Ty J Posted December 18, 2023 Author Posted December 18, 2023 My Victron worked excellent this summer. Im not retired but still spent 35 days this summer in my camper. I love power assist. Ran batteries Dead only 5 times on trips. I only have deployable solar panels. Im expermenting with a pecron and victron dc to dc charger. It has 4700 wh on it. I Trickled charged my Battle borns with 130 watts. Im currently putting in DC fridge. Thanks to everyone in the forum also adding the table on outside that is included on newer models. Thats my winter projects. I am overwhelmed at work and have not logged into forums in while. Multiplus is working well. Powers my a/c for about 5 hours. Have original penguin II. Expermenting with new flat solar panels from Bouge RV going to mount on top of oliver. 2021 Oliver Elite II. Only issue I have seen is when the victron is running hard its fans vibrate or radiate through the olivers fiberglass walls under my bed. Hottest it has been in cavity with Victron is 94 degrees , we had a mild summer in Montana. Did not get overly hot, like last year of 104 for 4 to 6 weeks. Weather has been all over the board up here. With the victron i set it to pull1200 wattes from my house plugs and can run a/c plugged into my normal outlet at house or anywhere. THe a/c will pull around 1450 watts , it just pulls extra wattage from battery bank and recharges them between cycling of the a/c . Take care My rig did not come with solar. Going to try flat panel on top. Little scared about heat impact on fiberglass, have used flat panels in past get extemely hot underneath. (PS white spots are reflections on my lights in my shop) Merry Christmas. 1 3 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
Ronbrink Posted December 18, 2023 Posted December 18, 2023 On 12/13/2023 at 10:18 AM, rich.dev said: The main reason I would swap out my Xantrex 3000 to the Victron Multiplus 3000 is Power Assist. What size cable did Oliver install leading to your Xantrex 3000, was it sufficient enough to accommodate the Victron or was it necessary to increase the cable size for the swap? My Xantrex Freedom XC 2000 has 2/0 cable and thinking it would have to be upsized for a similar install. Your pics show you installed the newer MultiPlus ll model, good move; and thanks for the update! Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
rich.dev Posted December 18, 2023 Posted December 18, 2023 7 hours ago, Ronbrink said: What size cable did Oliver install leading to your Xantrex 3000 My trailer is in storage but I’m pretty sure it’s 4/0 AWG cable. 7 hours ago, Ronbrink said: was it sufficient enough to accommodate the Victron or was it necessary to increase the cable size for the swap? Maybe this question was meant for someone else, I still have the Xantrex? 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Ronbrink Posted December 18, 2023 Posted December 18, 2023 39 minutes ago, rich.dev said: Maybe this question was meant for someone else, I still have the Xantrex? Sorry, my mistake. I will redirect. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted December 18, 2023 Posted December 18, 2023 18 hours ago, Ty J said: Multiplus is working well. What size cable did Oliver install leading to your Xantrex, was it sufficient enough to accommodate the Victron or was it necessary to increase the cable size for the swap? My Xantrex Freedom XC 2000 has 2/0 cable and thinking it would have to be upsized for a similar install. Your pics show you installed the newer MultiPlus ll model, good move; and thanks for the update! Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ty J Posted December 19, 2023 Author Posted December 19, 2023 Used 2/0. Changed out stock cables. Want to change out stock fuse later down the road also. Just need the time. 1 1 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
Ronbrink Posted December 19, 2023 Posted December 19, 2023 10 hours ago, Ty J said: Used 2/0. Changed out stock cables. So the 2/0 ‘stock’ cables were changed to what size, 4/0? I’m only thinking ahead, so a response when you find time is okay. Again thanks. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ty J Posted December 20, 2023 Author Posted December 20, 2023 I believe stock was 1/0 they were smaller and I had a bunch of 2/0 left over from my last installation on my lance. I had ton of 2/0 used on my Lance install. Thanks 1 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
Ronbrink Posted December 20, 2023 Posted December 20, 2023 10 hours ago, Ty J said: I believe stock was 1/0 they were smaller and I had a bunch of 2/0 If that is the case, a swap/upgrade to a 3000W inverter may be easier and less expensive than first thought. Current Xantrex Freedom XC 2000 Input cables are 2/0 If the hard reset (reboot) currently being conducted doesn’t resolve the charge cycle issues with this inverter, then said swap/upgrade is inevitable. Again, thanks for the info, much appreciated! Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ty J Posted December 21, 2023 Author Posted December 21, 2023 @2500 watts and 12 volts Your amperage would be around 210 amps most I ever plan to use. Keeping the length of cable down is critical. Keeping cables under 10 ft should be o..k.k. for 2/0 according to many of charts I have looked at. Critical to have good fuse. Thats what protects your wiring. 1 1 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
