JoJo Posted January 8, 2022 Author Share Posted January 8, 2022 Thanks for the Tip!!! Link to comment Share on other sites More sharing options...
dewdev Posted January 8, 2022 Share Posted January 8, 2022 I have the Tire Minder system and do not use the repeater. I found as long as I have the monitoring device by itself (no other devices next to it, like phone or GPS) I do not need the repeater. I would suggest you try it without the repeater hooked up at first and see for yourself. A number of other people on the forum also do not use the repeater. 2 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio Maine Link to comment Share on other sites More sharing options...
Mainiac Posted January 8, 2022 Share Posted January 8, 2022 Order a set onlne. $39.99. Works great, solar powered, and do not need a repeater... 1 Link to comment Share on other sites More sharing options...
VBistro Posted January 8, 2022 Share Posted January 8, 2022 I have Tire Minder. Set it up before our drive back from TN and it worked fine the whole way without the repeater. I keep the base unit plugged in in the back seat. I do think the repeaterh might be necessary for big rigs and/or 5th wheels and dualies, but maybe not for the smaller Ollies. 1 MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package Link to comment Share on other sites More sharing options...
John E Davies Posted January 8, 2022 Share Posted January 8, 2022 I have the Tire Traker system, it doesn’t require a booster either with an Ollie. Be aware that the length of your tow vehicle, and the amount of stuff, especially dense items like a generator or bikes, in the back or bed can block the radio signals. You can play around with the monitor’s position, it may work better at the left side of the dash rather than in the center. It certainly should not be down low on the center console. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
SteveCr Posted January 10, 2022 Share Posted January 10, 2022 I've had the Tire Minder since last May. It worked ok without the repeater, but would occasionally send a NS. I installed the repeater inside the battery bay....no issues since. 1 Link to comment Share on other sites More sharing options...
Geronimo John Posted January 15, 2022 Share Posted January 15, 2022 I have used a Tire Tracker for 4 seasons. Don't need the repeater with my OEII. Works well. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
