Moderators topgun2 Posted June 5, 2023 Moderators Share Posted June 5, 2023 Unfortunately, my ASA Voyager rearview camera developed a leak which cause moisture to collect inside the housing. This, in turn, caused the camera view to be "foggy" and/or virtually non-usable. Via email I contacted ASA's customer relations area and they advised me to send the camera in to be examined. I removed it from the Ollie, boxed it up and put it in the mail 6 days ago. Today, I received a new camera via FedEx. That is what I call great service!. Unfortunately, ASA didn't include a tech in the package to do the re-install! However, that process has got to be a bunch easier than getting the old one off the Oliver in the first place.😊 Like Oliver, these guys take Service to the point it should be and this makes what could have been a very disappointing situation into an almost pleasant one. Bill 7 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
Patriot Posted June 5, 2023 Share Posted June 5, 2023 25 minutes ago, topgun2 said: Unfortunately, my ASA Voyager rearview camera developed a leak which cause moisture to collect inside the housing. This, in turn, caused the camera view to be "foggy" and/or virtually non-usable. Via email I contacted ASA's customer relations area and they advised me to send the camera in to be examined. I removed it from the Ollie, boxed it up and put it in the mail 6 days ago. Today, I received a new camera via FedEx. That is what I call great service!. Unfortunately, ASA didn't include a tech in the package to do the re-install! However, that process has got to be a bunch easier than getting the old one off the Oliver in the first place.😊 Like Oliver, these guys take Service to the point it should be and this makes what could have been a very disappointing situation into an almost pleasant one. Bill Bill, That is great news! Now you will be back at keeping an 👁️on things while on the super slab! 😊 Patriot🇺🇸 1 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor North Carolina 🇺🇸 Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted June 6, 2023 Moderators Share Posted June 6, 2023 Bill, which model do you have? Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted June 6, 2023 Author Moderators Share Posted June 6, 2023 12 hours ago, Mike and Carol said: Bill, which model do you have? Good question, Mike. I'm not sure of the model number but it is the camera without the "hood" over the top and the antenna comes straight up off the back of the camera housing. Does the picture below help? 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
MAX Burner Posted June 6, 2023 Share Posted June 6, 2023 @topgun2: Same here. Researching for model number ATM... Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
Moderators mossemi Posted June 6, 2023 Moderators Share Posted June 6, 2023 This is the rear view camera on hull 193: Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
MAX Burner Posted June 6, 2023 Share Posted June 6, 2023 3 minutes ago, mossemi said: This is the rear view camera on hull 193: Mossey Ah! @mossemi - beat me to it, brother! HA! Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
Wayfinder Posted September 23, 2023 Share Posted September 23, 2023 I have the same camera system and just ordered a new camera at Amazon, WVCMS130AP. I checked my manual to confirm. My camera was also full of water. I tried drying it out and using plumber's grease on the seal ,in hopes it would come back to life (no fog), it didn't work. There is only a fairly solid white image on the monitor, but the camera is transmitting - yay!? I don't know what to expect in regards to the wiring. Do I get to it from the inside rear-upper cabinet space, or pull the wire seal from the outside? Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted September 23, 2023 Author Moderators Share Posted September 23, 2023 1 hour ago, Wayfinder said: I don't know what to expect in regards to the wiring. Do I get to it from the inside rear-upper cabinet space, or pull the wire seal from the outside? See my reply to your other post about the camera. The wiring can be accessed via the attic. You will need to remove the two self tapping screws/bolts at the bottom of the left (curbside) panel and pull down the insulation. You should be able to locate where the wires from the camera come through the roof. Follow those wires about a foot to 18 inches and you should come to the pin connector I mention in the other post. Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
Wayfinder Posted September 24, 2023 Share Posted September 24, 2023 Thanks Bill 1 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