rideadeuce Posted April 9, 2024 Posted April 9, 2024 I am thinking about swapping out Xantrex 2000 for a Victron Multiplus II 3000 and installing upgraded Lithium batteries. The part that I need help with is the wiring from the PD 4000 distribution panel and bypassing or disconnecting the charger. Still need converter portion for shore 110v? MP2 for Inverter DC to AC, power switch (Shore to DC, DC to Shore) and charging. Does the OEM wiring from the junction box on Xantrex end just go into the AC IN and AC OUT on the Victron Multiplus? Or do you need to run the shore power out of EMS to Multiplus AC IN and then back to distribution panel. Do you simply disconnect charger? If you run new longer feed from the EMS to MP 2 AC IN then can you use the AC OUT back to the PD 4000? OR does the EMS to MP2 go back to shore power in the same AC in on back of PD 4000. Any clarification on these questions or pics would be greatly appreciated. Just trying to figure it all out before hiring someone or diving in myself. I, also, just want to understand how it works. Thanks in advance for any feedback. Mike - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Ty J Posted April 10, 2024 Author Posted April 10, 2024 I my xantrex had dc charger built in. I rewired my total dc side though did not like wiring from factory. You should be able to remove the dc xantrex charger. Yours is different layout would have to follow your wires. Never touched ac side at all except hooked up proper breaker to proper spot. AC on fridge and ac on air conditioning were wired backwards from factory. Found that out when tried running AC off my batteries alone. Rewired dc side with victron shunt and lynx distribution on fender well. Very tight 1 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
Teaney Hull 292 Posted April 4 Posted April 4 On 4/28/2023 at 11:51 AM, John E Davies said: I have concerns about cooling. That compartment is dead end and gets very hot in summer. How will you deal with that? Your unit is horizontal, which isn’t desirable, and it doesn’t appear to have the required 4” clearances all around it. Do you plan to add vents and a blower or fan? Can you easily remove the black service cover for service or adjustments “in situ”, without taking the unit out? Are you a “qualified electrical engineer” and do you think your warranty will be good? What does your warranty booklet say about this? I would greatly appreciate some closeups of the wiring. Here is a full article on installation. https://www.victronenergy.com/blog/2020/10/30/how-to-install-a-multiplus-inverter-charger/ Victron MultiPlus II intro video I love some Victron components, others drive me completely nuts. Their batteries for example, have no onboard Battery Management System, and they cannot function without the full suite of their proprietary controls and chargers, and they have to ship by a trucking company as hazmat freight…. $$$$$. (Battle Borns ship by FedEx.) Thanks John Davies Spokane WA Great info. Getting ready to buy the Victron Multiplex II. Should I get the GX model? I will have 2 280Ah Lithiums (they arrive tomorrow) ‘the 4045CSV replacement board arrives Monday, and I have 380 portable Solar with the controller that came with the panels. Went on Victron site and saw they have 2 boat install vendors in St. Pete, across the bay from Tampa, where I live. The video is great, and let me know this install is above my pay grade. I will reach out to them for install price, so I am good to go for the April Rally. Gary and Anita Teaney and Ranger 2017 Oliver Elite II Hull 292 2018 Nissan Armada Tampa, FL
Teaney Hull 292 Posted April 4 Posted April 4 On 12/17/2023 at 9:03 PM, Ty J said: My Victron worked excellent this summer. Im not retired but still spent 35 days this summer in my camper. I love power assist. Ran batteries Dead only 5 times on trips. I only have deployable solar panels. Im expermenting with a pecron and victron dc to dc charger. It has 4700 wh on it. I Trickled charged my Battle borns with 130 watts. Im currently putting in DC fridge. Thanks to everyone in the forum also adding the table on outside that is included on newer models. Thats my winter projects. I am overwhelmed at work and have not logged into forums in while. Multiplus is working well. Powers my a/c for about 5 hours. Have original penguin II. Expermenting with new flat solar panels from Bouge RV going to mount on top of oliver. 2021 Oliver Elite II. Only issue I have seen is when the victron is running hard its fans vibrate or radiate through the olivers fiberglass walls under my bed. Hottest it has been in cavity with Victron is 94 degrees , we had a mild summer in Montana. Did not get overly hot, like last year of 104 for 4 to 6 weeks. Weather has been all over the board up here. With the victron i set it to pull1200 wattes from my house plugs and can run a/c plugged into my normal outlet at house or anywhere. THe a/c will pull around 1450 watts , it just pulls extra wattage from battery bank and recharges them between cycling of the a/c . Take care My rig did not come with solar. Going to try flat panel on top. Little scared about heat impact on fiberglass, have used flat panels in past get extemely hot underneath. (PS white spots are reflections on my lights in my shop) Merry Christmas. Ty, I’m intrigued. So how have they performed? My hull 292 also did not come with Solar. Would love to drive down the road and charge. Gary Gary and Anita Teaney and Ranger 2017 Oliver Elite II Hull 292 2018 Nissan Armada Tampa, FL
