thompsonkd Posted March 1 Share Posted March 1 A while back, Scuba Rx posted about a safety procedure that he recommended for our converters to prevent the possibility of the converter overheating. Using the search feature, I am absolutely unable to find the post! Can someone point me in the right direction to find the post? Thanks David Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L http://visitedstatesmap.com/image/INKYMINCTNlg.jpg Link to comment Share on other sites More sharing options...
Trainman Posted March 1 Share Posted March 1 Oliver had to replace mine because it would not cycle correctly, keep kicking on and off, replacement worked perfect. Not sure what the problem was, I just wanted it to work correctly and be done with it. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Link to comment Share on other sites More sharing options...
thompsonkd Posted March 1 Author Share Posted March 1 We are not having issues with our converter-we actually replaced ours when we went to lithium batteries. I was just trying to find a thread that Scuba Rx started about an issue with converters over heating. He talked about the need to inspect the converter to avoid the issue-the Forum search feature will not bring up the thread. Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L http://visitedstatesmap.com/image/INKYMINCTNlg.jpg Link to comment Share on other sites More sharing options...
John E Davies Posted March 1 Share Posted March 1 Maybe the lunchbox, AKA “Transfer switch relay”? https://olivertraveltrailers.com/forums/topic/7219-no-110v-power-proves-to-be-a-wiring-issue-with-my-transfer-switch/#comment-78186 John Davies Spokane WA "Mouse": 2017 Legacy Elite II NARV (Not An RV) Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 33" LT tires, airbags, Safari snorkel. Link to comment Share on other sites More sharing options...
thompsonkd Posted March 1 Author Share Posted March 1 Yes John! That’s it! Thank you. Darn search feature just doesn’t work. David 1 Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L http://visitedstatesmap.com/image/INKYMINCTNlg.jpg Link to comment Share on other sites More sharing options...
Rivernerd Posted March 1 Share Posted March 1 32 minutes ago, thompsonkd said: Darn search feature just doesn’t work. Yep. That is why I use Google with a search like: "Oliver converter inverter" to find threads on the Oliver forum relating to the inverter or converter. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package Link to comment Share on other sites More sharing options...
Moderators mossemi Posted March 2 Moderators Share Posted March 2 (edited) 17 hours ago, thompsonkd said: Darn search feature just doesn’t work. Try Rivernerd’s Google search "Oliver converter inverter" above and then try "site:olivertraveltrailers.com forum converter inverter", with forum converter inverter being the search words you are looking for at olivertraveltrailers.com. Then compare the results. There is an old saying about computers "garbage in, garbage out" which means that the computer will give you just what you ask for. And a ‘thank you’ goes out to DavidS, who shared the specific site:Oliver travel trailers.com a few years back. Mossey Edited March 2 by mossemi Clarification 1 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
thompsonkd Posted March 2 Author Share Posted March 2 Good idea. Might bring up more responses. David Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L http://visitedstatesmap.com/image/INKYMINCTNlg.jpg Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted March 4 Moderator+ Share Posted March 4 On 3/1/2023 at 11:24 AM, thompsonkd said: We are not having issues with our converter-we actually replaced ours when we went to lithium batteries. I was just trying to find a thread that Scuba Rx started about an issue with converters over heating. He talked about the need to inspect the converter to avoid the issue-the Forum search feature will not bring up the thread. Sorry I didn't see this when you first posted. As you've probably realized by now, it's not the converter, it's the transfer switch and is only included if you order the front generator hook-up port. The problem arose because the screws in the connector block had loosened over time and a loose connection will build up heat due to the increased resistance. As far as any concerns with the converter goes, you do need to make sure the wiring connections are all tight there as well. 2 Steve, Tali and the dogs: Reacher and Rocky plus our beloved Storm, Maggie and Lucy (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
thompsonkd Posted March 4 Author Share Posted March 4 Thanks for the clarification. Makes sense. David Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L http://visitedstatesmap.com/image/INKYMINCTNlg.jpg Link to comment Share on other sites More sharing options...
