We are very happy to report that our 13500 BTU Truma Aventa AC retrofit was seamlessly completed today. A special thank you to Director of Service Jason Essary, Mike Sharpe, and Tucker the technician that did an excellent job on our install. Just amazing work and we are so grateful.
A Big Thank you to the entire Oliver Service Team!
David and Kathy
Patriots🇺🇸
New Truma Aventa decibel reading on high setting.
Former Dometic Penguin on high setting.
New Truma CP Plus Control panel.
https://www.truma.com/int/en/products/truma-operating-systems/truma-cp-plus
  • Like 9
Looking good! You guys will be sleeping in quiet comfort at the rally!
Thanks Chris, it’s a game changer!
Travel safe and we are fired up for you both on your special day tomorrow!
David
Awesome.  Keep us posted , as you continue to use it.
13 hours ago, Patriot said:
New Truma Pro Plus Control panel.
Do I see in this photo at the bottom left the original thermostat on the wall remaining to control the heater? We're having our Truma retrofit done on June 22. I hope the Dometic thermostat can be left in place.
@MobileJoy
That is not the OEM Dometic digital thermostat you see in the photo. I made a suggestion in April to Oliver to consider using this Honeywell furnace only digital thermostat in the below link. It was approved by their electrical engineers and is now an option when having the Truma retrofit done. Otherwise you will get the Dometic mechanical thermostat. So no Oliver is not using the original dual control thermostat. I much prefer the look, fit, and finish of the digital Tstat below.
This ended up being particularly helpful to me as I presold our Dometic Penguin prior to the retrofit being completed. I needed the original thermostat to sell with the Penguin.
here-
https://www.amazon.com/dp/B00H6ARNXO?psc=1&ref=ppx_yo2ov_dt_b_product_details
Patriot🇺🇸
Just now, MobileJoy said:
https://olivertraveltrailers.com/forums/profile/3243-patriot/,
Did you previously have an Easy Start capacitor? If so, did they remove it, or just bypass it, leaving it in place?
I wanted the ES left in in the Penguin. The buyer of my Penguin wanted it as part of the sale as he has a small genset. Oliver removes the ES along with the Penguin during the retro fit.
Patriot🇺🇸
That is fantastic! We so want to do this with ours. My husband wears hearing aids so the noise doesn’t bother him, but me…..I call it the freight train!😳😬
2021 Dodge Ram 1500
2021 Oliver Elite ll
Hull #732
Michigan
8 hours ago, Allen Lee Rohner said:
Have you tried running your Truma Aventa AC on 20 Amp shore power?
Allen
When we got the LE2 home last evening I plugged in with an adaptor to the standard 115v outlet. Mine are on 15 amp breakers so may not actually answer your question. As soon as the AC kicked on, it popped the 15 amp circuit breaker. Will be installing my 30amp RV plug in the garage today.
BTW the Truma did run OK on the 3200 watt generator all night. Just another test I wanted to perform.
@Ollie-Haus
Got my panel installed a few weeks before we took delivery.  I have a 50A circuit connected to it so I have to "manage" the connections to ensure I don't overload it. Although, it has breakers on the remote panel and the main panel.
With a 30A travel trailer it shouldn't be an issue.  I do like having the 20A outlet for other tools if I need it.  This model is from Connecticut Electric and I can close and lock the door with the trailer plugged in.
I stay with relatives which have standard 115v outlet on 20 amp breakers and would like to know if the Truma would run on this shore power.
Good to know about the Generator, I have the EU3200i.  Thank you, Allen
2021 Oliver Elite II, Hull # 867,    Shiloh, IL
2022 GMC Sierra 1500 AT4, 3.0L Diesel, CarbonPro
Truma says that a 3000 watt generator is required to run the Aventa unit.  A 20 amp outlet would not be sufficient.
John and Kim
So with the retrofit complete, ours runs fine on AC setting using a 20amp circuit.  However we do have a 30amp we plug into in our barn.  We run a 12volt fan and the invertor when we are storing it in our barn.  Has anyone measured the E2 height with the retrofit?
#837 started this new traveling experience in the summer of 2021 and loving it.
TV is 2020 Durango Citadel or 2021 Dodge 1500 diesel V6.  2021
Allen
I have not and won’t as I have 30 amp shore power at home. You could call Truma customer service and ask.
Patriot🇺🇸