Galway Girl Posted April 4 Posted April 4 On 4/9/2024 at 8:32 AM, rideadeuce said: Any clarification on these questions or pics would be greatly appreciated. Just trying to figure it all out before hiring someone or diving in myself. I, also, just want to understand how it works. Try reading my upgrade article here... In it I describe all the steps to an upgrade - Also - check my personal message I sent today. Full Article in our Blog Here: https://4-ever-hitched.com/ggs-blog/f/lithium-battery-upgrade?blogcategory=Electrical+Upgrades Slides of the upgrade & Pix in this PDF: 12V Layout.pdf Craig - Hull 505 - (Galway Girl) 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
katanapilot Posted April 30 Posted April 30 Finally finished the Victron system retrofit. Everything seems to be working well and playing nicely with the other components. Haven't modified the truck yet with the DC cables to power the DC-DC charger, but no reason to think it won't work properly. Still a little programming to do to get all the settings and configuration correct. The Victron stuff is top notch and would be a good option for a premium package from Oliver. 4 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
jd1923 Posted June 7 Posted June 7 (edited) On 4/28/2023 at 6:49 AM, Ty J said: Can't beat power assist on Victron components (Uses battery to meet power requirements when specified amount of current is set) I thought to find an old thread I had remembered reading, just after I had joined the OTT Forum. At first, I did not understand the value of this feature. How would Victron Power Assist be of value in a real-world use case? Thank you @Ty J and others who had contributed here (now over 2 years ago). We love our Victron Multiplus II, OMG! Camping in south central Kansas, a muggy day that was going get hot, mid-to-high 80s over the afternoon, and we wanted to go for the day... Leaving our older pup Charley to rest in the Oliver while we were gone. The Dometic with SoftStart would not run on this public "20A circuit" alone, without blowing the breaker. I set the MP2 limit setting for incoming amps to 15A to be very safe 75% of the 20A commercial circuit (to lower the probability of blowing the breaker). We ran the Dometic Pengiun 2 A/C, set to 69F. The 600 Ah batteries were high 90s SOC due to our Orion DC-DC charger running as we drove in the day before. The Victron app showed -40A on startup, so I was thinking we would lose 30-40% SOC while gone for 4-5 hours. We were gone a full 5 hours. The SOC on 600 Ah, in Power Assist mode, dropped only 20% (compressor only running 60% of total time). All was good, A/C running, the Oliver interior nicely cooled down and all systems running as programmed. These are the results. Notice AC OUT at 1684W - 1226W AC IN = 458W supplied by batteries (at 96% efficiency: 458W / 13V x 36.7A). I've never before seen this screen on the Victron Connect app for the MP2. There truly is a working Power Assist mode, not only in how the MP2 Inverter/Charger functions, but as a listed display mode as shown. This feature works well and as advertised. 😂 Edited June 7 by jd1923 1 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rich.dev Posted June 7 Posted June 7 8 hours ago, jd1923 said: I thought to find an old thread I had remembered reading, just after I had joined the OTT Forum. At first, I did not understand the value of this feature. How would Victron Power Assist be of value in a real-world use case? John, here’s a nice video from Nate from Explorist Life explaining power assist. When my Xantrex craps out I’ll definitely go the MII route. 1 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Treasure Coast Vault Posted June 8 Posted June 8 Is the below search info below not correct? I am thinking you would set the Xantrex to only input 15 amps from shore power or generator then it would kick in and provide the next 10 amps or so with a 3000 watt inverter? How would the Xantrex know the difference between shore power and generator? Yes, Xantrex has a feature similar to Victron's Power Assist. Xantrex Freedom SW inverters and chargers include a "Generator Support Mode" that enables the unit to assist a generator when AC loads exceed its capacity. This functionality allows the inverter/charger to provide additional power from the batteries to supplement the generator, similar to how Victron's Power Assist uses battery power to supplement a limited input. Here's a more detailed explanation: Victron's Power Assist: This feature allows you to adjust the input current to a level lower than the output power without affecting output power. It allows the inverter/charger to use battery power to supplement a limited input like shore power or a generator. Xantrex's Generator Support Mode: This mode is specifically designed for RVs and boats. When using a generator, it allows the inverter/charger to draw power from the batteries to assist the generator when AC loads exceed its capacity. Key Difference: While both achieve the same goal of supplementing a limited power source, Xantrex's Generator Support Mode is more focused on generators and RV applications, whereas Victron's Power Assist can be used with various power sources.
jd1923 Posted June 9 Posted June 9 On 6/8/2025 at 9:25 AM, Treasure Coast Vault said: How would the Xantrex know the difference between shore power and generator? Test it on a 15A household circuit. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Treasure Coast Vault Posted June 17 Posted June 17 I tried it and it did not "Power Assist". Contacted Xantrex they said the XC does not support power assist only the SW models do. 1
