Gliddenwoods Posted October 4, 2022 Posted October 4, 2022 We have plugged our brand new 2022 (#1242) Oiver II into three different electrical outlets with GFCI at three different campgrounds and each time the campground outlet breaker trips; no 120v. If the outlet is not GFCI all is fine and we have 120v service. Question. Is this normal? Is it correct that all Olivers can not be used with 120v at any campground with GFCI outlets? Or is this situation unique to our new Oliver II? Many campgrounds have GFCI outlets so this situation would be/is disappointing! Be advise & thanks. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Ray Kimsey Posted October 4, 2022 Posted October 4, 2022 Yes, that is normal. I had the same issue when I tried to plug mine in at home. I had to use a non GFCI outlet at my house. 1 2019 Ram 1500 5.7L V8, 3.92 axle ratio - 2020 LEll - Hull676
dewdev Posted October 4, 2022 Posted October 4, 2022 Best to use your power cord at a campground, supplied by Oliver, and plug into their 30 amp outlet. 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
